Hello everyone
Today I reinstalled Manjaro KDE
Previously, all things were fine, but now I have a problem(AGAIN)
When I boot I see this error:
Failed to start Load/Save Screen Backlight Brightness of amdgpu_bl1.
And also my brightness is ALWAYS set to 100% after each boot which is so annoying
After that, I tried to start the service manually:
sudo systemctl start systemd-backlight@amdgpu_bl1.service
Job for systemd-backlight@amdgpu_bl1.service failed because the control process exited with error code.
See "systemctl status systemd-backlight@amdgpu_bl1.service" and "journalctl -xe" for details.
Then I checked the systemd:
â—Ź systemd-backlight@amdgpu_bl1.service - Load/Save Screen Backlight Brightness of amdgpu_bl1
Loaded: loaded (/usr/lib/systemd/system/systemd-backlight@.service; static)
Active: failed (Result: exit-code) since Wed 2020-12-09 17:01:57 +0330; 10s ago
Docs: man:systemd-backlight@.service(8)
Process: 2355 ExecStart=/usr/lib/systemd/systemd-backlight load amdgpu_bl1 (code=exited, status=1/FAILURE)
Main PID: 2355 (code=exited, status=1/FAILURE)
Dec 09 17:01:57 Mtn-Lap systemd[1]: Starting Load/Save Screen Backlight Brightness of amdgpu_bl1...
Dec 09 17:01:57 Mtn-Lap systemd-backlight[2355]: Requires a subsystem and sysname pair specifying a backlight device.
Dec 09 17:01:57 Mtn-Lap systemd[1]: systemd-backlight@amdgpu_bl1.service: Main process exited, code=exited, status=1/FAILURE
Dec 09 17:01:57 Mtn-Lap systemd[1]: systemd-backlight@amdgpu_bl1.service: Failed with result 'exit-code'.
Dec 09 17:01:57 Mtn-Lap systemd[1]: Failed to start Load/Save Screen Backlight Brightness of amdgpu_bl1.
Since I’m using a hybrid laptop(amd/nvidia) I decided to install optimus-switch-amd-sddm
Even after didn’t work
I also added acpi_backlight=vendor
to my grub, no luck
My specs:
System: Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2
wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec1xxx v: N/A serial: <superuser/root required>
Chassis: type: 10 serial: <superuser/root required>
Mobo: HP model: 87B1 v: 31.17 serial: <superuser/root required> UEFI: AMI v: F.02 date: 05/14/2020
Battery: ID-1: BAT0 charge: 28.5 Wh condition: 46.9/46.9 Wh (100%) volts: 11.1/11.6 model: Hewlett-Packard Primary
type: Li-ion serial: N/A status: Discharging cycles: 422
CPU: Info: 6-Core model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP arch: Zen rev: 1
L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 71897
Speed: 1984 MHz min/max: 1400/3000 MHz boost: enabled Core speeds (MHz): 1: 2144 2: 2081 3: 2218 4: 2211 5: 2420
6: 2420 7: 1383 8: 1383 9: 1383 10: 1383 11: 1383 12: 1382
Graphics: Device-1: NVIDIA TU117M vendor: Hewlett-Packard driver: N/A bus ID: 01:00.0 chip ID: 10de:1f99
Device-2: Advanced Micro Devices [AMD/ATI] Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel bus ID: 05:00.0
chip ID: 1002:1636
Device-3: Luxvisions Innotech Limited HP TrueVision HD Camera type: USB driver: uvcvideo bus ID: 3-3:3
chip ID: 30c9:0013 serial: 0001
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: amdgpu resolution: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: AMD RENOIR (DRM 3.39.0 5.9.11-3-MANJARO LLVM 11.0.0) v: 4.6 Mesa 20.2.3 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Hewlett-Packard
driver: N/A bus ID: 05:00.5 chip ID: 1022:15e2
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus ID: 05:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.9.11-3-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel
port: e000 bus ID: 02:00.0 chip ID: 10ec:8168
IF: eno1 state: down mac: b0:5c:da:42:34:3f
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard driver: rtw_8822ce
v: N/A port: d000 bus ID: 03:00.0 chip ID: 10ec:c822
IF: wlo1 state: up mac: 70:66:55:bb:04:b7
Device-3: Realtek 802.11ac WLAN Adapter type: USB driver: btusb bus ID: 1-4:3 chip ID: 0bda:b00c
serial: 00e04c000001
Drives: Local Storage: total: 476.94 GiB used: 7.38 GiB (1.5%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: KBG40ZNV512G KIOXIA size: 476.94 GiB speed: 31.6 Gb/s lanes: 4
serial: 306PEEC9PBV1 rev: HP00AE00 scheme: GPT
Partition: ID-1: / size: 275.15 GiB used: 7.35 GiB (2.7%) fs: ext4 dev: /dev/nvme0n1p4
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 48.1 C mobo: N/A gpu: amdgpu temp: 46.0 C
Info: Processes: 262 Uptime: 5m Memory: 7.21 GiB used: 1.26 GiB (17.4%) Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1046 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.08
