Hello everyone!!!
Can anyone tell me why when i turning on my laptop and boots to manjaro shows me this error and how to solve it?
Thank you!!!
Update:
I think i found something here:[FAILED] failed to start pkgfile database update - #22 by ThalesMarcel
It is probably caused by a network timeout. I’ve had it happening here as well. You can however manually start it after booting…
sudo systemctl start pkgfile-update
OK i think you helped me a lot!!!
I will try it on command!!
Thank you!!!
Can i ask you something else?
How much hour it takes to complete?
Because im not seeing right now any action!!!
It shouldn’t take longer than a few seconds, and it runs in the background and then stops. It doesn’t run all the time. It is normally triggered by a timer.
Here what i got!!! It was stuck here for some reason!!!
Just wait a while for it to finish. It should normally finish pretty quickly.
