the first time I installed Manjaro KDE Plasma using a USB and I hade no problems. but now whenever I boot into the usb I get this message
what is it? and what does it mean ? is it possible to fix without reinstalling ?
the system is working I have no problems with it . so should I be concerned ?
System: Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=3eb6f3ad-5767-4869-8316-44365a52609e rw quiet
apparmor=1 security=apparmor resume=UUID=3b69790b-e216-4ce0-ac38-d2f4d8d718f8 udev.log_priority=3
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: LENOVO product: 20RW v: Lenovo ThinkBook 15-IML serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: LENOVO model: LVA/LVAB v: NO DPK serial: <filter> UEFI: LENOVO v: CJCN29WW date: 06/19/2020
Battery: ID-1: BAT1 charge: 41.6 Wh condition: 44.5/45.0 Wh (99%) volts: 12.7/11.5 model: Celxpert L19C3PF1
type: Li-poly serial: <filter> status: Discharging cycles: 26
Memory: RAM: total: 3.36 GiB used: 1.55 GiB (46.0%)
CPU: Topology: Quad Core model: Intel Core i5-10210U bits: 64 type: MT MCP arch: Kaby Lake family: 6
model-id: 8E (142) stepping: C (12) microcode: D6 L2 cache: 6144 KiB bogomips: 33615
Speed: 800 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities arch_perfmon art avx avx2 bmi1
bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp
hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: srbds mitigation: TSX disabled
Graphics: Device-1: Intel UHD Graphics vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:9b41
Device-2: Acer SunplusIT Integrated Camera type: USB driver: uvcvideo bus ID: 1-6:3 chip ID: 5986:2113
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: intel display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.1.7 direct render: Yes
Audio: Device-1: Intel vendor: Lenovo driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus ID: 00:1f.3 chip ID: 8086:02c8
Sound Server: ALSA v: k5.8.6-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169 v: kernel
port: 3000 bus ID: 01:00.0 chip ID: 10ec:8168
IF: enp1s0 state: down mac: <filter>
Device-2: Realtek vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: 2000 bus ID: 02:00.0
chip ID: 10ec:c82f
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Drives: Local Storage: total: 931.51 GiB used: 10.45 GiB (1.1%)
ID-1: /dev/sda vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 0E scheme: GPT
RAID: Message: No RAID data was found.
Partition: ID-1: / raw size: 923.83 GiB size: 908.32 GiB (98.32%) used: 10.45 GiB (1.2%) fs: ext4 dev: /dev/sda2
label: N/A uuid: 3eb6f3ad-5767-4869-8316-44365a52609e
ID-2: /boot/efi raw size: 300.0 MiB size: 299.4 MiB (99.80%) used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1
label: N/A uuid: 120B-E6B6
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 7.39 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3 label: N/A
uuid: 3b69790b-e216-4ce0-ac38-d2f4d8d718f8
Unmounted: Message: No unmounted partitions found.
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-5:2 info: Shenzhen Goodix Goodix FingerPrint Device type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 480 Mb/s chip ID: 27c6:55a4
Device-2: 1-6:3 info: Acer SunplusIT Integrated Camera type: Video driver: uvcvideo interfaces: 2 rev: 2.0
speed: 480 Mb/s chip ID: 5986:2113
Device-3: 1-10:4 info: Realtek Bluetooth Radio type: Bluetooth driver: btusb interfaces: 2 rev: 1.0
speed: 12 Mb/s chip ID: 0bda:c02f serial: <filter>
Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 40.0 C mobo: N/A
Info: Processes: 221 Uptime: 3h 03m Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1196 lib: 321
flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
