Sep 21 16:57:01 joel-Manjaro systemd-vconsole-setup[411]: /usr/bin/loadkeys failed with exit status 1.
Sep 21 16:57:01 joel-Manjaro systemd[1]: systemd-vconsole-setup.service: Main process exited, code=exited, status=1/FAILURE
░░ Subject: Unit process exited
░░ Defined-By: systemd
░░ An ExecStart= process belonging to unit systemd-vconsole-setup.service has exited.
░░ The process' exit code is 'exited' and its exit status is 1.
Sep 21 16:57:01 joel-Manjaro systemd[1]: systemd-vconsole-setup.service: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ The unit systemd-vconsole-setup.service has entered the 'failed' state with result 'exit-code'.
Sep 21 16:57:01 joel-Manjaro systemd[1]: Failed to start Virtual Console Setup.
░░ Subject: A start job for unit systemd-vconsole-setup.service has failed
░░ A start job for unit systemd-vconsole-setup.service has finished with a failure.
░░ The job identifier is 125 and the job result is failed.
