This is not just one package. I’m using AUR and I get the same CMAKE error message:
==> Starting build()...
CMake Deprecation Warning at CMakeLists.txt:5 (cmake_minimum_required):
Compatibility with CMake < 2.8.12 will be removed from a future version of
CMake.
Update the VERSION argument <min> value or use a ...<max> suffix to tell
CMake that the project does not need compatibility with older versions.
CMake Error: CMake was unable to find a build program corresponding to "Unix Makefiles". CMAKE_MAKE_PROGRAM is not set. You probably need to select a different build tool.
CMake Error: CMAKE_C_COMPILER not set, after EnableLanguage
CMake Error: CMAKE_CXX_COMPILER not set, after EnableLanguage
-- Configuring incomplete, errors occurred!
See also "/home/froggy/.cache/yay/art-rawconverter/src/art-rawconverter_1.8.3_build/CMakeFiles/CMakeOutput.log".
==> ERROR: A failure occurred in build().
Aborting...
I’ve had the same problem with other packages that had to be compiled.
Here is the CMakeLists.txt that I have:
/usr/share/git/buildsystems/CMakeLists.txt
and it has:
cmake_minimum_required(VERSION 3.14)
any suggestion on how to fix?
Thank you
