Fakeroot binary missing
Hi I want to install “tracktion waveform pro” and found it n AUR. However I get an error when I follow the instructions found in the artivcle that @zoli62 linked here):
In command line I enter makepkg and this is what I get in turn:
~/Dokumente/tracktion-waveform >>> makepkg
==> FEHLER: Cannot find the fakeroot binary.
==> FEHLER: Cannot find the strip binary required for object file stripping.
Unfortunately I’m not experienced enough to fix this by myself.
Regards
Please see this:
https://wiki.manjaro.org/index.php?title=Arch_User_Repository
Particularly the part about needing base-devel package group before using the AUR.
(mode note - I moved your post as it was necroing an old thread, you are not actually converting a .deb package yourself, and this is a basic AUR question)
Thank you.
Note to other noobs:
I could install the software of my choice, after installing binutils and fakeroot.
Enter pamac install base-devel into command line an choose what to be added by typing in respective number.
However, as you see in @cscs 's post below, it is recommended to just install the whole package.
Will have to check out if software works. If I don’t post on this anymore, it works.
No …
install all of base-devel if you intend to use the AUR.
(what you did here might technically work in this one instance … but next time you might require some other part, etc)
Oi, too late!
I got the same error messages for both applications (obsidian and tracktion waveform pro).
I’ll install all of base-devel for future use hoping that the software will acutally work.
D: NOOB
The right command is:
sudo pacman -S --needed base-devel
This will install al missing packages of base-devel group
That solved it!
I can now install flowblade.
Thanks!
