Failed to synchronize all databases (no servers configured for repository) and can not refresh mirrors
I am not able to update Manjaro, the update command with pacman gives me the error:
 ■■■■■■■■■■■■■■■ ~]$ sudo pacman -Syuu
error: failed to synchronize all databases (no servers configured for repository)
on searching I saw that it could be a mirrors issue and tried updating it, but got the error:
[■■■■■■■■■■■■■■ ~]$ sudo pacman-mirrors --fasttrack
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Using custom mirror file
::INFO Querying mirrors - This may take some time
  ..... India          : https://mirrors.vishnetwork.in/manjaro/
::ERROR Connection: HTTPSConnectionPool(host='mirrors.vishnetwork.in', port=443): Max retries exceeded with url: /manjaro/stable/core/x86_64/core.db.tar.gz (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fbb5a2c3490>: Failed to establish a new connection: [Errno -2] Name or service not known'))
  ..... India          : https://mirror.albony.xyz/manjaro/
::ERROR Connection 404 Client Error: Not Found for url: https://mirror.hyd.albony.in/manjaro/stable/core/x86_64/core.db.tar.gz
::INFO Writing mirror list
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
Then I thought that since I recently moved from India to the US, I can resolve this by switching the mirrors to another country but still ran into:
[■■■■■■■■■■■■■■ ~]$ sudo pacman-mirrors --country United_States --fasttrack
[sudo] password for jo:
Version 4.24.0
USAGE:
 pacman-mirrors [-h] [-f [NUMBER]] [-i [-d]] [-m METHOD] [--status]
		[-c COUNTRY [COUNTRY...] | [--geoip] | [--continent]]
		[-l] [-lc] [-q] [-t SECONDS] [-v] [-n]
		[--api] [-S/-B BRANCH] [-p PREFIX]
			[-P PROTO [PROTO...]] [-R] [-U URL]
pacman-mirrors: error: argument -f/--fasttrack: not allowed with argument -c/--country
Not sure if I proceeded in the right direction. I desperately need to update my packages. Any help with this will be appreciated.
Here are the complete details of my system:
  Kernel: 6.6.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=41e5b7b1-2fcc-46ac-a809-55b6ce116089 rw quiet
    resume=UUID=f2530063-c444-43b1-bd74-4a5321932a40
  Desktop: GNOME v: 45.4 tk: GTK v: 3.24.41 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 45.0.1 Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: Acer product: Predator PH315-51 v: V1.24
    serial: <superuser required>
  Mobo: CFL model: Sienta_CFS v: V1.24 serial: <superuser required>
    part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 1.24
    date: 12/05/2018
  ID-1: BAT1 charge: 26.1 Wh (100.0%) condition: 26.1/48.9 Wh (53.2%)
    volts: 15.9 min: 15.2 model: LG PABAS0241231 type: Li-ion serial: <filter>
    status: full
  System RAM: total: 8 GiB available: 7.6 GiB used: 5.61 GiB (73.8%)
  Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
    speed: 2667 MT/s volts: curr: 1 min: 1.25 max: 2 width (bits): data: 64
    total: 64 manufacturer: Kingston part-no: ACR26D4S9S8ME-8 serial: <filter>
  Device-2: ChannelB-DIMM0 type: no module installed
  Info: model: Intel Core i5-8300H bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 812 high: 900 min/max: 800/2300 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
    5: 900 6: 800 7: 800 8: 800 bogomips: 36812
    smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    vulnerable
Use of uninitialized value $data{"current_link_speed"} in substitution (s///) at /usr/bin/inxi line 35035.
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630]
    vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-9.5
    process: Intel 14nm built: 2016-20 ports: active: eDP-1 empty: none
    bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile]
    vendor: Acer Incorporated ALI driver: N/A alternate: nouveau
    non-free: 545.xx+ status: current (as of 2024-04; EOL~2026-12-xx)
    arch: Pascal code: GP10x process: TSMC 16nm built: 2016-2021
    bus-ID: 01:00.0 chip-ID: 10de:1c8c class-ID: 0300
  Device-3: Realtek USB Boot driver: N/A type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 1-5:13 chip-ID: 0bda:5841 class-ID: 0e02
    serial: <filter>
  Display: x11 server: X.org v: 1.21.1.12 with: Xwayland v: 23.2.6
    compositor: gnome-shell driver: X: loaded: intel dri: i965 gpu: i915
    display-ID: :1 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 mapped: eDP1 model: AU Optronics 0x60ed built: 2016
    res: 1920x1080 hz: 60 dpi: 143 gamma: 1.2 chroma: red: x: 0.647 y: 0.337
    green: x: 0.322 y: 0.608 blue: x: 0.149 y: 0.047 white: x: 0.314 y: 0.329
    size: 340x190mm (13.39x7.48") diag: 394mm (15.5") ratio: 16:9
    modes: 1920x1080
  API: OpenGL Message: Unable to show GL data. glxinfo is missing.
  Device-1: Intel Cannon Lake PCH cAVS vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
  Device-2: NVIDIA GP107GL High Definition Audio
    vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
    bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
  API: ALSA v: k6.6.26-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.3 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
  Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
    vendor: Acer Incorporated ALI RTL8111/8168/8411 driver: r8168
    v: 8.052.01-NAPI modules: r8169 pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3000 bus-ID: 06:00.1 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp6s0f1 state: down mac: <filter>
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:3
  Report: rfkill ID: hci0 rfk-id: 16 state: up address: see --recommends
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
    v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
  Local Storage: total: 1.03 TiB used: 81.73 GiB (7.8%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: RBUSNS8180DS3128GJ
    size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 61E1 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HTS721010A9E630
    tech: HDD rpm: 7200 serial: <filter> fw-rev: A3J0 scheme: GPT
  ID-1: / raw-size: 110.15 GiB size: 107.86 GiB (97.92%)
    used: 79.61 GiB (73.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 41e5b7b1-2fcc-46ac-a809-55b6ce116089
    used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 3ED0-E138
  ID-1: swap-1 type: partition size: 8.8 GiB used: 2.12 GiB (24.1%)
    priority: -2 dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: f2530063-c444-43b1-bd74-4a5321932a40
  ID-1: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: ntfs label: Data
    uuid: 02BE341FBE340E23
  Device-1: 1-5:13 info: Realtek USB Boot type: video driver: N/A
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 0bda:5841 class-ID: 0e02 serial: <filter>
  Device-2: 1-14:3 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
  System Temperatures: cpu: 45.0 C pch: 56.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1632 libs: 493 tools: pamac pm: flatpak pkgs: 0
  No active pacman repos in: /etc/pacman.d/mirrorlist
Processes:
  CPU top: 5 of 277
  1: cpu: 7.0% command: firefox pid: 125743 mem: 266.9 MiB (3.4%)
  2: cpu: 1.6% command: firefox pid: 3277 mem: 35.8 MiB (0.4%)
  3: cpu: 1.4% command: firefox pid: 2760 mem: 675.4 MiB (8.6%)
  4: cpu: 1.2% command: firefox pid: 144681 mem: 244.3 MiB (3.1%)
  5: cpu: 0.7% command: Research started-by: FoxitReader pid: 120774
    mem: 196.2 MiB (2.5%)
  Memory top: 5 of 277
  1: mem: 1131.3 MiB (14.5%) command: pamac-manager pid: 121386 cpu: 0.5%
  2: mem: 675.4 MiB (8.6%) command: firefox pid: 2760 cpu: 1.4%
  3: mem: 368.5 MiB (4.7%) command: firefox pid: 91381 cpu: 0.0%
  4: mem: 311.0 MiB (3.9%) command: firefox pid: 6180 cpu: 0.0%
  5: mem: 266.9 MiB (3.4%) command: firefox pid: 125743 cpu: 7.0%
  Processes: 277 Power: uptime: 15d 1h 3m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 13 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 3.03 GiB services: gsd-power,
    tool: systemctl
  Compilers: clang: 16.0.6 gcc: 13.2.1 alt: 12 Shell: Bash v: 5.2.26
    running-in: gnome-terminal inxi: 3.3.34
It sounds like you deleted the lines under [community] in /etc/pacman.cont but did not delete the line [community]
Edit your /etc/pacman.conf and make sure your repo config part look like this
[core]
Include = /etc/pacman.d/mirrorlist
[extra]
# If you want to run 32 bit applications on your x86_64 system,
# enable the multilib repositories as required here.
[multilib]
Some pacman-mirrors arguments cannot be combined - please read the message
To rebuild your mirror list use
sudo pacman-mirrors --country all
Or
sudo pacman-mirrors --fasttrack 10
Then do a system sync
sudo pacman -Syu
I’m not sure I follow here. I do not have any [community] in the command line messages here. Can you please direct me on what I must do?
Post your/etc/pacman.conf
[■■■■■■■■■■■■■■ ~]$ cat /etc/pacman.conf
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir     = /
#DBPath      = /var/lib/pacman/
CacheDir = /var/cache/pacman/pkg/
#LogFile     = /var/log/pacman.log
#GPGDir      = /etc/pacman.d/gnupg/
#HookDir     = /etc/pacman.d/hooks/
HoldPkg      = pacman glibc manjaro-system
# If upgrades are available for these packages they will be asked for first
SyncFirst    = manjaro-system archlinux-keyring manjaro-keyring
#XferCommand = /usr/bin/curl -C - -f %u > %o
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#TotalDownload
# We cannot check disk space from within a chroot environment
CheckSpace
#VerbosePkgLists
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
SigLevel    = Required DatabaseOptional
LocalFileSigLevel = Optional
#RemoteFileSigLevel = Required
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official Manjaro Linux
# packagers with `pacman-key --populate archlinux manjaro`.
# REPOSITORIES
#   - can be defined here or included from another file
#   - pacman will search repositories in the order defined here
#   - local/custom mirrors can be added here or in separate files
#   - repositories listed first will take precedence when packages
#     have identical names, regardless of version number
#   - URLs will have $repo replaced by the name of the current repo
#   - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
#       [repo-name]
#       Server = ServerName
#       Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
# The testing repositories are disabled by default. To enable, uncomment the
# repo name header and Include lines. You can add preferred servers immediately
# after the header, and they will be used before the default mirrors.
[core]
SigLevel = PackageRequired
[extra]
[community]
[multilib]
# An example of a custom package repository.  See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
Delete this section.
You can also simply enter the following in the terminal.
sudo cp /etc/pacman.conf /etc/pacman.conf.original
sudo cp /etc/pacman.conf.pacnew /etc/pacman.conf
sudo pacman -Syu
That will remove any custom changes made to pacman.conf. If the user didn’t make any, it wouldn’t make a difference.
Thanks, this helped. Although I could not run sudo pacman-mirrors --fasttrack correctly since it still seems to be trying to get the India connection Pool. So I used:
now on running the system update, I get the following conflict:
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: tlp and power-profiles-daemon are in conflict
how must I decide to keep tlp or power-profiles-daemon? Is it right to remove one of them and re-run the system update?
If you don’t know what tlp even is:
remove that one
If you know tlp, remove the other one.
Yes, it should be that simple.
Please see TLP and Power Profiles Daemon are in conflict.
