oe36
13 November 2024 17:16
1
Today I booted up my Lenovo Legion 5I in Manjaro and ran steam. My fans were running very hard. This has never happened before. Checked CPU load, GPU load, temps, etc and all seemed fine and not sure why fans had to run so hard.
Also booted in Windows and did not have the same experience. (EDIT - disregard that last sentance, happening in Windows as well. May be a hardware issue)
Is there a guide on how to check / setup fans in Manjaro? I am wondering if something became misconfigured.
Thank you.
Kobold
13 November 2024 18:13
2
The way you describe your problem, it looks indeed like a hardware issue.
A system report shows also your Temps, so if you could check your system settings while running steam with your noisy fans, could be helpfull.
inxi --admin --verbosity=5 --filter --no-host --width
Repasting Termal Paste is my first guess.
To reduce Fanspeed doesn’t sound like a good idea, when you normally have a silent system while running steam, so the additional fan speed probably prevent your system from a meltdown.
HTOP will show the system usage btw.
oe36
13 November 2024 18:51
3
Thanks for the replay Kobold. I will get you the inxi info this afternoon. I can mention that the CPU usage widget on KDE was saying CPU usage less than 1 pct and GPU temp was 37C so something seems odd.
This started happening this morning. Last night, I put the machine to “sleep” while booted into Manjaro and when I woke up this morning, the battery was fully dead. Not sure if that could have contributed to the fans going haywire. Seems coincidental to me. I will get you the requested info later this afternoon.
Thank you.
oe36
13 November 2024 19:36
4
Here is the data from the inxi query…
Kernel: 6.11.2-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
root=UUID=dbcb9150-6182-41c0-8f44-7d25537ac315 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
Type: Laptop System: LENOVO product: 82WK v: Legion Pro 5 16IRX8
serial: Chassis: type: 10 v: Legion Pro 5 16IRX8
serial:
Mobo: LENOVO model: LNVNB161216 v: SDK0T76461 WIN
serial: part-nu: LENOVO_MT_82WK_BU_idea_FM_Legion Pro 5
16IRX8 uuid: UEFI: LENOVO v: KWCN46WW date: 07/04/2024
ID-1: BAT0 charge: 77.2 Wh (100.0%) condition: 77.2/80.0 Wh (96.5%)
volts: 17.3 min: 15.4 model: Sunwoda L22D4PC0 type: Li-poly serial:
status: full cycles: 67
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
serial: charge: 55% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: 16 GiB available: 15.36 GiB used: 8.6 GiB (56.0%)
Device-1: Controller0-ChannelA-DIMM0 type: DDR5 detail: synchronous
size: 8 GiB speed: spec: 5600 MT/s actual: 4800 MT/s volts: curr: 1
width (bits): data: 64 total: 64 manufacturer: Samsung
part-no: M425R1GB4BB0-CWMOD serial:
Device-2: Controller1-ChannelA-DIMM0 type: DDR5 detail: synchronous
Info: model: 13th Gen Intel Core i7-13700HX bits: 64 type: MST AMCP
arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183) stepping: 1
microcode: 0x129
Topology: cpus: 1x dies: 1 clusters: 10 cores: 16 threads: 24 mt: 8 tpc: 2
st: 8 smt: enabled cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32
KiB, 8x64 KiB L2: 14 MiB desc: 8x1.2 MiB, 2x2 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 2242 min/max: 800/4800:5000:3700 scaling:
driver: intel_pstate governor: powersave cores: 1: 2242 2: 2242 3: 2242
4: 2242 5: 2242 6: 2242 7: 2242 8: 2242 9: 2242 10: 2242 11: 2242 12: 2242
13: 2242 14: 2242 15: 2242 16: 2242 17: 2242 18: 2242 19: 2242 20: 2242
21: 2242 22: 2242 23: 2242 24: 2242 bogomips: 110616
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Raptor Lake-S UHD Graphics vendor: Lenovo driver: i915
v: kernel alternate: xe arch: Gen-13 process: Intel 7 (10nm) built: 2022+
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:a788
class-ID: 0300
Device-2: NVIDIA AD106M [GeForce RTX 4070 Max-Q / Mobile] vendor: Lenovo
driver: nvidia v: 550.120 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
bus-ID: 01:00.0 chip-ID: 10de:2860 class-ID: 0300
Device-3: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:7 chip-ID: 04f2:b7b6
class-ID: fe01 serial:
Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_wayland driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915,nvidia display-ID: 0
Monitor-1: eDP-1 res: 2560x1600 size: N/A modes: N/A
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
surfaceless: drv: nvidia wayland: drv: iris x11: drv: iris
inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.4-arch1.0.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-S)
device-ID: 8086:a788 memory: 7.5 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.295 layers: 10 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4070 Laptop GPU driver: nvidia v: 550.120 device-ID: 10de:2860
surfaces: xcb,xlib,wayland
Device-1: Intel Raptor Lake High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:7a50 class-ID: 0403
Device-2: NVIDIA AD106M High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
bus-ID: 01:00.1 chip-ID: 10de:22bd class-ID: 0403
Device-3: GN Netcom Jabra Link 380 driver: jabra,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3.1:5
chip-ID: 0b0e:24c7 class-ID: 0300 serial:
API: ALSA v: k6.11.2-4-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
Device-1: Intel Raptor Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:7a70 class-ID: 0280
IF: wlp0s20f3 state: up mac:
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 4000 bus-ID: 0c:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp12s0 state: down mac:
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:9 chip-ID: 8087:0033
class-ID: e001
Local Storage: total: 2.86 TiB used: 447.95 GiB (15.3%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung model: MZVL21T0HCLR-00BL2
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: fw-rev: EL1QGXA7 temp: 33.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 2TB
lanes: 4 tech: SSD serial: fw-rev: 4B2QJXD7 temp: 32.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: SanDisk model: USB 3.2Gen1
size: 114.6 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial:
fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 447.95 GiB (24.4%)
fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:2 label: N/A
uuid: dbcb9150-6182-41c0-8f44-7d25537ac315
used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1 label: N/A
uuid: 368C-DD8F
System Temperatures: cpu: 66.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 453 Power: uptime: 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.11 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: 2024 pm: pacman pkgs: 1991 libs: 535 tools: pamac pm: flatpak
pkgs: 33 Compilers: clang: 18.1.8 gcc: 14.2.1 alt: 13 Shell: Zsh v: 5.9
default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.36
66C on the CPU didn’t seem too terribly high to me. Fans were rediculous.
Let me know if you see anything… Thank you.
Wollie
13 November 2024 19:43
5
Have you checked your firmware settings?
oe36
13 November 2024 19:48
6
Think I figured it out. I’m going to own this one since folks probably need a good laugh anyway. I mentioned the battery died while in sleep mode. Further disclosure, I was nodding off last night while using the machine.
There is an undocumented feature that Fn + Q sets your fan mode to “quiet”, “auto” or “let’s see if we can get this laptop to levitate” mode.
I’m pretty sure while drifting in and out of consciousness I must have bumped that feature. A duckduck search helped me find the resolution.
God always finds a way to keep us humble. Thanks for your responses.
system
Closed
16 November 2024 19:48
7
