Hi there! I’m having the problem that my fan is really loud.
I fixed this problem about a year ago, but recently the issue appeared again. When I run pwmconfig
and then restart fancontrol
, the fan gets quiet enough that it doesn’t bother me. However, this is only temporary: When I reboot the PC, the fan is really loud again.
systemctl status fancontrol
reveals the following error after a reboot:
Okt 01 20:24:57 ludwig-pc fancontrol[515]: MINSTART=150
Okt 01 20:24:57 ludwig-pc fancontrol[515]: MINSTOP=0
Okt 01 20:24:57 ludwig-pc fancontrol[515]: MINPWM=0
Okt 01 20:24:57 ludwig-pc fancontrol[515]: MAXPWM=255
Okt 01 20:24:57 ludwig-pc fancontrol[515]: AVERAGE=1
Okt 01 20:24:57 ludwig-pc fancontrol[515]: Device path of hwmon4 has changed
Okt 01 20:24:57 ludwig-pc fancontrol[515]: Device name of hwmon4 has changed
Okt 01 20:24:57 ludwig-pc fancontrol[515]: Configuration appears to be outdated, please run pwmconfig again
Okt 01 20:24:57 ludwig-pc systemd[1]: fancontrol.service: Main process exited, code=exited, status=1/FAILURE
Okt 01 20:24:57 ludwig-pc systemd[1]: fancontrol.service: Failed with result 'exit-code'.
Do you know how to fix this?
Click to see (hopefully useful) system information
Screenfetch:
/usr/bin/screenfetch: Zeile 1802: 3315867648-: Syntaxfehler: Operator erwartet. (Fehlerverursachendes Zeichen ist "-").
██████████████████ ████████ ludwig@ludwig-pc
██████████████████ ████████ OS: Manjaro 21.1.4 Pahvo
██████████████████ ████████ Kernel: x86_64 Linux 5.13.19-2-MANJARO
██████████████████ ████████ Uptime: 46m
████████ ████████ Packages: 1735
████████ ████████ ████████ Shell: fish 3.3.1
████████ ████████ ████████ Resolution: 1920x1080
████████ ████████ ████████ DE: KDE 5.86.0 / Plasma 5.22.5
████████ ████████ ████████ WM: KWin
████████ ████████ ████████ GTK Theme: Dracula [GTK2/3]
████████ ████████ ████████ Icon Theme: breeze-dark
████████ ████████ ████████ Disk: 88G / 102G (91%)
████████ ████████ ████████ CPU: AMD A8-7600 Radeon R7, 10 Compute Cores 4C+6G @ 4x 3.1GHz
████████ ████████ ████████ GPU: AMD KAVERI (DRM 2.50.0, 5.13.19-2-MANJARO, LLVM 12.0.1)
RAM: 3315867648-
Here’s the content of /etc/fancontrol
# Configuration file generated by pwmconfig, changes will be lost
INTERVAL=10
DEVPATH=hwmon4=devices/platform/it87.2608
DEVNAME=hwmon4=it8772
FCTEMPS=hwmon4/pwm3=hwmon4/temp1_input
FCFANS= hwmon4/pwm3=hwmon4/fan2_input
MINTEMP=hwmon4/pwm3=20
MAXTEMP=hwmon4/pwm3=60
MINSTART=hwmon4/pwm3=150
MINSTOP=hwmon4/pwm3=0
Here’s the output of sensors
it8772-isa-0a30
Adapter: ISA adapter
in0: 828.00 mV (min = +0.00 V, max = +3.06 V)
in1: 1.51 V (min = +0.00 V, max = +3.06 V)
in2: 2.04 V (min = +0.00 V, max = +3.06 V)
in3: 2.08 V (min = +0.00 V, max = +3.06 V)
in4: 1.12 V (min = +0.00 V, max = +3.06 V)
in5: 1.12 V (min = +0.00 V, max = +3.06 V)
in6: 2.22 V (min = +0.00 V, max = +3.06 V)
3VSB: 3.29 V (min = +0.00 V, max = +6.12 V)
Vbat: 3.34 V
fan1: 0 RPM (min = 11 RPM) ALARM
fan2: 2445 RPM (min = 22 RPM)
fan3: 0 RPM (min = 19 RPM) ALARM
temp1: +41.0°C (low = +85.0°C, high = +90.0°C) sensor = thermistor
temp2: +40.0°C (low = +127.0°C, high = +127.0°C) sensor = thermistor
temp3: +10.0°C (low = +127.0°C, high = +127.0°C) sensor = thermal diode
intrusion0: ALARM
k10temp-pci-00c3
Adapter: PCI adapter
temp1: +10.0°C (high = +70.0°C)
(crit = +70.0°C, hyst = +69.0°C)
acpitz-acpi-0
Adapter: ACPI interface
temp1: +10.0°C (crit = +127.0°C)
radeon-pci-0008
temp1: +11.0°C (crit = +120.0°C, hyst = +90.0°C)
fam15h_power-pci-00c4
power1: N/A (crit = 65.19 W)
Summary of sensors-detect
Now follows a summary of the probes I have just done.
Just press ENTER to continue:
Driver `k10temp' (autoloaded):
* Chip `AMD Family 15h thermal sensors' (confidence: 9)
Driver `it87':
* ISA bus, address 0xa30
Chip `ITE IT8772E Super IO Sensors' (confidence: 9)
Driver `fam15h_power' (autoloaded):
* Chip `AMD Family 15h power sensors' (confidence: 9)
Do you want to overwrite /etc/conf.d/lm_sensors? (YES/no):
Content of /etc/conf.d/lm_sensors
# Generated by sensors-detect on Fri Oct 1 20:17:49 2021
# This file is sourced by /etc/init.d/lm_sensors and defines the modules to
# be loaded/unloaded.
# The format of this file is a shell script that simply defines variables:
# HWMON_MODULES for hardware monitoring driver modules, and optionally
# BUS_MODULES for any required bus driver module (for example for I2C or SPI).
HWMON_MODULES="it87"
