How do I find the logs after updating attempt?
pacman log : /var/log/pacman.log
. but if no update, we have nothing in log.
run pamac (or pacman) in terminal
Your title isn’t finished.
Failure to update due to
Due to what? Is there an error you can share?
conflicting files:
- gcc13: /usr/lib/gcc/x86_64-pc-linux-gnu/lib/libgcc_s.so already exists in filesystem (owned by gcc12)
- gcc13: /usr/lib/gcc/x86_64-pc-linux-gnu/lib/libgcc_s.so.1 already exists in filesystem (owned by gcc12)
I looked at * » Upgrading from gcc12 to gcc13
How do I remove gcc12 ?
I had the same issue.
I ran pacman -Qi gcc12
to see if anything actually needed it. In my case there was no depending packages, so I removed it (pacman -R gcc12
The upgrade worked afterwards.
gcc12
isn’t in the repos any more, only the AUR. There were no (obvious) dependencies so I simply ran sudo pacman -Rns gcc12
and, as with @raphaelp, the upgrade worked fine afterwards.
