Hi there.
To get some packages I decided to switch from stable branch to testing. It resulted in a big update including kernel.
After reboot, I’ve got the following output :
Failed to start Load Kernel Modules
Failed to mount /boot/EFI
Dependency failed for Local File systems
Trying to boot with another kernel is not helping.
I post in comments the outputs from a usb ISO.
manjaro is on a nvme disk
there is a windows install on a second ssd
$ inxi -Fza
Kernel: 5.15.25-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_XFCE_2124 quiet
systemd.show_status=1 apparmor=1 security=apparmor driver=free
nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: Precision 7520 v: N/A
Mobo: Dell model: 0P1FNM v: A00 serial: <superuser required> UEFI: Dell
v: 1.23.1 date: 12/15/2021
ID-1: BAT0 charge: 6.8 Wh (12.0%) condition: 56.7/72.0 Wh (78.7%)
volts: 11.6 min: 11.1 model: LGC-LGC3.23 DELL 1V0PP81 type: Li-ion
serial: <filter> status: Charging
Info: model: Intel Core i7-7820HQ bits: 64 type: MT MCP arch: Kaby Lake
family: 6 model-id: 0x9E (158) stepping: 9 microcode: 0xEC
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/3900 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 46419
Type: l1tf
Device-1: NVIDIA GM107GLM [Quadro M1200 Mobile] vendor: Dell
driver: nouveau v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max:
gen: 3 speed: 8 GT/s ports: active: eDP-1 empty: DP-1, DP-2, DP-3, VGA-1
bus-ID: 01:00.0 chip-ID: 10de:13b6 class-ID: 0300
Device-2: Realtek Integrated Webcam HD type: USB driver: uvcvideo
bus-ID: 1-11:5 chip-ID: 0bda:568c class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting alternate: fbdev,vesa gpu: nouveau display-ID: :0.0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 model: Chi Mei Innolux built: 2016 res: 1920x1080 hz: 60
dpi: 142 gamma: 1.2 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: max: 1920x1080 min: 800x600
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX] vendor: Dell
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fbc
class-ID: 0403
Sound Server-1: ALSA v: k5.15.25-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: no
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15e3 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd
class-ID: 0280
Local Storage: total: 718.67 GiB used: 0 KiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: PC401 NVMe 256GB size: 238.47 GiB block-size: physical: 512 B
rev: 80003E00 temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00WD
scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB model: USB Flash Memory
size: 14.44 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 1.00 scheme: MBR
Message: No partition data found.
System Temperatures: cpu: 52.0 C pch: 44.5 C mobo: N/A gpu: nouveau
temp: 53.0 C
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 237 Uptime: 9m wakeups: 1 Memory: 15.55 GiB
used: 1.82 GiB (11.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1151 lib: 319 flatpak: 0
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.13
$ sudo parted -l
Model: ATA WDC WDS500G2B0A (scsi)
Disk /dev/sda: 500GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 106MB 105MB fat32 EFI system partition boot, esp
2 106MB 123MB 16.8MB Microsoft reserved partition msftres
3 123MB 500GB 499GB ntfs Basic data partition msftdata
4 500GB 500GB 548MB ntfs hidden, diag
Model: USB Flash Memory (scsi)
Disk /dev/sdb: 15.5GB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
2 3529MB 3534MB 4194kB primary esp
Model: PC401 NVMe SK hynix 256GB (nvme)
Disk /dev/nvme0n1: 256GB
Disk Flags:
1 2097kB 317MB 315MB fat32 boot, esp
2 317MB 247GB 246GB ext4 root
3 247GB 256GB 9449MB linux-swap(v1) swap
chroot:
[manjaro /]# ls /boot/*
/boot/initramfs-5.15-x86_64-fallback.img /boot/intel-ucode.img
/boot/initramfs-5.15-x86_64.img /boot/linux515-x86_64.kver
/boot/initramfs-5.16-x86_64-fallback.img /boot/vmlinuz-5.15-x86_64
/boot/initramfs-5.16-x86_64.img /boot/vmlinuz-5.16-x86_64
/boot/efi:
EFI 'System Volume Information'
/boot/grub:
fonts grub.cfg grubenv locale themes x86_64-efi
/boot/memtest86+:
memtest.bin
/boot/efi:
/boot/grub:
/boot/memtest86+:
memtest.bin
mhwd-kernel -li
Currently running: 5.15.25-1-MANJARO (linux515)
* linux515
On a live session:
manjaro-chroot -a
mkinitcpio -P
update-grub
Check whats in:
cat /etc/fstab
on the local installation.
You can also use Maxi
to collect information about the boot process. This works,
when you are in your running system (with CTRL +ALT +F2 ).
And also in a live environment
If your manjaro installation does not boot (any more), maxi may help to find what is missing
mkinitcpio fails :
[manjaro /]# mkinitcpio -P
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
-> -k /boot/efi/bd658c047c1c4984a1ddc4ed19292840/5.15.32-1-MANJARO/linux -c /etc/mkinitcpio.conf -g /boot/efi/bd658c047c1c4984a1ddc4ed19292840/5.15.32-1-MANJARO/initrd
==> ERROR: Unable to write to path: `/boot/efi/bd658c047c1c4984a1ddc4ed19292840/5.15.32-1-MANJARO/initrd'
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
-> -k /boot/efi/bd658c047c1c4984a1ddc4ed19292840/5.15.32-1-MANJARO/linux -c /etc/mkinitcpio.conf -g /boot/efi/bd658c047c1c4984a1ddc4ed19292840/5.15.32-1-MANJARO/initrd-fallback -S autodetect
==> ERROR: Unable to write to path: `/boot/efi/bd658c047c1c4984a1ddc4ed19292840/5.15.32-1-MANJARO/initrd-fallback'
fstab :
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=510A-E9A5 /boot/efi vfat umask=0077 0 2
UUID=1781abd2-a9de-4743-ac2e-08f7bf3b128e / ext4 defaults,noatime 0 1
UUID=80f0b9e6-1c27-4ad7-aeed-e4283762e2f7 swap swap defaults,noatime 0 0
Well if the path does not exist, then it cannot write into it.
What do you use? grub or systemd-boot ?
By default it should look like this:
$ cat /etc/mkinitcpio.d/linux515.preset
# mkinitcpio preset file for the 'linux515' package
ALL_config="/etc/mkinitcpio.conf"
ALL_kver="/boot/vmlinuz-5.15-x86_64"
PRESETS=('default' 'fallback')
#default_config="/etc/mkinitcpio.conf"
default_image="/boot/initramfs-5.15-x86_64.img"
#default_options=""
#fallback_config="/etc/mkinitcpio.conf"
fallback_image="/boot/initramfs-5.15-x86_64-fallback.img"
fallback_options="-S autodetect"
Set the correct path.
I use grub.
linux515.preset looks the same as you.
I’m not sure how I should set the correct path
Please show it:
find /etc/mkinitcpio.d/ -name "*.preset" -exec echo -e "\n###\n{}\n###\n" \; -exec cat {} \;
Ok sorry, I made a mistake.
So I have made change to linux515.preset to make it looks like default.
But now I’ve go this error :
mkinitcpio -P
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
==> ERROR: '/lib/modules/5.15.28-1-MANJARO' is not a valid kernel module directory
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
pamac upgrade --force-refresh --enable-downgrade --overwrite "*" --no-aur
Whats in here?
find /boot/ -name "*.kver" -exec echo -e "\n###\n{}\n###\n" \; -exec cat {} \;
ls -la /lib/modules/
[manjaro /]# find /boot/ -name "*.kver" -exec echo -e "\n###\n{}\n###\n" \; -exec cat {} \;
5.15.32-1-MANJARO x64
[manjaro /]# ls -la /lib/modules/
total 232
drwxr-xr-x 4 root root 4096 Apr 12 17:45 .
drwxr-xr-x 247 root root 221184 Apr 12 15:25 ..
drwxr-xr-x 3 root root 4096 Apr 12 17:46 5.15.32-1-MANJARO
drwxr-xr-x 2 root root 4096 Apr 12 17:46 extramodules-5.15-MANJARO
pamac reinstall linux515 --overwrite "*"
Reinstall ok…
But again error :
why? Please check if systemd-boot is installed:
pamac list --installed | grep systemd-boot-manager
ls /usr/share/libalpm/hooks/sdboot*
There must be hook which changes the preset and other configs.
systemd-boot is not installed
[manjaro /]# ls /usr/share/libalpm/hooks/sdboot*
ls: cannot access '/usr/share/libalpm/hooks/sdboot*': No such file or directory
I’ve found /usr/share/libalpm/hooks/systemd-boot.hook
Ah well I guess this it…
$ LANG=C pamac search --files /usr/share/libalpm/hooks/systemd-boot.hook
/usr/share/libalpm/hooks/systemd-boot.hook is owned by systemd-kernel-maintenance
That package is clearly only for systemd-boot:
$ LANG=C pamac info systemd-kernel-maintenance
Version : 0.92-1
Description : Enables systemd-boot automation using kernel-install
URL : https://gitlab.com/fhdk/systemd-kernel-maintenance
Licenses : GPL2
Repository : community
Installed Size : 11.8 kB
Groups : --
Depends On : systemd
Optional Dependencies : --
Provides : --
Replaces : --
Conflicts With : --
Packager : fhdk <fh@manjaro.org>
Build Date : Wed Nov 3 06:48:04 2021
Validated By : MD5 Sum SHA-256 Sum Signature
So remove it:
pamac remove systemd-kernel-maintenance
and reinstall the kernel.
yeah, that’s it !
I can now successfully boot.
Thank you, I really appreciate your help !
system
Closed
15 April 2022 11:40
19
