Failed to start Tracker metadata extractor 2
What does this error mean and how can I fix it:
systemd[1671]: Failed to start Tracker metadata extractor.
░░ Subject: A start job for unit UNIT has failed
░░ Defined-By: systemd
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 372 and the job result is failed.
It is this:
$ systemctl cat --user tracker-extract-3.service
# /usr/lib/systemd/user/tracker-extract-3.service
[Unit]
Description=Tracker metadata extractor
ConditionUser=!root
[Service]
Type=dbus
BusName=org.freedesktop.Tracker3.Miner.Extract
ExecStart=/usr/lib/tracker-extract-3
Restart=on-failure
# Don't restart after tracker daemon -k (aka tracker-control -k)
RestartPreventExitStatus=SIGKILL
Slice=background.slice
[Install]
WantedBy=default.target
Tracker is a file indexer that extracts metadata from files. It just fails to start.
Nothing to fix. It restarts on-failure:
Restart=on-failure
There is something wrong with it on my system though:
# systemctl --user status tracker-miner-fs-3.service
× tracker-miner-fs-3.service - Tracker file system data miner
     Loaded: loaded (/usr/lib/systemd/user/tracker-miner-fs-3.service; disabled; vendor preset: enabled)
     Active: failed (Result: exit-code) since Wed 2022-04-20 07:11:04 CEST; 10s ago
    Process: 3359386 ExecStart=/usr/lib/tracker-miner-fs-3 (code=exited, status=1/FAILURE)
   Main PID: 3359386 (code=exited, status=1/FAILURE)
        CPU: 80ms
Apr 20 07:11:03 username systemd[1671]: Failed to start Tracker file system data miner.
Apr 20 07:11:04 username systemd[1671]: tracker-miner-fs-3.service: Scheduled restart job, restart counter is at 5.
Apr 20 07:11:04 username systemd[1671]: Stopped Tracker file system data miner.
Apr 20 07:11:04 username systemd[1671]: tracker-miner-fs-3.service: Start request repeated too quickly.
Apr 20 07:11:04 username systemd[1671]: tracker-miner-fs-3.service: Failed with result 'exit-code'.
Apr 20 07:11:04 username systemd[1671]: Failed to start Tracker file system data miner.
@whatthe ok… then add this:
systemctl --user edit tracker-miner-fs-3.service
Add there (as explained in the commented text):
[Service]
Environment=G_MESSAGES_DEBUG=Tracker
and save it.
Run this in one terminal:
journalctl --user --follow --unit tracker-miner-fs-3.service
and at another terminal this:
systemctl --user restart tracker-miner-fs-3.service
More here: HACKING.md · master · GNOME / tracker · GitLab
Apr 20 09:35:20 username systemd[1671]: tracker-miner-fs-3.service: Failed with result 'exit-code'.
Apr 20 09:35:20 username systemd[1671]: Failed to start Tracker file system data miner.
Apr 20 09:35:20 username systemd[1671]: tracker-miner-fs-3.service: Scheduled restart job, restart counter is at 5.
Apr 20 09:35:20 username systemd[1671]: Stopped Tracker file system data miner.
Apr 20 09:35:20 username systemd[1671]: tracker-miner-fs-3.service: Start request repeated too quickly.
Apr 20 09:35:26 username systemd[1671]: tracker-miner-fs-3.service: Start request repeated too quickly.
Apr 20 09:35:26 username systemd[1671]: tracker-miner-fs-3.service: Failed with result 'exit-code'.
Apr 20 09:35:26 username systemd[1671]: Failed to start Tracker file system data miner.
Apr 20 11:40:37 username systemd[1671]: Starting Tracker file system data miner...
Apr 20 11:40:37 username tracker-miner-f[3382791]: Could not request DBus name 'org.freedesktop.Tracker3.Miner.Files': D-Bus service name:'org.freedesktop.Tracker3.Miner.Files' is already taken, perhaps the application is already running?
Apr 20 11:40:37 username systemd[1671]: tracker-miner-fs-3.service: Main process exited, code=exited, status=1/FAILURE
Apr 20 11:40:37 username systemd[1671]: tracker-miner-fs-3.service: Failed with result 'exit-code'.
Apr 20 11:40:37 username systemd[1671]: Failed to start Tracker file system data miner.
Apr 20 11:40:37 username systemd[1671]: tracker-miner-fs-3.service: Scheduled restart job, restart counter is at 1.
Apr 20 11:40:37 username systemd[1671]: Stopped Tracker file system data miner.
Apr 20 11:40:37 username tracker-miner-f[3382799]: Could not request DBus name 'org.freedesktop.Tracker3.Miner.Files': D-Bus service name:'org.freedesktop.Tracker3.Miner.Files' is already taken, perhaps the application is already running?
Apr 20 11:40:37 username systemd[1671]: tracker-miner-fs-3.service: Scheduled restart job, restart counter is at 2.
Apr 20 11:40:37 username tracker-miner-f[3382806]: Could not request DBus name 'org.freedesktop.Tracker3.Miner.Files': D-Bus service name:'org.freedesktop.Tracker3.Miner.Files' is already taken, perhaps the application is already running?
Apr 20 11:40:38 username systemd[1671]: tracker-miner-fs-3.service: Scheduled restart job, restart counter is at 3.
Apr 20 11:40:38 username systemd[1671]: Stopped Tracker file system data miner.
Apr 20 11:40:38 username systemd[1671]: Starting Tracker file system data miner...
Apr 20 11:40:38 username tracker-miner-f[3382813]: Could not request DBus name 'org.freedesktop.Tracker3.Miner.Files': D-Bus service name:'org.freedesktop.Tracker3.Miner.Files' is already taken, perhaps the application is already running?
Apr 20 11:40:38 username systemd[1671]: tracker-miner-fs-3.service: Main process exited, code=exited, status=1/FAILURE
Apr 20 11:40:38 username systemd[1671]: tracker-miner-fs-3.service: Failed with result 'exit-code'.
Apr 20 11:40:38 username systemd[1671]: Failed to start Tracker file system data miner.
Apr 20 11:40:38 username systemd[1671]: tracker-miner-fs-3.service: Scheduled restart job, restart counter is at 4.
Apr 20 11:40:38 username tracker-miner-f[3382820]: Could not request DBus name 'org.freedesktop.Tracker3.Miner.Files': D-Bus service name:'org.freedesktop.Tracker3.Miner.Files' is already taken, perhaps the application is already running?
Apr 20 11:40:38 username systemd[1671]: tracker-miner-fs-3.service: Scheduled restart job, restart counter is at 5.
Apr 20 11:40:38 username systemd[1671]: tracker-miner-fs-3.service: Start request repeated too quickly.
Job for tracker-miner-fs-3.service failed because the control process exited with error code.
See "systemctl --user status tracker-miner-fs-3.service" and "journalctl --user -xeu tracker-miner-fs-3.service" for details.
░░ Subject: A stop job for unit UNIT has finished
░░ A stop job for unit UNIT has finished.
░░ The job identifier is 3729 and the job result is done.
Apr 20 11:40:38 username systemd[1671]: tracker-miner-fs-3.service: Start request>
Apr 20 11:40:38 username systemd[1671]: tracker-miner-fs-3.service: Failed with r>
░░ Subject: Unit failed
░░ The unit UNIT has entered the 'failed' state with result 'exit-code'.
Apr 20 11:40:38 username systemd[1671]: Failed to start Tracker file system data >
░░ The job identifier is 3729 and the job result is failed.
So, another instance of tracker-miner-fs-3 is already running. So check your processes and which one starts it.
How can I check that?
ps -aux | grep tracker-miner-fs-3
journalctl --user --follow --unit dbus.service
user          1931  0.0  0.1 794956 18584 ?        SNl  Apr18   0:32 /usr/lib/tracker-miner-fs-3
user       3382773  0.0  0.1 105028 18884 pts/1    S+   11:40   0:00 journalctl --user --follow --unit tracker-miner-fs-3.service
user       3382831  0.0  0.1 105028 18936 pts/2    S+   11:40   0:00 journalctl --user -xeu tracker-miner-fs-3.service
user       3385245  0.0  0.0   7032  2588 pts/0    S+   12:07   0:00 grep --colour=auto tracker-miner-fs-3
Apr 20 12:05:29 username dbus-daemon[3385046]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.6.so.0: cannot open shared object file: No such file or directory
Apr 20 12:05:29 username org.freedesktop.thumbnails.Thumbnailer1[3385046]: Registered thumbnailer evince-thumbnailer -s %s %u %o
Apr 20 12:05:29 username org.freedesktop.thumbnails.Thumbnailer1[3385046]: Registered thumbnailer /usr/bin/gdk-pixbuf-thumbnailer -s %s %u %o
Apr 20 12:05:29 username org.freedesktop.thumbnails.Thumbnailer1[3385046]: Registered thumbnailer gsf-office-thumbnailer -i %i -o %o -s %s
Apr 20 12:05:29 username org.freedesktop.thumbnails.Thumbnailer1[3385046]: Registered thumbnailer ffmpegthumbnailer -i %i -o %o -s %s -f
Apr 20 12:05:29 username org.freedesktop.thumbnails.Thumbnailer1[3385046]: Registered thumbnailer heif-thumbnailer -s %s %i %o
Apr 20 12:05:29 username dbus-daemon[1708]: [session uid=1000 pid=1708] Successfully activated service 'org.freedesktop.thumbnails.Thumbnailer1'
Apr 20 12:07:28 username dbus-daemon[1708]: [session uid=1000 pid=1708] Failed to activate service 'org.freedesktop.Tracker3.Miner.Extract': timed out (service_start_timeout=120000ms)
See this, it is running:
Check this:
journalctl --user --boot 0 --unit dbus.service --grep "Tracker3"
Apr 18 14:04:57 username dbus-daemon[1708]: [session uid=1000 pid=1708] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.47' (uid=1000 pid=1931 comm="/usr/lib/tracker-miner-fs-3 ")
Apr 18 14:05:11 username dbus-daemon[1708]: [session uid=1000 pid=1708] Successfully activated service 'org.freedesktop.Tracker3.Miner.Extract'
Apr 18 21:11:24 username dbus-daemon[1708]: [session uid=1000 pid=1708] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.47' (uid=1000 pid=1931 comm="/usr/lib/tracker-miner-fs-3 ")
Apr 18 21:13:24 username dbus-daemon[1708]: [session uid=1000 pid=1708] Failed to activate service 'org.freedesktop.Tracker3.Miner.Extract': timed out (service_start_timeout=120000ms)
Apr 18 21:21:04 username dbus-daemon[1708]: [session uid=1000 pid=1708] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.47' (uid=1000 pid=1931 comm="/usr/lib/tracker-miner-fs-3 ")
Apr 18 21:23:04 username dbus-daemon[1708]: [session uid=1000 pid=1708] Failed to activate service 'org.freedesktop.Tracker3.Miner.Extract': timed out (service_start_timeout=120000ms)
Apr 19 19:37:16 username dbus-daemon[1708]: [session uid=1000 pid=1708] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.47' (uid=1000 pid=1931 comm="/usr/lib/tracker-miner-fs-3 ")
Apr 19 19:39:16 username dbus-daemon[1708]: [session uid=1000 pid=1708] Failed to activate service 'org.freedesktop.Tracker3.Miner.Extract': timed out (service_start_timeout=120000ms)
Apr 19 22:02:24 username dbus-daemon[1708]: [session uid=1000 pid=1708] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.47' (uid=1000 pid=1931 comm="/usr/lib/tracker-miner-fs-3 ")
Apr 19 22:04:24 username dbus-daemon[1708]: [session uid=1000 pid=1708] Failed to activate service 'org.freedesktop.Tracker3.Miner.Extract': timed out (service_start_timeout=120000ms)
Apr 19 22:08:51 username dbus-daemon[1708]: [session uid=1000 pid=1708] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.47' (uid=1000 pid=1931 comm="/usr/lib/tracker-miner-fs-3 ")
Apr 19 22:10:51 username dbus-daemon[1708]: [session uid=1000 pid=1708] Failed to activate service 'org.freedesktop.Tracker3.Miner.Extract': timed out (service_start_timeout=120000ms)
Apr 19 22:13:44 username dbus-daemon[1708]: [session uid=1000 pid=1708] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.47' (uid=1000 pid=1931 comm="/usr/lib/tracker-miner-fs-3 ")
Apr 19 22:15:44 username dbus-daemon[1708]: [session uid=1000 pid=1708] Failed to activate service 'org.freedesktop.Tracker3.Miner.Extract': timed out (service_start_timeout=120000ms)
Apr 19 22:18:52 username dbus-daemon[1708]: [session uid=1000 pid=1708] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.47' (uid=1000 pid=1931 comm="/usr/lib/tracker-miner-fs-3 ")
Apr 19 22:35:09 username dbus-daemon[1708]: [session uid=1000 pid=1708] Failed to activate service 'org.freedesktop.Tracker3.Miner.Extract': timed out (service_start_timeout=120000ms)
Apr 20 06:49:01 username dbus-daemon[1708]: [session uid=1000 pid=1708] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.47' (uid=1000 pid=1931 comm="/usr/lib/tracker-miner-fs-3 ")
Apr 20 06:51:01 username dbus-daemon[1708]: [session uid=1000 pid=1708] Failed to activate service 'org.freedesktop.Tracker3.Miner.Extract': timed out (service_start_timeout=120000ms)
Apr 20 06:51:19 username dbus-daemon[1708]: [session uid=1000 pid=1708] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.47' (uid=1000 pid=1931 comm="/usr/lib/tracker-miner-fs-3 ")
Apr 20 06:53:18 username dbus-daemon[1708]: [session uid=1000 pid=1708] Failed to activate service 'org.freedesktop.Tracker3.Miner.Extract': timed out (service_start_timeout=120000ms)
Apr 20 06:54:13 username dbus-daemon[1708]: [session uid=1000 pid=1708] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.47' (uid=1000 pid=1931 comm="/usr/lib/tracker-miner-fs-3 ")
Apr 20 06:56:13 username dbus-daemon[1708]: [session uid=1000 pid=1708] Failed to activate service 'org.freedesktop.Tracker3.Miner.Extract': timed out (service_start_timeout=120000ms)
Apr 20 07:07:34 username dbus-daemon[1708]: [session uid=1000 pid=1708] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.47' (uid=1000 pid=1931 comm="/usr/lib/tracker-miner-fs-3 ")
Apr 20 07:09:34 username dbus-daemon[1708]: [session uid=1000 pid=1708] Failed to activate service 'org.freedesktop.Tracker3.Miner.Extract': timed out (service_start_timeout=120000ms)
Apr 20 07:10:46 username dbus-daemon[1708]: [session uid=1000 pid=1708] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.47' (uid=1000 pid=1931 comm="/usr/lib/tracker-miner-fs-3 ")
Apr 20 07:12:46 username dbus-daemon[1708]: [session uid=1000 pid=1708] Failed to activate service 'org.freedesktop.Tracker3.Miner.Extract': timed out (service_start_timeout=120000ms)
Apr 20 07:13:04 username dbus-daemon[1708]: [session uid=1000 pid=1708] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.47' (uid=1000 pid=1931 comm="/usr/lib/tracker-miner-fs-3 ")
Apr 20 07:15:04 username dbus-daemon[1708]: [session uid=1000 pid=1708] Failed to activate service 'org.freedesktop.Tracker3.Miner.Extract': timed out (service_start_timeout=120000ms)
Apr 20 07:18:48 username dbus-daemon[1708]: [session uid=1000 pid=1708] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.47' (uid=1000 pid=1931 comm="/usr/lib/tracker-miner-fs-3 ")
Apr 20 07:20:48 username dbus-daemon[1708]: [session uid=1000 pid=1708] Failed to activate service 'org.freedesktop.Tracker3.Miner.Extract': timed out (service_start_timeout=120000ms)
Apr 20 08:05:30 username dbus-daemon[1708]: [session uid=1000 pid=1708] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.47' (uid=1000 pid=1931 comm="/usr/lib/tracker-miner-fs-3 ")
Apr 20 08:07:30 username dbus-daemon[1708]: [session uid=1000 pid=1708] Failed to activate service 'org.freedesktop.Tracker3.Miner.Extract': timed out (service_start_timeout=120000ms)
Apr 20 09:11:55 username dbus-daemon[1708]: [session uid=1000 pid=1708] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.47' (uid=1000 pid=1931 comm="/usr/lib/tracker-miner-fs-3 ")
Apr 20 09:13:55 username dbus-daemon[1708]: [session uid=1000 pid=1708] Failed to activate service 'org.freedesktop.Tracker3.Miner.Extract': timed out (service_start_timeout=120000ms)
Apr 20 09:49:20 username dbus-daemon[1708]: [session uid=1000 pid=1708] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.47' (uid=1000 pid=1931 comm="/usr/lib/tracker-miner-fs-3 ")
Apr 20 09:51:20 username dbus-daemon[1708]: [session uid=1000 pid=1708] Failed to activate service 'org.freedesktop.Tracker3.Miner.Extract': timed out (service_start_timeout=120000ms)
Apr 20 09:51:58 username dbus-daemon[1708]: [session uid=1000 pid=1708] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.47' (uid=1000 pid=1931 comm="/usr/lib/tracker-miner-fs-3 ")
Apr 20 09:53:58 username dbus-daemon[1708]: [session uid=1000 pid=1708] Failed to activate service 'org.freedesktop.Tracker3.Miner.Extract': timed out (service_start_timeout=120000ms)
Apr 20 10:51:12 username dbus-daemon[1708]: [session uid=1000 pid=1708] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.47' (uid=1000 pid=1931 comm="/usr/lib/tracker-miner-fs-3 ")
Apr 20 10:53:12 username dbus-daemon[1708]: [session uid=1000 pid=1708] Failed to activate service 'org.freedesktop.Tracker3.Miner.Extract': timed out (service_start_timeout=120000ms)
Apr 20 10:58:08 username dbus-daemon[1708]: [session uid=1000 pid=1708] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.47' (uid=1000 pid=1931 comm="/usr/lib/tracker-miner-fs-3 ")
Apr 20 11:00:08 username dbus-daemon[1708]: [session uid=1000 pid=1708] Failed to activate service 'org.freedesktop.Tracker3.Miner.Extract': timed out (service_start_timeout=120000ms)
Apr 20 11:02:07 username dbus-daemon[1708]: [session uid=1000 pid=1708] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.47' (uid=1000 pid=1931 comm="/usr/lib/tracker-miner-fs-3 ")
Apr 20 11:04:07 username dbus-daemon[1708]: [session uid=1000 pid=1708] Failed to activate service 'org.freedesktop.Tracker3.Miner.Extract': timed out (service_start_timeout=120000ms)
Apr 20 11:10:14 username dbus-daemon[1708]: [session uid=1000 pid=1708] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.47' (uid=1000 pid=1931 comm="/usr/lib/tracker-miner-fs-3 ")
Apr 20 11:12:14 username dbus-daemon[1708]: [session uid=1000 pid=1708] Failed to activate service 'org.freedesktop.Tracker3.Miner.Extract': timed out (service_start_timeout=120000ms)
Apr 20 11:23:05 username dbus-daemon[1708]: [session uid=1000 pid=1708] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.47' (uid=1000 pid=1931 comm="/usr/lib/tracker-miner-fs-3 ")
Apr 20 11:25:05 username dbus-daemon[1708]: [session uid=1000 pid=1708] Failed to activate service 'org.freedesktop.Tracker3.Miner.Extract': timed out (service_start_timeout=120000ms)
Apr 20 12:05:28 username dbus-daemon[1708]: [session uid=1000 pid=1708] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.47' (uid=1000 pid=1931 comm="/usr/lib/tracker-miner-fs-3 ")
systemctl --user list-unit-files --all "tracker*.service"
Thank you for your help, brother. You are very smart, and I respect your expertise highly. <3
UNIT FILE                          STATE    VENDOR PRESET
tracker-extract-3.service          disabled enabled
tracker-miner-fs-3.service         disabled enabled
tracker-miner-fs-control-3.service static   -
tracker-miner-rss-3.service        disabled enabled
tracker-writeback-3.service        static   -
tracker-xdg-portal-3.service       static   -
6 unit files listed.
pacman -Qi tracker3-miners
Version         : 3.3.0-1
Description     : Collection of data extractors for Tracker/Nepomuk
Architecture    : x86_64
URL             : https://wiki.gnome.org/Projects/Tracker
Licenses        : GPL
Groups          : gnome
Provides        : None
Depends On      : tracker3  gst-plugins-base-libs  exempi  libexif  libcue  libgrss  libgsf  libgxps  libiptcdata  libosinfo
                  poppler-glib  totem-plparser  giflib  libgexiv2  gupnp-dlna  upower  libseccomp  libnm
                  libtracker-sparql-3.0.so=0-64
Optional Deps   : None
Required By     : nautilus
Optional For    : None
Conflicts With  : None
Replaces        : None
Installed Size  : 3.52 MiB
Packager        : Jan Alexander Steffens (heftig) <heftig@archlinux.org>
Build Date      : Tue 22 Mar 2022 02:34:24 AM CET
Install Date    : Tue 19 Apr 2022 10:38:07 PM CEST
Install Reason  : Installed as a dependency for another package
Install Script  : No
Validated By    : Signature
ok well… maybe there is a real problem… with tracker-extract-3 with some files…
cd /usr/lib/
G_MESSAGES_DEBUG=Tracker ./tracker-extract-3
Whats the output?
Btw… just to be sure. Your system is updated, right?
Yes, my system is fully updated. The version of tracker3-miners is:
Version : 3.3.0-1
(tracker-extract-3:3388519): Tracker-DEBUG: 12:36:27.004: Removing GStreamer plugin 'video4linux2' from registry
(tracker-extract-3:3388519): Tracker-DEBUG: 12:36:27.004: Removing GStreamer plugin 'nvcodec' from registry
(tracker-extract-3:3388519): Tracker-CRITICAL **: 12:36:27.020: Could not connect to filesystem miner endpoint: no such table: http://tracker.api.gnome.org/ontology/v3/tracker#Video.nrl:Namespace
Remove the Index in ~/.cache/tracker and try again.
sudo systemctl --user restart tracker-miner-fs-3.service
Failed to connect to bus: No medium found
without sudo. It is a user service.
