Failed to start Authorization Manager
Hello, I am on KDE Plasma I updated my system with the latest stable updates earlier in the day and had no issues, I rebooted my system many times and experienced no problems after updating, now suddenly after gaming my system now gets the following errors:
Failed to start network time synchronization X8 Failed to start Avahi mDNS/DNS-SD Stack Failed to start Authorization manager Dependency failed for Modem Manager
And then it goes to a black screen.
I’ve since booted into a live USB and chrooted into my system
I heard it could be an issue with glibc so I attempted to update glibc
sudo pacman -S lib32-glibc
warning: lib32-glibc-2.41+r9+ga900dbaf70f0-1 is up to date -- reinstalling
resolving dependencies...
Packages (1) lib32-glibc-2.41+r9+ga900dbaf70f0-1
Total Installed Size:  18.35 MiB
Net Upgrade Size:       0.00 MiB
It says it’s up to date and then the update fails anyways
I attempted to just update my system
sudo pacman -Syu
error: failed to synchronize all databases (unexpected error)
I am not too sure what the issue could be does anybody have an idea?
See if refreshing the mirrors helps:
sudo pacman-mirrors --continent && sudo pacman -Syu
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO User generated mirror list
::INFO Custom mirror file saved: /var/lib/pacman-mirrors/custom-mirrors.json
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
  0.381 Canada         : https://mirror.csclub.uwaterloo.ca/manjaro/
  0.618 Canada         : https://mirror.xenyth.net/manjaro/
  0.405 Canada         : https://muug.ca/mirror/manjaro/
  0.779 Costa_Rica     : https://mirrors.ucr.ac.cr/manjaro/
  0.421 United_States  : http://mirror.fcix.net/manjaro/
  0.272 United_States  : https://nnenix.mm.fcix.net/manjaro/
  0.570 United_States  : https://ziply.mm.fcix.net/manjaro/
  0.201 United_States  : https://cofractal-ewr.mm.fcix.net/manjaro/
  0.501 United_States  : https://irltoolkit.mm.fcix.net/manjaro/
  0.568 United_States  : https://repo.ialab.dsu.edu/manjaro/
  0.743 United_States  : https://mirrors.ocf.berkeley.edu/manjaro/
  0.212 United_States  : https://mirror.math.princeton.edu/pub/manjaro/
  0.219 United_States  : https://mnvoip.mm.fcix.net/manjaro/
  0.140 United_States  : https://forksystems.mm.fcix.net/manjaro/
  0.468 United_States  : https://codingflyboy.mm.fcix.net/manjaro/
  0.212 United_States  : https://coresite.mm.fcix.net/manjaro/
  0.498 United_States  : https://ridgewireless.mm.fcix.net/manjaro/
  0.483 United_States  : https://opencolo.mm.fcix.net/manjaro/
  0.227 United_States  : https://southfront.mm.fcix.net/manjaro/
  0.310 United_States  : https://volico.mm.fcix.net/manjaro/
  0.190 United_States  : https://ohioix.mm.fcix.net/manjaro/
  0.655 United_States  : https://mirrors.sonic.net/manjaro/
  0.181 United_States  : https://mirrors.gigenet.com/manjaro/
  0.310 United_States  : https://nocix.mm.fcix.net/manjaro/
::INFO Writing mirror list
::United_States   : https://forksystems.mm.fcix.net/manjaro/stable
::United_States   : https://mirrors.gigenet.com/manjaro/stable
::United_States   : https://ohioix.mm.fcix.net/manjaro/stable
::United_States   : https://cofractal-ewr.mm.fcix.net/manjaro/stable
::United_States   : https://mirror.math.princeton.edu/pub/manjaro/stable
::United_States   : https://coresite.mm.fcix.net/manjaro/stable
::United_States   : https://mnvoip.mm.fcix.net/manjaro/stable
::United_States   : https://southfront.mm.fcix.net/manjaro/stable
::United_States   : https://nnenix.mm.fcix.net/manjaro/stable
::United_States   : https://volico.mm.fcix.net/manjaro/stable
::United_States   : https://nocix.mm.fcix.net/manjaro/stable
::Canada          : https://mirror.csclub.uwaterloo.ca/manjaro/stable
::Canada          : https://muug.ca/mirror/manjaro/stable
::United_States   : http://mirror.fcix.net/manjaro/stable
::United_States   : https://codingflyboy.mm.fcix.net/manjaro/stable
::United_States   : https://opencolo.mm.fcix.net/manjaro/stable
::United_States   : https://ridgewireless.mm.fcix.net/manjaro/stable
::United_States   : https://irltoolkit.mm.fcix.net/manjaro/stable
::United_States   : https://repo.ialab.dsu.edu/manjaro/stable
::United_States   : https://ziply.mm.fcix.net/manjaro/stable
::Canada          : https://mirror.xenyth.net/manjaro/stable
::United_States   : https://mirrors.sonic.net/manjaro/stable
::United_States   : https://mirrors.ocf.berkeley.edu/manjaro/stable
::Costa_Rica      : https://mirrors.ucr.ac.cr/manjaro/stable
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
Fails to synchronize all databases, I restarted to see if it made a difference and I still have the same errors.
Usually there is a message like “nothing to do”, with the obvious meaning. This suggests the update has completed, but it seems that something else has gone awry after that.
What that is might only be determined from the information you can provide. Please provide system information as described (below) and I’m sure someone will help when they are able.
I do seem to recall seeing a mention of lib32-glibc recently; perhaps in the Update announcement comments; but that might no longer be relevant.
A quick Internet search (Arch related) revealed similar issues for some after incorrectly merging .pacnew files; have you merged any very recently?
You might consider performing an update again - from within a chroot environment – this tutorial may be helpful;
Update Announcements:
System Information:
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Be prepared to provide more information and outputs from other commands whenever asked.
12System:
  12Kernel 5.13.19-2-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 11.1.0 12clocksource tsc
    12avail hpet,acpi_pm 12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_KDE_2116 quiet systemd.show_status=1 apparmor=1
    security=apparmor driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
  12Console N/A 12wm kwin_x11 12Distro Manjaro 12base Arch Linux
12Machine:
  12Type Desktop 12System ASUS 12product N/A 12v N/A 12serial N/A
  12Mobo ASUSTeK 12model PRIME H510M-K R2.0 12v Rev 1.xx 12serial <filter> 12part-nu SKU
    12uuid 0d8e535b-62a7-fd4b-52d3-cc28aa330321 12UEFI American Megatrends 12v 1001 12date 12/14/2023
12Battery:
  12Message No system battery data found. Is one present?
12Memory:
  12System RAM 12total 16 GiB 12available 15.53 GiB 12used 3.14 GiB (20.2%)
  12Array-1 12capacity 32 GiB 12slots 2 12modules 2 12EC None 12max-module-size 16 GiB 12note est.
  12Device-1 ChannelA-DIMM1 12type DDR4 12detail synchronous 12size 8 GiB 12speed 2133 MT/s 12volts 12curr 1.2
    12min 1.2 12max 1.2 12width (bits) 12data 64 12total 64 12manufacturer Corsair 12part-no CMK16GX4M2B3200C16
    12serial N/A
  12Device-2 ChannelB-DIMM1 12type DDR4 12detail synchronous 12size 8 GiB 12speed 2133 MT/s 12volts 12curr 1.2
    12serial N/A
12PCI Slots:
  12Slot 0 12type PCIe 12status in use 12length long 12volts 3.3 12bus-ID 01:01.0
  12Slot 1 12type PCIe 12status available 12length short 12volts 3.3 12bus-ID ff:1b.2
12CPU:
  12Info 12model Intel Core i7-10700F 12socket LGA1200 12bits 64 12type MT MCP 12arch Comet Lake 12gen core 10
    12level v3 12note check 12built 2020 12process Intel 14nm 12family 6 12model-id 0xA5 (165) 12stepping 5
    12microcode 0xF8
  12Topology 12cpus 1x 12dies 1 12cores 8 12threads 16 12tpc 2 12smt enabled 12cache 12L1 512 KiB
    12desc d-8x32 KiB; i-8x32 KiB 12L2 2 MiB 12desc 8x256 KiB 12L3 16 MiB 12desc 1x16 MiB
  12Speed (MHz) 12avg 2903 12min/max 800/4800 12base/boost 2871/8300 12scaling 12driver intel_pstate
    12governor powersave 12volts 0.9 V 12ext-clock 100 MHz 12cores 121 2903 122 2903 123 2903 124 2903 125 2903 126 2903
    127 2903 128 2903 129 2903 1210 2903 1211 2903 1212 2903 1213 2903 1214 2903 1215 2903 1216 2903 12bogomips 92838
  12Flags 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities arch_perfmon art
    avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de
    ds_cpl dtes64 dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht hwp
    hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single
    lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat
    pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
    rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc
    tsc_adjust tsc_deadline_timer vme x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  12Vulnerabilities
  12Type itlb_multihit 12status KVM: VMX unsupported
  12Type l1tf 12status Not affected
  12Type mds 12status Not affected
  12Type meltdown 12status Not affected
  12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via prctl and seccomp
  12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer sanitization
  12Type spectre_v2 12mitigation Enhanced IBRS, IBPB: conditional, RSB filling
  12Type srbds 12status Not affected
  12Type tsx_async_abort 12status Not affected
12Graphics:
  12Device-1 NVIDIA GA106 [GeForce RTX 3060] 12vendor Micro-Star MSI 12driver nvidia 12v 470.63.01
    12non-free 550/565.xx+ 12status current (as of 2025-01; EOL~2026-12-xx) 12arch Ampere 12code GAxxx
    12process TSMC n7 (7nm) 12built 2020-2023 12pcie 12gen 1 12speed 2.5 GT/s 12lanes 8 12link-max 12gen 4
    12speed 16 GT/s 12lanes 16 12bus-ID 01:00.0 12chip-ID 10de:2503 12class-ID 0300
  12Display 12server X.Org 12v 1.20.13 12with Xwayland 12v 24.1.6 12compositor kwin_x11 12driver 12X 12loaded N/A
    12failed nvidia 12gpu nvidia 12display-ID :0 12screens 1
  12Screen-1 0 12s-res 1920x1080 12s-dpi 92 12s-size 530x292mm (20.87x11.50") 12s-diag 605mm (23.82")
  12Monitor-1 HDMI-0 12res 12mode 1920x1080 12hz 60 12scale 100% (1) 12dpi 94 12size 521x293mm (20.51x11.54")
    12diag 598mm (23.53") 12modes N/A
  12API EGL 12v 1.5 12platforms 12gbm 12drv kms_swrast 12surfaceless 12drv swrast 12x11 12drv swrast
    12inactive wayland
  12API OpenGL 12v 4.5 12vendor mesa 12v 24.3.4-arch1.1 12note incomplete (EGL sourced) 12renderer llvmpipe
    (LLVM 19.1.7 256 bits)
  12API Vulkan 12Message No Vulkan data available.
  12Info 12Tools 12api clinfo, eglinfo, glxinfo, vulkaninfo 12de kscreen-console,kscreen-doctor
    12gpu nvidia-settings,nvidia-smi 12wl wayland-info 12x11 xdpyinfo, xprop, xrandr
12Audio:
  12Device-1 Intel Comet Lake PCH cAVS 12vendor ASUSTeK 12driver snd_hda_intel 12v kernel 12bus-ID 00:1f.3
    12chip-ID 8086:06c8 12class-ID 0403
  12Device-2 NVIDIA GA106 High Definition Audio 12vendor Micro-Star MSI 12driver snd_hda_intel 12v kernel
    12pcie 12gen 1 12speed 2.5 GT/s 12lanes 8 12link-max 12gen 4 12speed 16 GT/s 12lanes 16 12bus-ID 01:00.1
    12chip-ID 10de:228e 12class-ID 0403
  12Device-3 Razer USA RZ19-0229 Gaming Microphone 12driver hid-generic,snd-usb-audio,usbhid 12type USB
    12rev 1.1 12speed 12 Mb/s 12lanes 1 12mode 1.1 12bus-ID 1-3:2 12chip-ID 1532:0511 12class-ID 0300
    12serial <filter>
  12API ALSA 12v k5.13.19-2-MANJARO 12status kernel-api 12with aoss 12type oss-emulator
    12tools alsactl,alsamixer,amixer
  12Server-1 sndiod 12v N/A 12status off 12tools aucat,midicat,sndioctl
  12Server-2 PipeWire 12v 1.2.7 12status n/a (root, process) 12with 121 pipewire-pulse 12status off
    122 pipewire-media-session 12status active 123 pipewire-alsa 12type plugin 124 pw-jack 12type plugin
    12tools pactl,pw-cat,pw-cli
12Network:
  12Device-1 Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet 12vendor ASUSTeK RTL8111H
    12driver r8169 12v kernel 12pcie 12gen 1 12speed 2.5 GT/s 12lanes 1 12port 3000 12bus-ID 02:00.0
    12chip-ID 10ec:8168 12class-ID 0200
  12IF enp2s0 12state up 12speed 1000 Mbps 12duplex full 12mac <filter>
  12IP v4 <filter> 12type dynamic noprefixroute 12scope global 12broadcast <filter>
  12IP v6 <filter> 12type dynamic noprefixroute 12scope global
  12IP v6 <filter> 12type noprefixroute 12scope link
  12Info 12services mld,NetworkManager
  12WAN IP <filter>
12Bluetooth:
  12Message No bluetooth data found.
12Logical:
  12Message No logical block device data found.
12RAID:
  12Message No RAID data found.
12Drives:
  12Local Storage 12total 968.79 GiB 12used 611.13 GiB (63.1%)
  12ID-1 /dev/nvme0n1 12maj-min 259:0 12vendor Western Digital 12model PC SN530 SDBPNPZ-1T00-1032
    12size 953.87 GiB 12block-size 12physical 512 B 12logical 512 B 12speed 31.6 Gb/s 12lanes 4 12tech SSD
    12serial <filter> 12fw-rev 21111000 12temp 33.9 C
  12SMART yes 12health PASSED 12on 1y 202d 9h 12cycles 1,900 12read-units 239,588,767 [122 TB]
    12written-units 59,131,114 [30.2 TB]
  12ID-2 /dev/sda 12maj-min 8:0 12vendor Lexar 12model USB Flash Drive 12size 14.92 GiB 12block-size
    12physical 512 B 12logical 512 B 12type USB 12rev 2.0 12spd 480 Mb/s 12lanes 1 12mode 2.0 12tech SSD
    12serial <filter> 12fw-rev 8.07
  12SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
  12Message No optical or floppy data found.
12Partition:
  12ID-1 / 12raw-size 953.57 GiB 12size 937.53 GiB (98.32%) 12used 611.13 GiB (65.2%) 12fs ext4
    12block-size 4096 B 12dev /dev/nvme0n1p2 12maj-min 259:2 12label N/A
    12uuid 553d29ad-fd46-4bdd-ab3e-3f8eafcb8558
  12ID-2 /boot/efi 12raw-size 300 MiB 12size 299.4 MiB (99.80%) 12used 292 KiB (0.1%) 12fs vfat
    12block-size 512 B 12dev /dev/nvme0n1p1 12maj-min 259:1 12label NO_LABEL 12uuid 3958-21F3
12Swap:
  12Alert No swap data was found.
12Unmounted:
  12ID-1 /dev/sda1 12maj-min 8:1 12size 3.24 GiB 12fs N/A 12label MANJARO_KDE_2116
    12uuid 2021-10-17-17-41-15-00
  12ID-2 /dev/sda2 12maj-min 8:2 12size 4 MiB 12fs N/A 12label MISO_EFI 12uuid 99C0-51B6
12USB:
  12Hub-1 1-0:1 12info hi-speed hub with single TT 12ports 16 12rev 2.0 12speed 480 Mb/s (57.2 MiB/s) 12lanes 1
    12mode 2.0 12chip-ID 1d6b:0002 12class-ID 0900
  12Device-1 1-3:2 12info Razer USA RZ19-0229 Gaming Microphone 12type audio,HID
    12driver hid-generic,snd-usb-audio,usbhid 12interfaces 4 12rev 1.1 12speed 12 Mb/s (1.4 MiB/s) 12lanes 1
    12mode 1.1 12power 500mA 12chip-ID 1532:0511 12class-ID 0300 12serial <filter>
  12Device-2 1-4:3 12info Lexar Media JumpDrive V10 12type mass storage 12driver usb-storage 12interfaces 1
    12rev 2.0 12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0 12power 200mA 12chip-ID 05dc:c75c 12class-ID 0806
    12serial <filter>
  12Device-3 1-5:4 12info Razer USA BlackWidow Elite 12type keyboard,mouse 12driver hid-generic,usbhid
    12interfaces 3 12rev 2.0 12speed 12 Mb/s (1.4 MiB/s) 12lanes 1 12mode 1.1 12power 500mA 12chip-ID 1532:0228
    12class-ID 0300
  12Device-4 1-6:5 12info Logitech G MX518 Gaming Mouse (MU0053) 12type mouse,HID
    12driver hid-generic,usbhid 12interfaces 2 12rev 2.0 12speed 12 Mb/s (1.4 MiB/s) 12lanes 1 12mode 1.1
    12power 300mA 12chip-ID 046d:c08e 12class-ID 0300 12serial <filter>
  12Device-5 1-8:10 12info Nintendo Switch Pro Controller 12type HID 12driver hid-generic,usbhid
    12interfaces 1 12rev 2.0 12speed 12 Mb/s (1.4 MiB/s) 12lanes 1 12mode 1.1 12power 500mA 12chip-ID 057e:2009
  12Hub-2 2-0:1 12info super-speed hub 12ports 8 12rev 3.1 12speed 10 Gb/s (1.16 GiB/s) 12lanes 1
    12mode 3.2 gen-2x1 12chip-ID 1d6b:0003 12class-ID 0900
12Sensors:
  12System Temperatures 12cpu 33.0 C 12mobo N/A 12gpu nvidia 12temp 30 C
  12Fan Speeds (rpm) N/A 12gpu nvidia 12fan 36%
12Repos:
  12Packages 12pm pacman 12pkgs 1715 12libs 499 12tools pamac 12pm flatpak 12pkgs 0
  12Active pacman repo servers in /etc/pacman.d/mirrorlist
    121 https: //forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    122 https: //mirrors.gigenet.com/manjaro/stable/$repo/$arch
    123 https: //ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    124 https: //cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    125 https: //mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    126 https: //coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    127 https: //mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    128 https: //southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    129 https: //nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    1210 https: //volico.mm.fcix.net/manjaro/stable/$repo/$arch
    1211 https: //nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    1212 https: //mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    1213 https: //muug.ca/mirror/manjaro/stable/$repo/$arch
    1214 http: //mirror.fcix.net/manjaro/stable/$repo/$arch
    1215 https: //codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    1216 https: //opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    1217 https: //ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    1218 https: //irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    1219 https: //repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    1220 https: //ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    1221 https: //mirror.xenyth.net/manjaro/stable/$repo/$arch
    1222 https: //mirrors.sonic.net/manjaro/stable/$repo/$arch
    1223 https: //mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    1224 https: //mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
12Processes:
  12CPU top 5 of 360
  121 12cpu 14.8% 12command firefox 12pid 5462 12mem 457.7 MiB (2.8%)
  122 12cpu 5.8% 12command firefox 12pid 5719 12mem 239.5 MiB (1.5%)
  123 12cpu 5.2% 12command kwin_x11 12pid 4366 12mem 172.5 MiB (1.0%)
  124 12cpu 4.4% 12command Xorg 12pid 4293 12mem 65.2 MiB (0.4%)
  125 12cpu 3.7% 12command plasmashell 12pid 4417 12mem 337.4 MiB (2.1%)
  12Memory top 5 of 360
  121 12mem 457.7 MiB (2.8%) 12command firefox 12pid 5462 12cpu 14.8%
  122 12mem 337.4 MiB (2.1%) 12command plasmashell 12pid 4417 12cpu 3.7%
  123 12mem 239.5 MiB (1.5%) 12command firefox 12pid 5719 12cpu 5.8%
  124 12mem 172.5 MiB (1.0%) 12command kwin_x11 12pid 4366 12cpu 5.2%
  125 12mem 138.8 MiB (0.8%) 12command firefox 12pid 5570 12cpu 0.4%
12Info:
  12Processes 360 12Power 12uptime 4m 12states freeze,mem,disk 12suspend deep 12avail s2idle 12wakeups 0
    12hibernate platform 12avail shutdown, reboot, suspend, test_resume 12image 6.19 GiB
    12services org_kde_powerdevil,upowerd 12Init systemd 12v 257 12default graphical 12tool systemctl
  12Compilers 12clang 19.1.7 12gcc 14.2.1 12alt 13 12Client systemd 12inxi 3.3.37
You mentioned pacnew files I always try to be careful with these but I did overwrite some earlier I did not have any issues with rebooting after but this potentially could be it. Is there is a way to revert them back?
Not directly; but there may be ways to replace some of them with the default content.
To start with you might need to list those you merged; and perhaps post the current content of the files you merged them with.
From that point, we’ll see what others might suggest.
