Failed to read AUR data
I am trying to rebuild Google Chrome as usual but I have this error:
% pamac build google-chrome
Warning: Building packages as dynamic user
Warning: Setting build directory to /var/cache/pamac
Failed to read AUR data from /var/tmp/pamac/packages-meta-ext-v1.json.gz : <data>:55267:169: Parse error: scanner: unterminated string constant
Error: target not found: google-chrome
How to build Google Chome ?
The problem seems to be more general:
% pamac update -a
Preparing...
Nothing to do.
I have tried % sudo curl -v -L -O https://aur.manjaro.org/packages-meta-ext-v1.json.gz, it works but does not help.
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
TL:DR
The complete recipe
sudo pacman-mirrors -aS unstable
sudo pacman -Syu base-devel --needed
git clone https://aur.archlinux.org/google-chrome
cd google-chrome
makepkg -i
No problems here. Have you tried:
pamac update --force-refresh
unfortunately the above does not help.
This will help; albeit, not the issue you’re having:
sudo pacman -S vivaldi
A chromium-based browser; Vivaldi is one of the better browsers you will ever use.
That is all. Cheers.
sudo pacman-mirrors -aS unstable … Yes it works. It looks like a full reinstall. Thus I updated Google Chrome from version 122 to 124. Thanks.
Then you didnt grasp what was actually happening.
You changed branches to Unstable and updated - with Stable branch being at least 6 weeks behind that meant you had upgrades for virtually every package.
(also why stable branch would not work well with AUR in the first place)
