Fallback initramfs - how to enable it again?
Hi there,
I’d like to use fallback initramfs again and would need a little help. The directory /etc/mkinitcpio.conf.d/ is empty and I could not find a good template, neither do I know the name(s) of necessary file(s) here. Kernels in use are versions 6.12 and 6.18.
Any hints please?
The directory you want to look at is:
/etc/mkinitcpio.d/
That is where the .preset files are.
In each one there is a line (the fourth) like this:
PRESETS=('default')
change it to this:
PRESETS=('default' 'fallback')
I never had that line without the fallback option - I removed the keyword myself to disable the generation of the fallback image.
the complete file for the 6.12 kernel currently looks like this, for me:
# mkinitcpio preset file for the '6.12-x86_64' package
#ALL_config="/etc/mkinitcpio.conf"
ALL_kver="/boot/vmlinuz-6.12-x86_64"
PRESETS=('default')
#default_config="/etc/mkinitcpio.conf"
default_image="/boot/initramfs-6.12-x86_64.img"
#default_uki="/efi/EFI/Linux/manjaro-6.12-x86_64.efi"
#default_options="--splash /usr/share/systemd/bootctl/splash-manjaro.bmp"
#fallback_config="/etc/mkinitcpio.conf"
fallback_image="/boot/initramfs-6.12-x86_64-fallback.img"
#fallback_uki="/efi/EFI/Linux/manjaro-6.12-x86_64-fallback.efi"
fallback_options="-S autodetect"
Thank you for this hint, but what would be correct filenames for the .preset files?
This is from my /boot:
$ ll
insgesamt 124952
drwxr-xr-x  7 root root     4096  4. Dez 10:01 .
drwxr-xr-x 17 root root     4096 27. Nov 20:48 ..
-rw-r--r--  1 root root   307200 26. Nov 03:21 amd-ucode.img
drwx------  3 root root     4096  1. Jan 1970  efi
drwxr-xr-x  3 root root     4096 11. Aug 19:27 EFI
drwxr-xr-x  6 root root     4096  4. Dez 10:01 grub
-rw-------  1 root root 39772271  4. Dez 10:01 initramfs-6.12-x86_64.img
-rw-------  1 root root 42378018  4. Dez 10:01 initramfs-6.18-x86_64.img
-rw-r--r--  1 root root 14934016 11. Nov 19:07 intel-ucode.img
-rw-r--r--  1 root root       22  1. Dez 12:43 linux612-x86_64.kver
-rw-r--r--  1 root root       21  2. Dez 05:30 linux618-x86_64.kver
drwx------  2 root root    16384 25. Jul 11:53 lost+found
drwxr-xr-x  2 root root     4096 13. Jul 10:19 memtest86+
-rw-r--r--  1 root root 13914624  2. Dez 14:49 vmlinuz-6.12-x86_64
-rw-r--r--  1 root root 16580800  2. Dez 14:49 vmlinuz-6.18-x86_64
… not useful
Once you adapt the file(s) in /etc/mkinitcpio.d/...
and regenerate the images
sudo mkinitcpio -P
the fallback file will be in your listing of the contents of /boot
Do I understand you correctly, that inside the directory
/etc/mkinitcpio.d/
the filename is irrelevant? I’m asking since the above directory is empty here.
Yes.
the name might be irrelevant - I don’t know
the extension (.preset) probably is not irrelevant - I had no reason to try a different one
the content certainly is not irrelevant …
(I only have one kernel, the whole file is posted in my previous comment)
that must be some recent change that I’m not aware of :man_shrugging:
Here is a thread I found by looking for a potential issue:
Mkinitcpio v40 disabled fallback image creation for new installs
maybe it helps
Thank you for your support - it works :slight_smile: Obviously the first part of the .preset’s filename does not seem to be important.
Best regards
Stefan
ArchWiki - mkinitcpio - Fallback intramfs generation
As of version 40 of mkinitcpio, fallback initramfs generation is disabled by default.
To enable it:
  • Adjust the respective .preset files in /etc/mkinitcpio.d/
    • Disable PRESETS=('default') and enable PRESETS=('default' 'fallback') instead
    • Enable fallback_image="/boot/initramfs-linux-fallback.img"
    • Enable fallback_options="-S autodetect"
  • Regenerate initramfs
  • Update your boot loader configuration.
