hskl
February 3, 2021, 9:44am
#1
Hi dear manjaro community, this is my first post in the forum so apologies in advance if i lack something.
When i startup light display driver fails to start and i am able to start the manager with tty using systemctl enable lightdm.service
and systemctl start lightdm.service
. Here is the errors on /var/log/Xorg.0.log :
[ 549.666] (EE) Failed to load module "intel" (module does not exist, 0)
[ 550.121] (II) Initializing extension MIT-SCREEN-SAVER
[ 550.615] (EE) libinput: DELL09A0:00 0488:121F Touchpad: Failed to create a device for /dev/input/mouse1
[ 550.615] (EE) PreInit returned 2 for "DELL09A0:00 0488:121F Touchpad"
I am using Dell Latitude 5410 with onboard graphics card (i7 10610U). I currently don’t have xf86-vide-intel installed because when i install the intel driver the display manager can start but my screen tears like when graphics card burns. (btw i only have fbdev and vesa installed)
Here is my inxi --admin --verbosity=7 --filter --no-host --width
result:
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=e91c4a07-b6bb-4df8-9fd5-e91556cb103c rw quiet apparmor=1
Desktop: i3 4.19 info: i3bar dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: Dell product: Latitude 5410 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 033T9K v: A00 serial: <filter> UEFI: Dell v: 1.3.2
date: 09/23/2020
ID-1: BAT0 charge: 43.4 Wh condition: 68.0/68.0 Wh (100%) volts: 15.7/15.2
model: BYD DELL 3PCVM0C type: Li-poly serial: <filter> status: Discharging
RAM: total: 15.24 GiB used: 1.48 GiB (9.7%)
Info: Quad Core model: Intel Core i7-10610U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
microcode: DE L2 cache: 8 MiB bogomips: 36812
Speed: 900 MHz min/max: 400/4900 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900 5: 900 6: 900 7: 900 8: 900
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep smx ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:9b41
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus ID: 1-6:2 chip ID: 0bda:565c serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: picom v: git-dac85 driver:
loaded: modesetting unloaded: fbdev,vesa alternate: intel display ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.3.3
direct render: Yes
Device-1: Intel vendor: Dell driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:02c8
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Intel Wireless-AC 9462 driver: iwlwifi v: kernel port: 3000
bus ID: 00:14.3 chip ID: 8086:02f0
Device-2: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: efa0 bus ID: 00:1f.6 chip ID: 8086:0d4e
IF: eno2 state: down mac: <filter>
IF-ID-1: wwp0s20f0u5 state: down mac: <filter>
Local Storage: total: 476.94 GiB used: 15.54 GiB (3.3%)
model: PC SN530 NVMe WDC 512GB size: 476.94 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 21112012
temp: 30.9 C
ID-1: / raw size: 476.64 GiB size: 468.16 GiB (98.22%)
used: 15.54 GiB (3.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: e91c4a07-b6bb-4df8-9fd5-e91556cb103c
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 74E9-E9D9
Message: No Unmounted partitions found.
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-6:2 info: Realtek Integrated_Webcam_HD type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 0bda:565c
serial: <filter>
Device-2: 1-8:3 info: Broadcom 58200 type: Smart Card driver: N/A
interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 0a5c:5842 serial: <filter>
Device-3: 1-10:4 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s chip ID: 8087:0026
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
Device-1: 2-5:2 info: Dell DW5820e L850-GL
type: Communication,CDC-Data,Abstract (modem) driver: cdc_acm,cdc_mbim
interfaces: 8 rev: 3.0 speed: 5 Gb/s chip ID: 413c:81d9 serial: <filter>
System Temperatures: cpu: 30.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 228 Uptime: 3m wakeups: 271 Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: pacman: 1071 lib: 280 Shell: Bash v: 5.1.0
running in: urxvtd inxi: 3.2.02
There is no xorg.conf created on my system but at the arch wiki page for xorg notes that /usr/share/X11/xorg.conf.d/ is enough.
Fabby
February 5, 2021, 1:22am
#2
Welcome to Manjaro!
Please read this:
When asking questions in the forum, it would be most helpful to all members if you provide some basic information. When you provide info from the terminal, usually from your logs, you have to format it so the content is easy to read. First copy and...
Reading time: 6 mins 🕑
Likes: 133 ❤
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width
would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU you have, …
Fabby
February 6, 2021, 8:44pm
#3
I’m not an intel nor lightdm user, but from your inxi
output I’d say you have to use:
hskl:
i915
instead of
hskl:
"intel"
Hi, I’m having the same problem. your problem solved?
here is inxi --admin --verbosity=7 --filter --no-host --width
output
Kernel: 5.11.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=680cd823-90c9-4992-a3a1-a6fc76b604dd ro quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4
Type: Desktop Mobo: ASUSTeK model: TUF B450-PRO GAMING v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 2807 date: 02/01/2021
Device-1: hid-34:88:5d:d7:7d:26-battery model: Keyboard K380 serial: N/A
charge: N/A status: Discharging
RAM: total: 15.61 GiB used: 5 GiB (32.0%)
Info: 6-Core model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: N/A microcode: 8701021
L2 cache: 3 MiB bogomips: 91070
Speed: 3855 MHz min/max: 2200/4939 MHz boost: enabled Core speeds (MHz):
1: 3855 2: 2119 3: 2195 4: 2196 5: 2060 6: 2196 7: 2196 8: 2196 9: 3664
10: 2191 11: 2137 12: 2196
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload
vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt xsaves
Device-1: NVIDIA GK208B [GeForce GT 710] vendor: Gigabyte driver: nouveau
v: kernel alternate: nvidia_drm,nvidia bus ID: 07:00.0 chip ID: 10de:128b
class ID: 0300
Display: x11 server: X.Org 1.20.10 driver: loaded: nouveau
unloaded: modesetting alternate: fbdev,nv,vesa display ID: :0.0 screens: 1
Monitor-1: HDMI-1 res: 1920x1080 hz: 75 dpi: 102
size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
OpenGL: renderer: NV106 v: 4.3 Mesa 20.3.4 direct render: Yes
Device-1: NVIDIA GK208 HDMI/DP Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 07:00.1 chip ID: 10de:0e0f class ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 09:00.4 chip ID: 1022:1487
class ID: 0403
Sound Server: ALSA v: k5.11.2-1-MANJARO
vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus ID: 04:00.0
chip ID: 10ec:8168 class ID: 0200
IF: enp4s0 state: down mac: <filter>
Device-2: Realtek RTL8192EE PCIe Wireless Network Adapter driver: rtl8192ee
v: kernel port: d000 bus ID: 05:00.0 chip ID: 10ec:818b class ID: 0280
IF: wlp5s0 state: up mac: <filter>
IF-ID-1: vpn0 state: up speed: 10 Mbps duplex: full mac: N/A
IP v6: <filter> virtual: stable-privacy scope: link
Device-1: Broadcom BCM20702 Bluetooth 4.0 [ThinkPad] type: USB driver: btusb
v: 0.8 bus ID: 1-10:4 chip ID: 0a5c:21e6 class ID: fe01 serial: <filter>
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 1.82 TiB used: 310.17 GiB (16.6%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Lexar model: 500GB SSD
size: 465.76 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: S0614B0 temp: 39.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Lexar model: 500GB SSD
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-22Z10T0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 1A01
ID-1: / raw size: 46.55 GiB size: 45.57 GiB (97.89%) used: 10.93 GiB (24.0%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:5 label: N/A
uuid: 680cd823-90c9-4992-a3a1-a6fc76b604dd
ID-2: /boot/efi raw size: 251 MiB size: 247.1 MiB (98.46%)
used: 298 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:4 label: N/A
uuid: F904-4D1C
ID-3: /home raw size: 413.38 GiB size: 405.89 GiB (98.19%)
used: 299.24 GiB (73.7%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:6
label: N/A uuid: 81e3c0bd-a2bc-453b-8f3e-72296a0d4563
ID-1: swap-1 type: partition size: 5.59 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p1 maj-min: 259:3 label: N/A
uuid: 878cd85c-e909-41d6-a690-1d09f0b5b98f
ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 465.76 GiB fs: ext4 label: N/A
uuid: 4e0a9b70-4155-413c-bc53-c4b111513120
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Device-1: 1-7:2 info: A4Tech USB Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
chip ID: 09da:c10a class ID: 0301
Hub-2: 1-8:3 info: Dell USB 2.0 Hub [MTT] ports: 4 rev: 2.0 speed: 480 Mb/s
chip ID: 413c:1010 class ID: 0900
Device-1: 1-8.4:5 info: Dell Dell Wired Multimedia Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s chip ID: 413c:2110 class ID: 0301
Device-2: 1-10:4 info: Broadcom BCM20702 Bluetooth 4.0 [ThinkPad]
type: Bluetooth driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003 class ID: 0900
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 45.5 C mobo: N/A gpu: nouveau temp: 45.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 2130
Processes: 337 Uptime: 2h 20m wakeups: 1 Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: pacman: 1239 lib: 387 flatpak: 0 Shell: Zsh v: 5.8
running in: xfce4-terminal inxi: 3.3.01
sometimes it’s okay and can start display manager sometimes it’s not
