Hi, I’m new using Manjaro. And I encountered this problem when I couldn’t open/mount my home partition (where my important documents are stored) after I updated. How do I fix it?
Please return the output of the following:
lsblk
blkid
cat /etc/fstab
[lucsumitro@luc-PC ~]$ lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS sda 8:0 0 465,8G 0 disk ├─sda1 8:1 0 2G 0 part /boot ├─sda2 8:2 0 8G 0 part [SWAP] ├─sda3 8:3 0 396,9G 0 part └─sda4 8:4 0 58,8G 0 part / sr0 11:0 1 1024M 0 rom [lucsumitro@luc-PC ~]$ blkid /dev/sda1: UUID="427cd502-f159-4da9-895c-36b176aed3b5" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="97be5b6a-01" /dev/sda2: UUID="fb5d5d02-1dac-4226-ba85-98294cc2b455" TYPE="swap" PARTUUID="97be5b6a-02" /dev/sda3: BLOCK_SIZE="512" UUID="01D66C6617243080" TYPE="ntfs" PARTUUID="97be5b6a-03" /dev/sda4: UUID="1b1106c1-7d02-4188-9866-bf666b4aa25c" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="97be5b6a-04" [lucsumitro@luc-PC ~]$ cat /etc/fstab # /etc/fstab: static file system information. # # Use 'blkid' to print the universally unique identifier for a device; this may # be used with UUID= as a more robust way to name devices that works even if # disks are added and removed. See fstab(5). # # <file system> <mount point> <type> <options> <dump> <pass> UUID=427cd502-f159-4da9-895c-36b176aed3b5 /boot ext4 defaults,noatime 0 2 UUID=fb5d5d02-1dac-4226-ba85-98294cc2b455 swap swap defaults,noatime 0 0 UUID=1b1106c1-7d02-4188-9866-bf666b4aa25c / ext4 defaults,noatime 0 1
So, I guess that is supposed to be /home/
I really would not suggest ntfs
as a linux partition … for a number of reasons … one of them being that the only reliable way to repair it is using windoze.
Which is what I would suggest at this point - attempt repair … but you would want to use windoze for that.
The other thing to mention might be what driver you are using for ntfs (ntfs-3g
Thank you for the suggestion. I’m relatively new using Manjaro, and I rarely explore it. I don’t know whether it is ntfs-3g or not, how do i check it?
The main thing would be to check for the package:
pacman -Qs ntfs
https://wiki.archlinux.org/title/NTFS
https://wiki.archlinux.org/title/NTFS-3G
(you may noticed that things changed recently and ntfs-3g was used to enable read/write of ntfs … whereas recent kernels are built with support from ntfs3
… but there have been numerous reports of problems using it with many choosing to continue using ntfs-3g for now)
Yes, it turns out it was installed. Should I change it and reinstall? or is there another alternative? . Forgive me, I’m really bad at this.
I suggest running some form of windoze and using chkdsk
or similar.
Note: Do Not Use tools like ntfsfix for linux.
They are not as capable as tools built for windoze (ntfs is a proprietary windoze filesystem), and can even be destructive to your data.
thank you
You could try to disable the kernel-internal ntfs3 driver by:
echo 'blacklist ntfs3' | sudo tee /etc/modprobe.d/disable-ntfs3.conf
sudo mkinitcpio -P
sudo update-grub
and reboot afterwards.
This partition doesn’t have a mount point. If this is your home partition you will need to create a mountpoint of /home
for it. If it is NTFS, as cscs suggests, and also vefied by blkid, then that’s not ideal; it needs to be a native Linux filesystem wherever possible.
thank you, it worked!
