Hello. I have problem with Laptop Lenovo Thinkpad X240. Fan not working after suspend, overtherating over 95C and throttling. Sometimes fan working, sometimes not.
On Windows I didn’t saw that issue.
Added text where you can see output from lm-sensors when fan work at system start and fan not work after suspend.
When works:
[user51@lp ~]$ sensors
thinkpad-isa-0000
Adapter: ISA adapter
fan1: 3095 RPM
CPU: +46.0°C
GPU: +0.0°C
temp3: +0.0°C
temp4: +0.0°C
temp5: +0.0°C
temp6: +0.0°C
temp7: +0.0°C
temp8: +0.0°C
BAT0-acpi-0
Adapter: ACPI interface
in0: 12.25 V
coretemp-isa-0000
Package id 0: +45.0°C (high = +100.0°C, crit = +100.0°C)
Core 0: +44.0°C (high = +100.0°C, crit = +100.0°C)
Core 1: +43.0°C (high = +100.0°C, crit = +100.0°C)
BAT1-acpi-0
in0: 12.94 V
acpitz-acpi-0
temp1: +46.0°C
When not working:
thinkpad-isa-0000
fan1: 0 RPM
CPU: N/A
GPU: +0.0°C
temp3: +0.0°C
temp4: +0.0°C
temp5: +0.0°C
temp6: +0.0°C
temp7: +0.0°C
temp8: +0.0°C
BAT0-acpi-0
in0: 12.24 V
coretemp-isa-0000
Package id 0: +55.0°C (high = +100.0°C, crit = +100.0°C)
Core 0: +55.0°C (high = +100.0°C, crit = +100.0°C)
Core 1: +55.0°C (high = +100.0°C, crit = +100.0°C)
BAT1-acpi-0
in0: 12.94 V
acpitz-acpi-0
temp1: +48.0°C
inxi output:
user51@lp ~]$ inxi -Farz
Kernel: 6.6.63-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=7b1d60b8-dab3-444f-ae28-3ae5c98d3ae0 rw quiet splash apparmor=1
security=apparmor udev.log_priority=3 mitigations=off
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
with: plank,xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: LENOVO product: 20AL00E0RT v: ThinkPad X240
Mobo: LENOVO model: 20AL00E0RT v: SDK0E50510 PRO
serial: <superuser required>
part-nu: LENOVO_MT_20AL_BU_Think_FM_ThinkPad X240
uuid: <superuser required> UEFI: LENOVO v: GIET99WW (2.49 )
date: 03/17/2020
ID-1: BAT0 charge: 12.8 Wh (96.2%) condition: 13.3/23.2 Wh (57.5%)
volts: 12.2 min: 11.1 model: SANYO 45N1773 type: Li-ion serial: <filter>
status: not charging
ID-2: BAT1 charge: 27.3 Wh (100.0%) condition: 27.3/24.0 Wh (113.7%)
volts: 12.9 min: 11.4 model: SANYO 45N1130 type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i5-4210U bits: 64 type: MT MCP arch: Haswell
gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
family: 6 model-id: 0x45 (69) stepping: 1 microcode: 0x26
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1032 min/max: 800/2700 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 1032 2: 1032 3: 1032 4: 1032 bogomips: 19166
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable; IBPB: disabled; STIBP: disabled;
Type: srbds status: Vulnerable
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Lenovo ThinkPad X240
driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:0a16 class-ID: 0300
Device-2: Lite-On Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-8:4 chip-ID: 04ca:7035
class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.14 compositor: xfwm4 v: 4.18.0
driver: X: loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: LG Display 0x03ed built: 2012 res: 1366x768 hz: 60
dpi: 125 gamma: 1.2 size: 277x156mm (10.91x6.14") diag: 318mm (12.5")
ratio: 16:9 modes: 1366x768
API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus x11:
drv: crocus inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4400 (HSW
GT2) device-ID: 8086:0a16 memory: 1.46 GiB unified: yes
Device-1: Intel Haswell-ULT HD Audio vendor: Lenovo ThinkPad X240
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c
class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Lenovo ThinkPad X240
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20
class-ID: 0403
API: ALSA v: k6.6.63-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I218-LM vendor: Lenovo ThinkPad X240 driver: e1000e
v: kernel port: 3080 bus-ID: 00:19.0 chip-ID: 8086:155a class-ID: 0200
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:08b2 class-ID: 0280
Local Storage: total: 480.68 GiB used: 102.14 GiB (21.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 00WD
scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD U110 16GB
size: 14.91 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 001 scheme: GPT
ID-1: / raw-size: 288.77 GiB size: 283.17 GiB (98.06%)
used: 102.14 GiB (36.1%) fs: ext4 dev: /dev/sda6 maj-min: 8:6
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda5 maj-min: 8:5
System Temperatures: cpu: 60.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1391 libs: 424 tools: pamac,yay
pm: flatpak pkgs: 0
Active pacman repo servers in: /etc/pacman.conf
1: https://download.sublimetext.com/arch/stable/x86_64
1: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
2: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
5: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
6: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
Memory: total: 8 GiB available: 7.64 GiB used: 2.48 GiB (32.4%)
Processes: 265 Power: uptime: 1m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 3.04 GiB services: upowerd,xfce4-power-manager
Init: systemd v: 256 default: graphical tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Bash v: 5.2.37
running-in: xfce4-terminal inxi: 3.3.36
