Hi. Very new laptop with AMD Ryzen 5 (4000 series) and AMD Radeon graphics. Based on what I’ve read at other forums, I suspect this particular hardware combo might not do suspend in Linux. But let’s see…
Hibernate works, but I’m a big fan of suspend, which does not work. The screen goes black after selecting suspend from log-out menu or after pushing the power button, or even after entering “systemctl suspend” in terminal.
However, the power button light stays on, I can hear the fan, and I can even toggle through the keyboard backlight brightness options while the laptop is allegedly suspended.
I’ve seen this problem reported before, but the route to a solution is not clear to me. I read this (Power management - ArchWiki) but nothing jumps at me from there. Same with this (https://classicforum.manjaro.org/index.php?topic=32803.45) and this (Laptop does not suspend when lid is closed) etc.
System info:
Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=deb59a35-a866-456e-9aad-80eac89d9e75 rw quiet apparmor=1
security=apparmor resume=UUID=69d42cc9-b4dd-4683-ab58-fc0f5771ffc5
udev.log_priority=3
Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X521IA_M533IA
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X521IA v: 1.0 serial: <filter>
UEFI: American Megatrends v: X521IA.303 date: 07/31/2020
ID-1: BAT0 charge: 36.6 Wh condition: 50.9/50.0 Wh (102%) volts: 11.9/11.9
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Discharging
cycles: 6
Info: 6-Core model: AMD Ryzen 5 4500U with Radeon Graphics bits: 64
type: MCP arch: Zen family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600106 L2 cache: 3072 KiB
bogomips: 28454
Speed: 1397 MHz min/max: 1400/2375 MHz boost: enabled Core speeds (MHz):
1: 1397 2: 1397 3: 1397 4: 1397 5: 1397 6: 1396
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: disabled, RSB filling
Device-1: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel
bus ID: 03:00.0 chip ID: 1002:1636
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus ID: 3-3:3 chip ID: 13d3:56a2 serial: <filter>
Display: x11 server: X.Org 1.20.10 driver: amdgpu,ati unloaded: modesetting
alternate: fbdev,vesa display ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.39.0 5.9.11-3-MANJARO LLVM 11.0.0)
v: 4.6 Mesa 20.2.3 direct render: Yes
Device-1: AMD driver: snd_hda_intel v: kernel bus ID: 03:00.1
chip ID: 1002:1637
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 03:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.9.11-3-MANJARO
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus ID: 01:00.0
chip ID: 8086:2723
Local Storage: total: 238.47 GiB used: 9.87 GiB (4.1%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: HFM256GDJTNG-8310A
size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 serial: <filter> rev: 80001C00 scheme: GPT
ID-1: / raw size: 229.37 GiB size: 224.77 GiB (97.99%) used: 9.86 GiB (4.4%)
fs: ext4 dev: /dev/nvme0n1p2
ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3
System Temperatures: cpu: 33.6 C mobo: N/A gpu: amdgpu temp: 33.0 C
Fan Speeds (RPM): cpu: 0
Processes: 283 Uptime: 8m Memory: 7.26 GiB used: 1.64 GiB (22.6%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1132 lib: 351
flatpak: 0 Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.08
cat /sys/power/mem_sleep returned this:
[s2idle]
systemctl hybrid-sleep works, and if it comes to it, I would be happy with this as an alternative to suspend, but I would need help with that process. However, suspend is what I am looking for and will be first prize.
I don’t know if it’s relevant to this problem, but just in case it is, @megavolt solved a ‘blackscreen boot’ issue earlier where the problem was that the system tried and failed to load a radeon driver when the amd driver supports AMD Renoir: [Solved] Booting to black screen - #14 by megavolt
Any help will be much appreciated…
