I keep getting a failed to synchronize databases after the Plasma 6 update on a couple machines. When I do the konsole update I get
hint: Using 'master' as the name for the initial branch. This default branch name
hint: is subject to change. To configure the initial branch name to use in all
hint: of your new repositories, which will suppress this warning, call:
hint:
hint: git config --global init.defaultBranch <name>
hint:
hint: Names commonly chosen instead of 'master' are 'main', 'trunk' and
hint: 'development'. The just-created branch can be renamed via this command:
hint:
hint: git branch -m <name>"
I open Add/Remove Software (Pamac) and get the Failed to Synchronize Data Bases.
I do the Konsole and put in sudo pamac update --force-refresh and it will update, but gives me that message in another color.
Open Add/Remove Software (Pamac) and it comes back with the Failed message.
Yes I have some AUR programs, might be that is what is failing in Pamac, but was working fine before the Plasma update. It works ok on other machines, fails on others.
I turned off the AUR/Flatpack in Pamac and it still fails to Synchronize Databases.
Never run pamac with sudo, it will prompt for privilege elevation when required. There is normally never a reason to force a refresh and will cause more problems than it solves.
OK, let me try again. I open add/remove software (pamac GUI) and it comes back Failed to Synchronize databases. Won’t let me update.
So I open konsole and type is pamac update and get
pamac update ✔
ln: failed to create symbolic link '/var/tmp/pamac/dbs/local': Permission denied
Preparing...
Failed to synchronize AUR database
cp: preserving times for '/var/tmp/pamac/dbs/sync': Operation not permitted
chmod: changing permissions of '/var/tmp/pamac/dbs/sync': Operation not permitted
chmod: changing permissions of '/var/tmp/pamac/dbs/sync/multilib.files': Operation not permitted
chmod: changing permissions of '/var/tmp/pamac/dbs/sync/core.db': Operation not permitted
chmod: changing permissions of '/var/tmp/pamac/dbs/sync/packages-meta-ext-v1.json.gz': Operation not permitted
chmod: changing permissions of '/var/tmp/pamac/dbs/sync/extra.files': Operation not permitted
chmod: changing permissions of '/var/tmp/pamac/dbs/sync/extra.db': Operation not permitted
chmod: changing permissions of '/var/tmp/pamac/dbs/sync/multilib.db': Operation not permitted
chmod: changing permissions of '/var/tmp/pamac/dbs/sync/core.files': Operation not permitted
chmod: changing permissions of '/var/tmp/pamac/dbs/sync/mhwd.db': Operation not permitted
Nothing to do.
Then I tried:
pamac update ✔
Preparing...
Nothing to do.
Then I tried:
pamac upgrade -a 1 ✘ 18s
Preparing...
Checking dropbox dependencies...
Resolving dependencies...
Checking inter-conflicts...
To build (1):
dropbox 199.4.6287-1 (197.4.7571-1) AUR
Edit build files : [e]
Apply transaction ? [e/y/N] y
Cloning dropbox build files...
hint:
hint:
hint:
Generating dropbox information...
Authenticating as: XXXXXX
Password:
Building dropbox...
==> Making package: dropbox 199.4.6287-1 (Mon 27 May 2024 09:31:49 PM CDT)
==> Retrieving sources...
-> Found DropboxGlyph_Blue.svg
-> Found terms.txt
-> Found dropbox.service
-> Found dropbox@.service
-> Downloading dropbox-lnx.x86_64-199.4.6287.tar.gz...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 111M 100 111M 0 0 19.4M 0 0:00:05 0:00:05 --:--:-- 20.1M
-> Downloading dropbox-lnx.x86_64-199.4.6287.tar.gz.asc...
100 488 100 488 0 0 5697 0 --:--:-- --:--:-- --:--:-- 5741
DropboxGlyph_Blue.svg ... Passed
terms.txt ... Passed
dropbox.service ... Passed
dropbox@.service ... Passed
==> Validating source_x86_64 files with sha256sums...
dropbox-lnx.x86_64-199.4.6287.tar.gz ... Passed
dropbox-lnx.x86_64-199.4.6287.tar.gz.asc ... Skipped
==> Verifying source file signatures with gpg...
==> Extracting sources...
-> Extracting dropbox-lnx.x86_64-199.4.6287.tar.gz with bsdtar
==> Starting prepare()...
[dropbox] Generating desktop file... ok
==> Entering fakeroot environment...
==> Starting package()...
==> Tidying install...
-> Removing libtool files...
-> Purging unwanted files...
-> Removing static library files...
-> Compressing man and info pages...
==> Checking for packaging issues...
==> Creating package "dropbox"...
-> Generating .PKGINFO file...
-> Generating .BUILDINFO file...
-> Generating .MTREE file...
-> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: dropbox 199.4.6287-1 (Mon 27 May 2024 09:31:58 PM CDT)
==> Cleaning up...
Checking keyring... [1/1]
Checking integrity... [1/1]
Loading packages files... [1/1]
Checking file conflicts... [1/1]
Checking available disk space... [1/1]
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
Upgrading dropbox (197.4.7571-1 -> 199.4.6287-1)... [1/1]
Reloading system manager configuration... [1/5]
Reloading user manager configuration... [2/5]
Arming ConditionNeedsUpdate... [3/5]
Refreshing PackageKit... [4/5]
Updating the desktop file MIME type cache... [5/5]
So I finally got it to update successfully
I hope that gives more information, but the GUI Pamac won’t work.
