Good afternoon,
Thank you all for your kind help in getting my system on track again. I have used Manjaro since 2020 on this PC. However three days ago during restart I got a message that system failed to system check on (probably) root device and went into emergency mode. I tried timeshift to restore previous image (but failed with same message). I tried reinstalling the Manjaro but still get the same message.
This is my system.
12class-ID 0701 12serial <filter>
12Device-4 1-8:5 12info Realtek RTS5129 Card Reader Controller
12type <vendor specific> 12driver rtsx_usb,rtsx_usb_ms,rtsx_usb_sdmmc
12interfaces 1 12rev 2.0 12speed 480 Mb/s 12power 500mA 12chip-ID 0bda:0129
12class-ID ff00 12serial <filter>
12Device-5 1-14:7 12info Qualcomm Atheros 12type Bluetooth 12driver btusb
12interfaces 2 12rev 1.1 12speed 12 Mb/s 12power 100mA 12chip-ID 0cf3:e005
12class-ID e001
12Hub-2 2-0:1 12info Super-speed hub 12ports 6 12rev 3.1 12speed 10 Gb/s
12chip-ID 1d6b:0003 12class-ID 0900
12Device-1 2-1:2 12info Seagate RSS LLC Expansion Portable 12type Mass Storage
12driver uas 12interfaces 1 12rev 3.0 12speed 5 Gb/s 12power 896mA 12chip-ID 0bc2:231a
12class-ID 0806 12serial <filter>
12Sensors:
12System Temperatures 12cpu 27.8 C 12pch 44.0 C 12mobo N/A
12Fan Speeds (RPM) 12cpu 988
12Info:
12Processes 226 12Uptime 38m 12wakeups 0 12Init systemd 12v 250 12tool systemctl
12Compilers 12gcc 11.2.0 12clang 13.0.1 12Packages 12pacman 1060 12lib 314 12flatpak 0
12Client Unknown Client: systemd 12inxi 3.3.15
[manjaro /]#
This is the system log
May 26 16:45:46 manjaro kernel: microcode: microcode updated early to revision >
May 26 16:45:46 manjaro kernel: Linux version 5.15.32-1-MANJARO (builduser@fv-a>
May 26 16:45:46 manjaro kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-x86_64 l>
May 26 16:45:46 manjaro kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 f>
May 26 16:45:46 manjaro kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE r>
May 26 16:45:46 manjaro kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX r>
May 26 16:45:46 manjaro kernel: x86/fpu: Supporting XSAVE feature 0x008: 'MPX b>
May 26 16:45:46 manjaro kernel: x86/fpu: Supporting XSAVE feature 0x010: 'MPX C>
May 26 16:45:46 manjaro kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2>
May 26 16:45:46 manjaro kernel: x86/fpu: xstate_offset[3]: 832, xstate_sizes[3>
May 26 16:45:46 manjaro kernel: x86/fpu: xstate_offset[4]: 896, xstate_sizes[4>
May 26 16:45:46 manjaro kernel: x86/fpu: Enabled xstate features 0x1f, context >
May 26 16:45:46 manjaro kernel: signal: max sigframe size: 2032
May 26 16:45:46 manjaro kernel: BIOS-provided physical RAM map:
May 26 16:45:46 manjaro kernel: BIOS-e820: [mem 0x0000000000000000-0x0000000000>
May 26 16:45:46 manjaro kernel: BIOS-e820: [mem 0x000000000009f000-0x0000000000>
May 26 16:45:46 manjaro kernel: BIOS-e820: [mem 0x0000000000100000-0x00000000a2>
May 26 16:45:46 manjaro kernel: BIOS-e820: [mem 0x00000000a2edd000-0x00000000a2>
May 26 16:45:46 manjaro kernel: BIOS-e820: [mem 0x00000000a2ede000-0x00000000a2>
May 26 16:45:46 manjaro kernel: BIOS-e820: [mem 0x00000000a2edf000-0x00000000b6>
May 26 16:45:46 manjaro kernel: BIOS-e820: [mem 0x00000000b6ac7000-0x00000000b9>
May 26 16:45:46 manjaro kernel: BIOS-e820: [mem 0x00000000b9e0a000-0x00000000b9>
May 26 16:45:46 manjaro kernel: BIOS-e820: [mem 0x00000000b9e87000-0x00000000ba>
lines 1-23
Check this file:
cat /etc/fstab
Could be a problem with the /home mount point there.
Both outputs are cut off. So nothing useful in there.
This is another error log.
4: inode 4727112
[ 2487.324952] audit: type=1106 audit(1653582388.514:150): pid=5977 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 2487.325052] audit: type=1104 audit(1653582388.514:151): pid=5977 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 2813.233065] audit: type=1101 audit(1653582714.420:152): pid=8677 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 2813.233582] audit: type=1110 audit(1653582714.420:153): pid=8677 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 2813.235694] audit: type=1105 audit(1653582714.424:154): pid=8677 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[manjaro@manjaro ~]$ fsck
fsck from util-linux 2.38
Many thanks for your help.
both your info in your first post are cut off, edit them properly first
and can you check in the live usb the smart status of your ssd, if you are using ssd
Thanks @megavolt . You are superquick!
[manjaro@manjaro ~]$ cat /etc/fstab
# /etc/fstab: static file system information
# <file system> <dir> <type> <options> <dump> <pass>
/dev/mapper/root-image / auto defaults 0 0
Sorry about that. This is the system information.
ID-3: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/nvme0n1p3 maj-min: 259:3 size: 45.66 GiB fs: ntfs label: OS
uuid: 72DE05B7DE05751F
ID-5: /dev/nvme0n1p4 maj-min: 259:4 size: 747 MiB fs: vfat label: N/A
uuid: D4A8-AF70
ID-6: /dev/nvme0n1p5 maj-min: 259:5 size: 478 MiB fs: ntfs
label: WINRETOOLS uuid: 2C5A7FD75A7F9BF0
ID-7: /dev/nvme0n1p6 maj-min: 259:6 size: 11.32 GiB fs: ntfs label: Image
uuid: 6480801C807FF342
ID-8: /dev/nvme0n1p7 maj-min: 259:7 size: 1.12 GiB fs: ntfs
label: DELLSUPPORT uuid: F036D1A536D16D5A
ID-9: /dev/nvme0n1p8 maj-min: 259:8 size: 512 MiB fs: vfat label: NO_LABEL
uuid: C8B4-B6B9
ID-10: /dev/nvme0n1p9 maj-min: 259:9 size: 2 GiB fs: swap label: N/A
uuid: df6fc0f6-4f14-49d7-a16c-e32399f23bfb
ID-11: /dev/sda1 maj-min: 8:1 size: 128 MiB fs: <superuser required>
ID-12: /dev/sda2 maj-min: 8:2 size: 120.84 GiB fs: ntfs label: DATA
uuid: DC2E10022E0FD484
ID-13: /dev/sda3 maj-min: 8:3 size: 692.85 GiB fs: ext4 label: N/A
uuid: 40d02bb2-72fe-4c7c-863e-8ffcf99baba6
ID-14: /dev/sda4 maj-min: 8:4 size: 39.57 GiB fs: swap label: N/A
uuid: b5f0b3dc-82e0-4f0f-a9dc-71a3525c0493
ID-15: /dev/sdb1 maj-min: 8:17 size: 200 MiB fs: vfat label: EFI
uuid: 67E3-17ED
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-5:2 info: Dell KB216 Wired Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 413c:2113 class-ID: 0300
Device-2: 1-6:3 info: Pixart Imaging Gaming Mouse type: Mouse,Keyboard
power: 100mA chip-ID: 093a:2533 class-ID: 0300
Device-3: 1-7:4 info: Brother Industries DCP-9015CDW type: Printer
driver: usblp interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 2mA
chip-ID: 04f9:03c0 class-ID: 0701 serial: <filter>
Device-4: 1-8:5 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-5: 1-14:7 info: Qualcomm Atheros type: Bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e005
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
Device-1: 2-1:2 info: Seagate RSS LLC Expansion Portable
type: Mass Storage driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 896mA chip-ID: 0bc2:231a class-ID: 0806 serial: <filter>
System Temperatures: cpu: 27.8 C pch: 44.0 C mobo: N/A
Fan Speeds (RPM): cpu: 989
Processes: 222 Uptime: 54m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1136 lib: 317
flatpak: 0 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.15
ash:
Puh encryption… if your are a novice at linux, then you will get extra headache.
Now we need this aswell:
cat /etc/cryptab
lsblk --fs
Thanks @megavolt . This is the output.
[manjaro@manjaro ~]$ inxi --admin --verbosity=7 --filter --width
Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us
tz=Europe/London misobasedir=manjaro misolabel=MANJARO_XFCE_2126 quiet
systemd.show_status=1 apparmor=1 security=apparmor driver=nonfree
nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Dell product: Inspiron 3670 v: N/A
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: Dell model: 0H4VK7 v: A01 serial: <superuser required> UEFI: Dell
v: 1.5.4 date: 08/02/2018
RAM: total: 7.59 GiB used: 3.57 GiB (47.0%)
RAM Report:
Info: model: Intel Core i3-8100 bits: 64 type: MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xB (11) microcode: 0xEC
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 800/3600 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 28808
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
STIBP: disabled, RSB filling
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Dell
driver: i915 v: kernel ports: active: HDMI-A-1 empty: DP-1 bus-ID: 00:02.0
chip-ID: 8086:3e91 class-ID: 0300
Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Dell driver: nvidia
v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1c82 class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
s-diag: 777mm (30.58")
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Lenovo LEN D32q-20B
serial: <filter> built: 2021 res: 2560x1440 hz: 60 dpi: 93 gamma: 1.2
size: 698x393mm (27.48x15.47") diag: 801mm (31.5") ratio: 16:9 modes:
max: 2560x1440 min: 720x400
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
Device-2: NVIDIA GP107GL High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb9
class-ID: 0403
Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Dell Vostro 3470 driver: ath9k v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 168c:0036 class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-14:7
chip-ID: 0cf3:e005 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 2.85 TiB used: 530.54 GiB (18.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KBG30ZMS128G NVMe 128GB size: 119.24 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter>
rev: ADDA0103 temp: 26.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
type: HDD rpm: 7200 serial: <filter> rev: CC45 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate model: Expansion
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 0710 scheme: GPT
Optical-1: /dev/sr0 vendor: PLDS model: DVD+-RW DU-8A5LH rev: 6D1M
dev-links: cdrom
Features: speed: 62 multisession: yes audio: yes dvd: yes
rw: cd-r,cd-rw,dvd-r state: running
ID-1: /run/media/manjaro/UNTITLED raw-size: 1.82 TiB
size: 1.82 TiB (100.00%) used: 530.54 GiB (28.5%) fs: exfat dev: /dev/sdb2
maj-min: 8:18 label: UNTITLED uuid: 5CF8-104A
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 650 MiB fs: vfat label: ESP
uuid: 94E0-E5AF
ID-2: /dev/nvme0n1p10 maj-min: 259:10 size: 56.68 GiB fs: ext4 label: N/A
uuid: b500b3bb-2490-44ac-88d4-2a7456738afb
uuid: D4A8-AF70
uuid: C8B4-B6B9
uuid: 67E3-17ED
class-ID: e001
[manjaro@manjaro ~]$ journalctl --boot=-1 --priority=3 --catalog
Specifying boot ID or boot offset has no effect, no persistent journal was found.
[manjaro@manjaro ~]$ journalctl --boot=-1 --unit=<service_name>
bash: syntax error near unexpected token `newline'
[manjaro@manjaro ~]$ cat /etc/cryptab
cat: /etc/cryptab: No such file or directory
[manjaro@manjaro ~]$ lsblk --fs
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0
squash 4.0 0 100% /run/miso/sfs/livefs
loop1
squash 4.0 0 100% /run/miso/sfs/mhwdfs
loop2
squash 4.0 0 100% /run/miso/sfs/desktopfs
loop3
squash 4.0 0 100% /run/miso/sfs/rootfs
sda
├─sda1
├─sda2
│ ntfs DATA DC2E10022E0FD484
├─sda3
│ ext4 1.0 40d02bb2-72fe-4c7c-863e-8ffcf99baba6
└─sda4
swap 1 b5f0b3dc-82e0-4f0f-a9dc-71a3525c0493
sdb
├─sdb1
│ vfat FAT32 EFI 67E3-17ED
└─sdb2
exfat 1.0 UNTITLED
5CF8-104A 1.3T 28% /run/media/manjaro/UNTITLED
sr0 iso966 Jolie MANJARO_XFCE_2126
2022-04-16-05-49-46-00 0 100% /run/miso/bootmnt
nvme0n1
├─nvme0n1p1
│ vfat FAT32 ESP 94E0-E5AF
├─nvme0n1p2
├─nvme0n1p3
│ ntfs OS 72DE05B7DE05751F
├─nvme0n1p4
│ vfat FAT32 D4A8-AF70
├─nvme0n1p5
│ ntfs WINRETOOLS
│ 2C5A7FD75A7F9BF0
├─nvme0n1p6
│ ntfs Image 6480801C807FF342
├─nvme0n1p7
│ ntfs DELLSUPPORT
│ F036D1A536D16D5A
├─nvme0n1p8
│ vfat FAT32 NO_LABEL
│ C8B4-B6B9
├─nvme0n1p9
│ swap 1 df6fc0f6-4f14-49d7-a16c-e32399f23bfb
└─nvme0n1p10
ext4 1.0 b500b3bb-2490-44ac-88d4-2a7456738afb
Ah wait it is the iso image
Which installation is it?
@megavolt , there was no encryption.
nvme0n1p8 is 512mb fat file for efi/boot.
sda3 is the /home
sda4 was previous swap that I forgot to delete in new installation.
However the problem arose before the new installation done today. So there was no issue with nvme0n1p9.
ah ok well… I assume you booted a live session.
Please chroot into the local installation:
sudo manjaro-choot -a
and check fstab again:
cat /etc/fstab
Thanks! I really need to learn the process behind the GUI.
[manjaro@manjaro ~]$ sudo manjaro-chroot -a
==> Mounting (ManjaroLinux) [/dev/nvme0n1p10]
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
--> mount: [/mnt/home]
[manjaro /]# cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=C8B4-B6B9 /boot/efi vfat umask=0077 0 2
UUID=df6fc0f6-4f14-49d7-a16c-e32399f23bfb swap swap defaults,noatime 0 0
UUID=b500b3bb-2490-44ac-88d4-2a7456738afb / ext4 defaults,noatime 0 1
UUID=40d02bb2-72fe-4c7c-863e-8ffcf99baba6 /home ext4 defaults,noatime 0 2
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
[manjaro /]#
Can you clarify this? You have done a new installation, but the problem of the dependency error was before the new installation?
looks pretty correct.
Yes. The issue happened three days ago. I don’t know what may have caused it. There was no update pending. I tried to boot live iso dvd, tried timeshift and restored snapshot from last week from my separate home folder. However the problem persisted.
I reinstalled Manjaro 2 days ago and once again today. However it persist. I did not change anything in windows. (In fact I don’t use windows on this PC). So I don’t think there should be any issue with that side.
Ok since fstab is fully correct, I would say it is a filesystem error, which could not be solved easily without manual action. Therefore…
Type exit to close the chroot.
Unmount home: sudo umount /mnt/home
Now do a file system check:
sudo fsck.ext4 -fy /dev/sda3
If it is a HDD, then also check for badblocks:
sudo fsck.ext4 -fcck /dev/sda3
but this will take time depending on the size of the partition.
This will also search for badblock on the disk.
Thanks @megavolt , There is one issue seen already.
[manjaro /]# exit
exit
--> umount: [/mnt/home]
--> umount: [/mnt/boot/efi]
--> umount: [/mnt]
[manjaro@manjaro ~]$ Unmount /home: sudo umount /mnt/home
bash: Unmount: command not found
[manjaro@manjaro ~]$ sudo umount /mnt/home
umount: /mnt/home: no mount point specified.
[manjaro@manjaro ~]$ sudo unmount /mnt/home
sudo: unmount: command not found
[manjaro@manjaro ~]$ sudo umount /home
umount: /home: not mounted.
[manjaro@manjaro ~]$ sudo fsck.ext4 -fy /dev/sda3
e2fsck 1.46.5 (30-Dec-2021)
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Missing '..' in directory inode 4727126.
Fix? yes
Pass 3: Checking directory connectivity
Unconnected directory inode 4727126 (/???)
Connect to /lost+found? yes
Pass 4: Checking reference counts
Inode 2 ref count is 4, should be 5. Fix? yes
Inode 4727126 ref count is 3, should be 2. Fix? yes
Inode 28845955 ref count is 5, should be 4. Fix? yes
Inode 28845956 ref count is 5, should be 4. Fix? yes
Inode 28845957 ref count is 5, should be 4. Fix? yes
Pass 5: Checking group summary information
/dev/sda3: ***** FILE SYSTEM WAS MODIFIED *****
/dev/sda3: 2272699/45408256 files (0.9% non-contiguous), 113720552/181627392 blocks
Thanks. Badblocks is going to take a lot of time. Only 2.5% done so far.
Kind regards.
Finally it is done! This is the output.
[manjaro /]# exit
exit
--> umount: [/mnt]
Fix? yes
[manjaro@manjaro ~]$ ^C
[manjaro@manjaro ~]$ sudo fsck.ext4 -fcck /dev/sda3
Checking for bad blocks (non-destructive read-write test)
Testing with random pattern: ^[[A^[[A 99.90% done, 14:01:43 elapsed. (0/0/0 errodone
/dev/sda3: Updating bad block inode.
[manjaro@manjaro ~]$ sudo fsck.ext4 -fy /dev/sda3^C
Seems like it has resolved the issue. I needed to restart the computer and now it has booted properly. It has even mounted the /home folder properly.
Thank you very much @megavolt , @brahma . It is much appreciated.
Is there any tutorial in how to learn basics about Linux and how to troubleshoot?
Kind regards to the Gurus!
system
Closed
29 May 2022 20:59
20
