Failed to synchronize AUR database
Hello!
Updating an AUR package today, I had an error message :
https://imgur.com/tiHsO1i
I looked further, of course :
https://aur.manjaro.org/packages-meta-ext-v1.json.gz: Unacceptable TLS certificate
https://imgur.com/z4qrZyK
I suppose it’s not a very big deal, but it’s still not a good thing, so here it is.
This has been an issue for some time now. Repeat the operation at some point it will work.
Just to be clear, the package was updated.
Yes, it happens to me often too
in the last times.
Since I’m new to Manjaro I did a search and saw that it’s a recurring thing.
Disable the AUR update check in Preferences.
This worked for me. Disable it close the options, then reenable it and it started syncing right again. Thanks!
