Hello,
since a few days my fan on my Lenovo Notebook is not turning on the fan anymore even on high heat! ( e.g. when running a 4k video).
The sensors -u
gives the following output (when 4k video is playing):
pch_cannonlake-virtual-0
Adapter: Virtual device
temp1:
temp1_input: 74.000
ucsi_source_psy_USBC000:001-isa-0000
Adapter: ISA adapter
in0:
in0_input: 0.000
in0_min: 0.000
in0_max: 0.000
curr1:
curr1_input: 3.000
curr1_max: 0.000
nvme-pci-0300
Adapter: PCI adapter
Composite:
temp1_input: 36.850
temp1_max: 84.850
temp1_min: -273.150
temp1_crit: 84.850
temp1_alarm: 0.000
Sensor 1:
temp2_input: 36.850
temp2_max: 65261.850
temp2_min: -273.150
Sensor 2:
temp3_input: 35.850
temp3_max: 65261.850
temp3_min: -273.150
ucsi_source_psy_USBC000:002-isa-0000
in0:
in0_input: 5.000
in0_min: 5.000
in0_max: 5.000
curr1:
curr1_input: 3.000
curr1_max: 3.000
thinkpad-isa-0000
fan1:
fan1_input: 0.000
temp1_input: -127.000
GPU:
temp2_input: 1.000
temp3:
temp3_input: 4.000
temp4:
temp4_input: 0.000
temp5:
ERROR: Can't get value of subfeature temp5_input: Can't read
temp6:
ERROR: Can't get value of subfeature temp6_input: Can't read
temp7:
temp7_input: 0.000
temp8:
temp8_input: 0.000
coretemp-isa-0000
Package id 0:
temp1_input: 90.000
temp1_max: 100.000
temp1_crit: 100.000
temp1_crit_alarm: 0.000
Core 0:
temp2_input: 90.000
temp2_max: 100.000
temp2_crit: 100.000
temp2_crit_alarm: 0.000
Core 1:
temp3_input: 87.000
temp3_max: 100.000
temp3_crit: 100.000
temp3_crit_alarm: 0.000
Core 2:
temp4_input: 90.000
temp4_max: 100.000
temp4_crit: 100.000
temp4_crit_alarm: 0.000
Core 3:
temp5_input: 89.000
temp5_max: 100.000
temp5_crit: 100.000
temp5_crit_alarm: 0.000
BAT0-acpi-0
Adapter: ACPI interface
in0:
in0_input: 11.372
The fan is not broken, the BIOS starts it up when turning on the computer. Maybe this came after an update?
My computer stats :
> inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.15.138-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
root=UUID=f91d5c3c-771a-42ad-bc25-a42929a9fec9 rw quiet splash apparmor=1
security=apparmor resume=UUID=e38abb1d-2937-46c5-800a-994a5aa81cf5
udev.log_priority=3 ipv6.disable=1
Desktop: GNOME v: 45.1 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 45.0.1
Type: Convertible System: LENOVO product: 20NT001KGE v: ThinkPad L390 Yoga
serial: <superuser required> Chassis: type: 31 serial: <superuser required>
Mobo: LENOVO model: 20NT001KGE v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: R10ET33W (1.18 )
date: 05/24/2019
ID-1: BAT0 charge: 27.9 Wh (80.9%) condition: 34.5/45.0 Wh (76.7%)
power: 7.4 W volts: 11.8 min: 11.1 model: LGC 01AV481 type: Li-poly
serial: <filter> status: discharging cycles: 402
System RAM: total: 16 GiB note: est. available: 15.27 GiB
used: 3.57 GiB (23.4%)
Info: model: Intel Core i7-8565U bits: 64 type: MT MCP arch: Whiskey Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xB (11) microcode: 0xF4
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1298 high: 2483 min/max: 400/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 900 3: 2379 4: 2483
5: 900 6: 900 7: 968 8: 957 bogomips: 32012
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Lenovo
ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Bison SunplusIT Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 5986:2113
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x075f built: 2017 res: 1920x1080
hz: 60 dpi: 166 gamma: 1.2 size: 294x165mm (11.57x6.5") diag: 337mm (13.3")
ratio: 16:9 modes: 1920x1080
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (WHL GT2)
device-ID: 8086:3ea0 memory: 14.91 GiB unified: yes
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
API: ALSA v: k5.15.138-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.84 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Device-1: Intel Ethernet I219-V vendor: Lenovo driver: N/A modules: e1000e
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15be class-ID: 0200
Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter
driver: rtl8188eu type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-3:5 chip-ID: 0bda:8179 class-ID: 0000 serial: <filter>
IF: enp0s20f0u3 state: up mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Local Storage: total: 931.51 GiB used: 413.33 GiB (44.4%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 1B2QEXM7 temp: 36.9 C scheme: GPT
ID-1: / raw-size: 914.42 GiB size: 898.99 GiB (98.31%)
used: 413.33 GiB (46.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: f91d5c3c-771a-42ad-bc25-a42929a9fec9
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: C036-B6F4
ID-1: swap-1 type: partition size: 16.79 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: e38abb1d-2937-46c5-800a-994a5aa81cf5
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-3:5 info: Realtek RTL8188EUS 802.11n Wireless Network Adapter
type: Network driver: rtl8188eu interfaces: 1 rev: 2.0
Device-2: 1-5:2 info: Bison SunplusIT Integrated Camera type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 5986:2113 class-ID: 0e02
Device-3: 1-6:3 info: Wacom Pen and multitouch sensor type: HID
driver: usbhid,wacom interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 400mA chip-ID: 056a:5158 class-ID: 0300
Device-4: 1-7:9 info: Synaptics Metallica MOH Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
chip-ID: 06cb:00a2 class-ID: ff00 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
System Temperatures: cpu: 55.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0
Processes: 279 Uptime: 3h 28m wakeups: 1 Init: systemd v: 254
Packages: 1951 pm: pacman pkgs: 1936 libs: 483 tools: gnome-software,pamac
pm: flatpak pkgs: 0 pm: snap pkgs: 15 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.31
Hope you can help me out
