This is the error message i get on boot. I understand something went while trying to install some programs with conflicting dependencies but this is all i know for sure…
I have booted into my system with a Manjaro live USB and i understand that i need to fix something in the booting sequence, i have read topics from the forum and wiki about grub restore etc but i got lost in “chroot” paragraphs
i believe i need some guidance here…
this is the output from lsblk:
[manjaro@manjaro ~]$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop0 7:0 0 78.4M 1 loop /run/miso/sfs/livefs
loop1 7:1 0 568.8M 1 loop /run/miso/sfs/mhwdfs
loop2 7:2 0 1.3G 1 loop /run/miso/sfs/desktopfs
loop3 7:3 0 630.5M 1 loop /run/miso/sfs/rootfs
sda 8:0 0 119.2G 0 disk
├─sda1 8:1 0 7.8G 0 part
├─sda2 8:2 0 300M 0 part
└─sda3 8:3 0 111.1G 0 part
sdb 8:16 0 465.8G 0 disk
└─sdb1 8:17 0 465.8G 0 part /run/media/manjaro/f37e4928-67cb-484d-9176-0089
sdc 8:32 1 14.8G 0 disk /run/miso/bootmnt
├─sdc1 8:33 1 2.6G 0 part
└─sdc2 8:34 1 4M 0 part
sr0 11:0 1 1024M 0 rom
Yes i remember it was a nvidia package conflicting. Is there a solution to this?
I am trying to find out what exactly is my disks configuration and where is the /boot section installed in order to apply this solution wiki.manjaro.org/index.php?title=GRUB/Restore_the_GRUB_Bootloader
@vbakalis Well if it is nvidia, then i guess your gpu is not supported by version 390xx or 455xx, all other driver version have been removed due support end. There are a lot of problems with that and solutions on the forum. A grub reinstall will not help then.
I ve read the articles on the forum and i understand some of the situations you mentioned above. The thing i don’t get is if i have to uninstall something from my computer in order to make the boot sequence work again
Just to make sure i am not going to blow things up, as i am quite new using Linux…
I dont understand your last line
I am currently running on live iso and i am trying to fix my system so:
manjaro-chroot -a ( in order to change the apparent root directory )
How do i remove the nvidia drivers? because on lspci -v i see that already nouveau drivers are in use
1:00.0 VGA compatible controller: NVIDIA Corporation GM107 [GeForce GTX 750] (rev a2) (prog-if 00 [VGA controller])
Subsystem: Palit Microsystems Inc. Device 1381
Flags: bus master, fast devsel, latency 0, IRQ 33
Memory at f6000000 (32-bit, non-prefetchable) [size=16M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
Memory at f0000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000 [size=128]
Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities: <access denied>
Kernel driver in use: nouveau
Kernel modules: nouveau
I am sorry to ask so many questions but i am really trying to understand the root cause of this situation.
Please if possible some step by step guidance to resolve this
What drivers should i install for graphics?
You will have to reinstall mhwd completely and also delete your installed configs in /var/lib/mhwd/local/pci/ , then install the gpu driver again with the new config video-nvidia or similiar.
Did you run mhwd -li on your live-boot or after you manjaro-chrooted into your actual system? It looks to me like it was run from the live-boot, which doesn’t help.
I think both these are bad ideas, I learned that you can achieve the same, but in a cleaner way, with mhwd -r pci <driver-name> as was pointed out here to me.
In that situation I had to install those drivers again using mhwd -a pci <driver-name> and then delete them properly with the above command. mhwd -l gives you a list of compatible possible drivers I believe. mhwd -li -d gives detail information about currently installed ones. All of this and more is also explained in the link @megavolt provided above.
Is that enough to manjaro-chroot into your broken installation, or do you have any problems doing so? Can’t you also just boot normally and once you see the [FAILED] Failed to start Load Kernel Modules open the tty (Ctrl+Alt+F3) and do the changes from there?
