failed to start manjaro after updating the system today
here the terminal output
[FAILED] failed to start tuptime scheduled execution
[FAILEd] failed to star tuptime service
But it also appears that you have installed 3rd party software (tuptime) that is failing .. though that is not necessarily the reason you cant boot .. it could simply be the last message you see.
So now the failings are :
mariadb, plex, containerd, docker, and tuptime.
So quite a few things.
Though nothing from the core system.
You say this was ‘after an update’ … did the update complete successfuly and without errors?
And … what is this image from? Did you try to boot some other way?
yes the update completed successfuly and without errors.
the problem is, i cn’t access the TTY.
If you cant boot even into something like runlevel 3 then you will probably need to use a live USB and chroot in. All of that covered in the link above.
allright, thank you
