Couple days back I got a message like thing in terminal when startup in XFCE.I am worried that it will affect my pc. This is what came when startup
/dev/sda2: clean, 1530405/60407808 files, 58378549/241610113 blocks
[FAILED] Failed to mount Mount unit for chromium-ffmpeg, revision 28.
[FAILED] Failed to mount Mount unit for core18, revision 2409.
[FAILED] Failed to mount Mount unit for gnome-3-28-1804, revision 161.
[FAILED] Failed to mount Mount unit for opera, revision 179.
[FAILED] Failed to mount Mount unit for opera, revision 180.
[FAILED] Failed to mount Mount unit for shotcut, revision 692.
[FAILED] Failed to mount Mount unit for snapd, revision 15904.
[FAILED] Failed to mount Mount unit for snapd, revision 16010.
[FAILED] Failed to mount Mount unit for spotify, revision 60.
[FAILED] Failed to mount Mount unit for teams, revision 7.
Kernel: 5.15.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=0822b13b-089c-4a9c-b669-5e4afa6c8657 rw quiet apparmor=1
security=apparmor resume=UUID=b9ece7d0-887f-41e2-ac29-8f8978127228
udev.log_priority=3
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: MSI product: MS-7817 v: 1.0
serial: <superuser required>
Mobo: MSI model: H81M-P33 (MS-7817) v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: 1.9 date: 03/30/2015
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
status: N/A
Info: model: Intel Pentium G3250 bits: 64 type: MCP arch: Haswell
built: 2013-15 process: Intel 22nm family: 6 model-id: 0x3C (60) stepping: 3
microcode: 0x28
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 3 MiB
desc: 1x3 MiB
Speed (MHz): avg: 3200 min/max: 800/3200 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 3200 2: 3200 bogomips: 12805
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Type: l1tf
STIBP: disabled, RSB filling
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Micro-Star MSI driver: i915 v: kernel arch: Gen5.75
process: Intel 45nm built: 2010 ports: active: none empty: HDMI-A-1,VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0402 class-ID: 0380
Device-2: NVIDIA GK208B [GeForce GT 710] vendor: Gigabyte driver: nvidia
v: 470.129.06 alternate: nouveau,nvidia_drm non-free: 470.xx+
status: legacy-active (EOL~2023/24) arch: Fermi 2 process: TSMC 28nm
built: 2010-16 pcie: gen: 2 speed: 5 GT/s lanes: 8 bus-ID: 01:00.0
chip-ID: 10de:128b class-ID: 0300
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-2.2:6 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver: X:
loaded: nvidia gpu: i915,nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1440x900 s-dpi: 96 s-size: 381x238mm (15.00x9.37")
s-diag: 449mm (17.69")
Monitor-1: DVI-I-1 res: 1440x900 hz: 60 dpi: 90
size: 408x255mm (16.06x10.04") diag: 481mm (18.94") modes: N/A
OpenGL: renderer: NVIDIA GeForce GT 710/PCIe/SSE2
v: 4.6.0 NVIDIA 470.129.06 direct render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 3-2.2:6
chip-ID: 046d:0825 bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0102
serial: <filter> class-ID: 0403
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8
bus-ID: 01:00.1 chip-ID: 10de:0e0f class-ID: 0403
Sound Server-1: ALSA v: k5.15.48-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.0 running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN Adapter type: USB
driver: rtl8188fu bus-ID: 3-9:5 chip-ID: 0bda:f179 class-ID: 0000
serial: <filter>
IF: wlp0s20u9 state: up mac: <filter>
IF-ID-1: enp0s20u7c4i2 state: down mac: <filter>
driver: btusb v: 0.8 bus-ID: 3-2.4:8 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 1.36 TiB used: 207.17 GiB (14.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
type: HDD rpm: 7200 serial: <filter> rev: CC46 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
model: WD5000BMVV-11A1CS0 size: 465.11 GiB block-size: physical: 512 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 1032 scheme: MBR
ID-1: / raw-size: 921.67 GiB size: 906.13 GiB (98.31%)
used: 207.17 GiB (22.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 300 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 9.55 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 39.0 C mobo: N/A gpu: nvidia temp: 49 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 46%
Processes: 184 Uptime: 30m wakeups: 8 Memory: 8.68 GiB
used: 1.59 GiB (18.3%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 1233 apt: 0
pacman: 1212 lib: 374 flatpak: 13 snap: 8 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.19
