Fancontrol not supported by the installed driver
I installed Coolercontrol so that I can control the AIO but it keeps telling:
 coolercontrold[22688]: PWM fan at /sys/class/hwmon/hwmon3/pwm1 is NOT writable - Fan control is not currently supported by the installed driver.
What driver is the current one? Maybe it means liquidctl?
inxi -Farz         ✔
  Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=ddd0a425-4318-460a-8a6e-486102175cb6 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.18.0
  Type: Desktop System: Gigabyte product: Z390 AORUS PRO v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: Z390 AORUS PRO-CF v: x.x
    serial: <superuser required> uuid: <superuser required>
    UEFI-[Legacy]: American Megatrends v: F12d date: 12/18/2019
  Info: model: Intel Core i7-9700K bits: 64 type: MCP arch: Coffee Lake
    gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xC (12) microcode: 0xF8
  Topology: cpus: 1x dies: 1 clusters: 8 cores: 8 smt: <unsupported> cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 800 min/max: 800/4900 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 bogomips: 57616
  Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: disabled;
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [Radeon RX 9070/9070
    XT/9070 GRE] vendor: XFX driver: amdgpu v: kernel arch: RDNA-4
    code: Navi-4x process: TSMC n4 (4nm) built: 2025+ pcie: gen: 5
    speed: 32 GT/s lanes: 16 ports: active: DP-3 empty: DP-1, DP-2, HDMI-A-1,
    Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:7550 class-ID: 0300
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: DP-3 model: Dell AW3423DWF serial: <filter> built: 2023 res:
    mode: 3440x1440 hz: 60 scale: 114% (1.15) to: 2991x1252 dpi: 109 gamma: 1.2
    size: 800x337mm (31.5x13.27") diag: 868mm (34.2") modes: max: 3440x1440
    min: 720x400
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.3-arch1.2
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 9070 XT (radeonsi
    gfx1201 LLVM 20.1.8 DRM 3.61 6.12.48-1-MANJARO) device-ID: 1002:7550
    memory: 15.62 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.321 layers: 4 device: 0 type: discrete-gpu name: AMD
    Radeon RX 9070 XT (RADV GFX1201) driver: mesa radv v: 25.2.3-arch1.2
    device-ID: 1002:7550 surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: lact wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
  Device-2: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
    driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16
    bus-ID: 03:00.1 chip-ID: 1002:ab40 class-ID: 0403
  Device-3: Corsair HS65 SURROUND driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:2
    chip-ID: 1b1c:0a87 class-ID: 0300
  API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
  Local Storage: total: 4.83 TiB used: 1.28 TiB (26.4%)
    model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 620311WD temp: 39.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Western Digital
    fw-rev: 620331WD temp: 40.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
    tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
  ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 250GB
    size: 232.88 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
  ID-6: /dev/sdd maj-min: 8:48 vendor: Kingston model: DataTraveler 3.0
    size: 57.62 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    scheme: MBR
  ID-1: / raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
    used: 8.31 GiB (3.6%) fs: btrfs dev: /dev/sdc1 maj-min: 8:33
  ID-2: /home raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
  ID-3: /var/log raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
  System Temperatures: cpu: 31.0 C pch: 52.0 C mobo: N/A gpu: amdgpu
    temp: 44.0 C mem: 46.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
  Packages: pm: pacman pkgs: 1449 libs: 445 tools: octopi,pamac,yay
    pm: flatpak pkgs: 0
    1: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    2: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    3: https://manjaro.mirror-services.net/pub/stable/$repo/$arch
  Memory: total: 16 GiB available: 15.55 GiB used: 4.21 GiB (27.1%)
  Processes: 310 Power: uptime: 2h 9m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.39
It took me ~2 minutes to find a possible likely reason in the docs.
As you have a newer card (RX9070), you need linux >=6.12, and you need to set a kernel parameter amdgpu.ppfeaturemask=0xffffffff to enable all features.
You already have 6.12 so hopefully the kernel parameter will help.
So this is about the gpu-fan. Coolercontrol is really bad managing that one, so I better exclude it again.
Thank you! And thanks for the Kernel reminder I hadnt checked that yet. But it is on 6.12 anyways. I thought it would install a higher one already.
So many settings to change after a fresh install.
a back up (of /etc in that case) would likely have made restoration easier
Actually I don’t know, it was just what popped up in a search and your GPU matched.
Search around in /sys/class/hwmon/hwmon3/ for clues (forgot to mention this in the first post).
ls /sys/class/hwmon/hwmon3/
cat /sys/class/hwmon/hwmon3/name
Nope, only when a currently installed kernel is removed from the repos. 6.12 is an LTS so it will be around for a while, if you want a newer kernel then install one.
mhwd-kernel -li
mhwd-kernel -l
sudo mhwd-kernel -i linux618
Thats no problem, I have a backup of that, just from sdb4 and I dont know if that would cause problems on sdc1 If I do that and the stutter is back then I’d give up :stuck_out_tongue:
I wouldnt see a clue if it jumped on me :slight_smile:
ls /sys/class/hwmon/hwmon3/                                                 ✔
device       freq2_input     power1_cap_default  temp1_crit       temp2_input
fan1_enable  freq2_label     power1_cap_max      temp1_crit_hyst  temp2_label
fan1_input   in0_input       power1_cap_min      temp1_emergency  temp3_crit
fan1_max     in0_label       power1_label        temp1_input      temp3_crit_hyst
fan1_min     name            pwm1                temp1_label      temp3_emergency
fan1_target  power           pwm1_max            temp2_crit       temp3_input
freq1_input  power1_average  pwm1_min            temp2_crit_hyst  temp3_label
freq1_label  power1_cap      subsystem           temp2_emergency  uevent
    ~  cat /sys/class/hwmon/hwmon3/name                                            ✔
amdgpu
Thanks, maybe later I will, atm. I just wanna get it as my old system was again.
The Manjaro Settings Manager’s Kernel manager is easy to use without having to note down and find commands later.
There’s one right here :down_arrow:
If that’s the case:
just copy the relevant file over to your current installation, to the same directory, of course … :wink:
What is it that you want to do?
reconfigure everything (which takes some time - not too much, though)
or just use the backup files - which you apparently have, but somehow cannot access?
Thanks for the laugh. You see a clue, while I break up laughing because I still dont.
Yea I know I have an amd gpu. I really feel stupid :slight_smile:
“the relevant files” gotta check whats relevant and how I I can find out
I can, they are on the nvme and that is in the devices list. I just dont know if I should dare, or just take the time now, every evening, and set it all up to avoid possible problems from the backup.
The directory /sys/class/hwmon/hwmon3/ relates to a piece of hardware - in this case it’s your GPU.
Therefore /sys/class/hwmon/hwmon3/pwm1 is a PWM fan from your GPU.
So:
Yes.
Or try what the docs say. :man_shrugging:
I have re installed countless times.
I seldom just copied files from backups I had - I just used them as a reference for what to do on the fresh install.
It takes some time - but not “every evening” till the end of time …
It may take a few hours - or only minutes when you know what you are looking for and want to achieve …
But not days …
Oh silly me, that was what the error said. Now I woke up! Well then it is clear and I just exclude the gpu fan from coolercontrol. Because last time when CC had access it always sped up, slowed down, up, down until I found that it was CC in the first place.
Thank you!
To give CC access to it and mess it up again? I dont think so :slight_smile:
What do the docs (which you won’t trust) say?
Writing directly to /sys/* is not permanent - after a reboot nothing will remain - even if you mess things up somehow.
It is not about the doc’s but about my experience the last time CC had access to the van. It not having access to the gpu fan serves me well.
… not an answer to the question though - therefore:
good luck!
