I was using an unstable kernel for some reason and had to remove it because it became unsupported. However, I can now no longer boot into my system, it goes straight into emergency mode. I suspect this is an nVida driver issue from the xjournal entries, but I am not sure. I have tried:
Using manjaro-chroot on a USB to run a full system upgrade and update grub. This does not seem to help. update-grub returns:
Found linux image: /boot/vmlinuz-5.13-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.13-x86_64.img
Found initrd fallback image: /boot/initramfs-5.13-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.9-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.9-x86_64.img
Found initrd fallback image: /boot/initramfs-5.9-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.4-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.4-x86_64.img
Found initrd fallback image: /boot/initramfs-5.4-x86_64-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sdc1. Check your device.map.
done
Adding a new kernel using pacman. I currently have
[manjaro /]# mhwd-kernel -li
Currently running: 5.9.16-1-MANJARO (linux59)
* linux510
* linux54
But none of thoe show up in grub. I am unsure how to remove kernels - updating through mhwd does not work (no targets specified error when I def. have a valid kernel) so I can use the rmc option.
Reinstalling nvida drivers. Current output of mhwd is:
[manjaro /]# mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2021.12.18 false PCI
update-grub && mkinitcpio -p and ‘grub-mkconfig’ which both do not help
That is all the advice for this issue I have been able to find on the forum or could think of with my own knowledge.
When entering manjaro-chroot I get the error message
grub-probe: error: cannot fin a GRUB drive or /dev/sdc1. CHeck your devices.map.
grub-probe: error: cannot find a GRUB drive for /dev/sdc1. Check your devices.map.
==> mounting (ManjaroLinux) [/dev/sda2]
--> mount [/mnt]
--> mount [/mnt/boot/efi]
I am chrooting into /dev/sda2 which seems to be correct from a look at partitions. /dev/sdc is the USB itself, so I think this error is probably a red herring. For reference:
/dev/sda: My boot SSD
/dev/sdb: My storage drive
/dev/sdc: The recovery USB
I have followed the grub restoration with no change.
[manjaro /]# pacman -Syu grub
core is up to date
extra is up to date
community is up to date
multilib is up to date
warning: grub-2.06.r261.g2f4430cc0-1 is up to date -- reinstalling
resolving dependencies...
Packages (1) grub-2.06.r261.g2f4430cc0-1
Total Installed Size: 46.79 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [##################] 100%
(1/1) checking package integrity [##################] 100%
(1/1) loading package files [##################] 100%
(1/1) checking for file conflicts [##################] 100%
(1/1) checking available disk space [##################] 100%
(1/1) reinstalling grub [##################] 100%
:: Grub does no longer support side-loading modules when secure boot is
enabled. Thus booting will fail, unless you have an efi executable
'grubx64.efi' with bundled modules.
(1/2) Arming ConditionNeedsUpdate...
(2/2) Updating the info directory file...
[manjaro /]# grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
Installing for x86_64-efi platform.
Installation finished. No error reported.
[manjaro /]# grub-mkconfig -o /boot/grub/grub.cfg
done
you have there 2 eol kernels - 5.13 and 5.9, post output from: mhwd-kernel -li ls /etc/mkinitcpio.d/*.preset ls /boot/initramfs-* ls /boot/vmlinuz-* ls /usr/lib/modules/*
also how long did you not update your system?
Not that long, I had one out of date kernel (5.9) which I removed a few days after it became EOL, which is what caused this issue. I think I must have installed 5.13 while trying to fix it. Or I didn’t remove it properly, I’ve always dealt with kernels through the manjaro GUI out of laziness and the hope that that was safer. But I def. only 5.9 installed when there was a problem (which was dumb) and tried to replace it with the two most recent LTS ones.
I don’t suppose there’s any chance you could explain what went wrong/point me to some relevant resources so I can fix it myself if it ever happens again?
