Whenever I tired to install headers this error shows.
Error! Bad return status for module build on kernel: 6.1.53-1-MANJARO (x86_64)
Consult /var/lib/dkms/rtl8822bu/20180723/build/make.log for more information.
==> WARNING: `dkms install --no-depmod rtl8822bu/20180723 -k 6.1.53-1-MANJARO' exited 10
==> dkms install --no-depmod rtl88x2bu/5.13.1.r189.12cfcd8 -k 6.1.53-1-MANJARO
==> dkms install --no-depmod rtl8821CU/5.4.1 -k 6.1.53-1-MANJARO
Consult /var/lib/dkms/rtl8821CU/5.4.1/build/make.log for more information.
==> WARNING: `dkms install --no-depmod rtl8821CU/5.4.1 -k 6.1.53-1-MANJARO' exited 10
==> dkms install --no-depmod rtl8821au/5.12.5.2 -k 6.1.53-1-MANJARO
==> dkms install --no-depmod rtl8822bu/5.8.7.4 -k 6.1.53-1-MANJARO
Deprecated feature: REMAKE_INITRD (/var/lib/dkms/rtl8822bu/5.8.7.4/source/dkms.conf)
Consult /var/lib/dkms/rtl8822bu/5.8.7.4/build/make.log for more information.
==> WARNING: `dkms install --no-depmod rtl8822bu/5.8.7.4 -k 6.1.53-1-MANJARO' exited 10
==> depmod 6.1.53-1-MANJARO
(4/4) Refreshing PackageKit..
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
