Failed to start Light Display Manager, seemingly because of NVIDIA driver?
Today my installation failed to boot Light Display Manager. After booting from a live USB and doing some reading through `/var/log/Xorg.0.log’, it seems to have been due to the proprietary NVIDIA driver I installed a while back failing to boot. Here’s the output of Xorg.0.log
[    60.112] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[    60.113]
X.Org X Server 1.20.11
[    60.113] Build Operating System: Linux Manjaro Linux
[    60.114] Current Operating System: Linux auran-optiplex990 5.10.42-1-MANJARO #1 SMP PREEMPT Thu Jun 3 14:37:11 UTC 2021 x86_64
[    60.114] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=cb22c1c4-889e-4069-ad69-504c36744ca1 rw noveau.modeset=0 quiet apparmor=1 security=apparmor resume=UUID=8f2ab4d5-48af-4184-93e8-d1d681d868e0 udev.log_priority=3
[    60.116] Build Date: 13 April 2021  04:11:08PM
[    60.116]
[    60.116] Current version of pixman: 0.40.0
[    60.117] 	Before reporting problems, check http://wiki.x.org
[    60.117] Markers: (--) probed, (**) from config file, (==) default setting,
[    60.128] (==) Log file: "/home/auran/.local/share/xorg/Xorg.0.log", Time: Tue Jun 15 16:40:40 2021
[    60.136] (==) Using config file: "/etc/X11/xorg.conf"
[    60.143] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    60.151] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    60.151] (==) ServerLayout "Layout0"
[    60.151] (**) |-->Screen "Screen0" (0)
[    60.151] (**) |   |-->Monitor "Monitor0"
[    60.151] (**) |   |-->Device "Device0"
[    60.151] (**) |   |-->GPUDevice "Device0"
[    60.151] (**) |-->Input Device "Keyboard0"
[    60.151] (**) |-->Input Device "Mouse0"
[    60.151] (==) Automatically adding devices
[    60.151] (==) Automatically enabling devices
[    60.151] (==) Automatically adding GPU devices
[    60.151] (==) Automatically binding GPU devices
[    60.151] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    60.151] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
[    60.151] 	Entry deleted from font path.
[    60.151] 	(Run 'mkfontdir' on "/usr/share/fonts/misc").
[    60.151] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[    60.151] 	(Run 'mkfontdir' on "/usr/share/fonts/TTF").
[    60.151] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[    60.151] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    60.151] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[    60.151] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[    60.151] (==) FontPath set to:
[    60.151] (==) ModulePath set to "/usr/lib/xorg/modules"
[    60.151] (**) Extension "COMPOSITE" is enabled
[    60.151] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[    60.151] (WW) Disabling Keyboard0
[    60.151] (WW) Disabling Mouse0
[    60.151] (II) Module ABI versions:
[    60.151] 	X.Org ANSI C Emulation: 0.4
[    60.151] 	X.Org Video Driver: 24.1
[    60.151] 	X.Org XInput driver : 24.1
[    60.151] 	X.Org Server Extension : 10.0
[    60.152] (++) using VT number 2
[    60.155] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[    60.155] (II) xfree86: Adding drm device (/dev/dri/card0)
[    60.156] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 10 paused 0
[    60.157] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[    60.157] (**) OutputClass "nvidia" setting /dev/dri/card0 as PrimaryGPU
[    60.158] (--) PCI:*(1@0:0:0) 10de:1287:19da:730b rev 161, Mem @ 0xdb000000/16777216, 0xd0000000/134217728, 0xd8000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/131072
[    60.158] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    60.158] (II) LoadModule: "glx"
[    60.158] (II) Loading /usr/lib/nvidia/xorg/libglx.so
[    60.158] (EE) Failed to load /usr/lib/nvidia/xorg/libglx.so: libnvidia-tls.so.390.143: cannot open shared object file: No such file or directory
[    60.158] (EE) Failed to load module "glx" (loader failed, 0)
[    60.158] (II) LoadModule: "nvidia"
[    60.158] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    60.158] (II) Module nvidia: vendor="NVIDIA Corporation"
[    60.158] 	compiled for 1.6.99.901, module version = 1.0.0
[    60.158] 	Module class: X.Org Video Driver
[    60.158] (II) NVIDIA dlloader X Driver  460.84  Wed May 26 20:07:09 UTC 2021
[    60.158] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    60.158] xf86EnableIOPorts: failed to set IOPL for I/O (Operation not permitted)
[    60.158] (II) systemd-logind: releasing fd for 226:0
[    60.159] (II) Loading sub module "fb"
[    60.159] (II) LoadModule: "fb"
[    60.159] (II) Loading /usr/lib/xorg/modules/libfb.so
[    60.159] (II) Module fb: vendor="X.Org Foundation"
[    60.159] 	compiled for 1.20.11, module version = 1.0.0
[    60.159] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    60.159] (II) Loading sub module "wfb"
[    60.159] (II) LoadModule: "wfb"
[    60.159] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    60.159] (II) Module wfb: vendor="X.Org Foundation"
[    60.159] (II) Loading sub module "ramdac"
[    60.159] (II) LoadModule: "ramdac"
[    60.159] (II) Module "ramdac" already built-in
[    60.160] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[    60.160] (EE) NVIDIA:     system's kernel log for additional error messages and
[    60.160] (EE) NVIDIA:     consult the NVIDIA README for details.
[    60.161] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[    60.161] (EE) NVIDIA:     system's kernel log for additional error messages and
[    60.161] (EE) NVIDIA:     consult the NVIDIA README for details.
[    60.162] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[    60.162] (EE) NVIDIA:     system's kernel log for additional error messages and
[    60.162] (EE) NVIDIA:     consult the NVIDIA README for details.
[    60.163] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[    60.163] (EE) NVIDIA:     system's kernel log for additional error messages and
[    60.163] (EE) NVIDIA:     consult the NVIDIA README for details.
[    60.163] (EE) No devices detected.
[    60.163] (EE)
Fatal server error:
[    60.163] (EE) no screens found(EE)
[    60.163] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[    60.163] (EE) Please also check the log file at "/home/auran/.local/share/xorg/Xorg.0.log" for additional information.
[    60.163] (EE)
[    60.176] (EE) Server terminated with error (1). Closing log file.
And here’s the output to inxi --admin --verbosity=7 --filter --no-host --width
I’m not too sure what I do from here, please advise.
  1. How did you install the nVidia driver exactly? Because I’m on:
    [ 3.996] (II) NVIDIA dlloader X Driver 465.31 Thu May 13 22:19:15 UTC 2021
    [ 3.996] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
    since the last update and you’re on:
    and your GeForce GT 730 is still supported by the 465.31 series.
  2. Have you tried booting into your fall-back kernel? (Ideally 5.4 LTS as you seem to be on 5.10 LTS)
:thinking:
