I have Lenovo V130 and i want to crank up the fans a little. My laptop sits at 50 degrees (celsius) idle. I know it isn’t that much high but my fans come alive after 60 degrees only. I want them to be at level 2 at least at 50.
I have read the thinkfan, nbfc and fancontrol wikis. They helped a lot but fancontrol and nbfc didn’t work with my laptop.
thinkfan is supported but I want help in setting it up as the hwmon sensors change in name after every boot and thinkfan fails to start and my laptop then sits at 80 degrees on idle.
Thank you for your time and reply in advance.
