Failed to load soundcard rules
So first of all yes, i did a GUI update for all my packages and now I’m having issues. Lets start of with the journalctl
   ~  journalctl --priority=warning..crit --no-pager --boot=0         ✔
mar 18 19:38:10 amd-burk kernel: hub 8-0:1.0: config failed, hub doesn't have any ports! (err -19)
mar 18 19:38:10 amd-burk kernel: sd 6:0:0:0: [sdc] No Caching mode page found
mar 18 19:38:10 amd-burk kernel: sd 6:0:0:0: [sdc] Assuming drive cache: write through
mar 18 19:38:11 amd-burk kernel: asus_wmi: failed to register LPS0 sleep handler in asus-wmi
mar 18 19:38:11 amd-burk kernel: No matching power limits found for this system
mar 18 19:38:11 amd-burk kernel: Could not initialise PPT tunable control 0
mar 18 19:38:11 amd-burk kernel: usb 5-2.2.1: Warning! Unlikely big volume range (=5120), cval->res is probably wrong.
mar 18 19:38:11 amd-burk kernel: usb 5-2.2.1: [5] FU [Microphone Capture Volume] ch = 1, val = -2560/2560/1
mar 18 19:38:11 amd-burk bluetoothd[753]: src/plugin.c:init_plugin() System does not support bap plugin
mar 18 19:38:11 amd-burk bluetoothd[753]: src/plugin.c:init_plugin() System does not support bass plugin
mar 18 19:38:11 amd-burk bluetoothd[753]: src/plugin.c:init_plugin() System does not support mcp plugin
mar 18 19:38:11 amd-burk bluetoothd[753]: src/plugin.c:init_plugin() System does not support vcp plugin
mar 18 19:38:11 amd-burk bluetoothd[753]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
mar 18 19:38:11 amd-burk bluetoothd[753]: src/plugin.c:init_plugin() System does not support micp plugin
mar 18 19:38:11 amd-burk bluetoothd[753]: src/plugin.c:init_plugin() System does not support ccp plugin
mar 18 19:38:11 amd-burk bluetoothd[753]: src/plugin.c:init_plugin() System does not support csip plugin
mar 18 19:38:11 amd-burk bluetoothd[753]: src/plugin.c:init_plugin() System does not support asha plugin
mar 18 19:38:40 amd-burk kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
mar 18 19:38:40 amd-burk kernel: usb 5-2.2.3.4.4: 3:0: failed to get current value for ch 0 (-22)
mar 18 19:38:40 amd-burk kernel: usb 5-2.2.3.4.4: 3:0: cannot get min/max values for control 2 (id 3)
mar 18 19:38:41 amd-burk (udev-worker)[565]: controlC2: /usr/lib/udev/rules.d/78-sound-card.rules:5 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:08.1/0000:0e:00.4/usb5/5-2/5-2.2/5-2.2.1/5-2.2.1:1.4/sound/card2/controlC2/../uevent}="change", ignoring: No such file or directory
mar 18 19:38:41 amd-burk (udev-worker)[589]: controlC2: /usr/lib/udev/rules.d/78-sound-card.rules:5 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:08.1/0000:0e:00.4/usb5/5-2/5-2.2/5-2.2.3/5-2.2.3.4/5-2.2.3.4.4/5-2.2.3.4.4:1.0/sound/card2/controlC2/../uevent}="change", ignoring: No such file or directory
mar 18 19:38:41 amd-burk sddm[843]: Could not setup default cursor
mar 18 19:38:41 amd-burk dbus-broker-launch[748]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
mar 18 19:38:41 amd-burk kernel: usb 5-2.2.1: Warning! Unlikely big volume range (=5120), cval->res is probably wrong.
mar 18 19:38:41 amd-burk kernel: usb 5-2.2.1: [5] FU [Microphone Capture Volume] ch = 1, val = -2560/2560/1
mar 18 19:38:41 amd-burk dbus-broker-launch[953]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
mar 18 19:38:41 amd-burk dbus-broker-launch[953]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
mar 18 19:38:41 amd-burk dbus-broker-launch[953]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
mar 18 19:38:42 amd-burk kernel: nvme nvme0: using unchecked data buffer
mar 18 19:38:42 amd-burk kernel: block nvme0n1: No UUID available providing old NGUID
mar 18 19:38:42 amd-burk NetworkManager[751]: <warn>  [1742323122.3785] device (wlp10s0): no secrets: No agents were available for this request.
mar 18 19:38:42 amd-burk NetworkManager[751]: <warn>  [1742323122.3786] device (wlp10s0): Activation: failed for connection 'The white box'
mar 18 19:38:42 amd-burk kded6[1161]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
mar 18 19:38:42 amd-burk kded6[1161]: QDBusObjectPath: invalid path "/modules/oom-notifier"
mar 18 19:38:42 amd-burk kded6[1161]: kf.dbusaddons: The kded module name "oom-notifier" is invalid!
mar 18 19:38:42 amd-burk kded6[1161]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
mar 18 19:38:42 amd-burk kded6[1161]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
mar 18 19:38:43 amd-burk kactivitymanagerd[1252]: kf.windowsystem: virtual void KX11Extras::connectNotify(const QMetaMethod&) may only be used on X11
mar 18 19:38:43 amd-burk plasmashell[1224]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth":
                                            file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:201:9
mar 18 19:38:43 amd-burk plasmashell[1224]: Toolbox not loading, toolbox package is either invalid or disabled.
mar 18 19:38:43 amd-burk baloo_file[981]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.24'
mar 18 19:38:43 amd-burk baloo_file[981]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.27'
mar 18 19:38:43 amd-burk backlighthelper[1416]: org.kde.powerdevil: no kernel backlight interface found
mar 18 19:38:43 amd-burk org_kde_powerdevil[1256]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
mar 18 19:38:43 amd-burk org_kde_powerdevil[1256]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
mar 18 19:38:45 amd-burk kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
mar 18 19:38:44 amd-burk org_kde_powerdevil[1256]: org.kde.powerdevil: Handle button events action could not check for screen configuration
mar 18 19:38:44 amd-burk org_kde_powerdevil[1256]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
mar 18 19:38:44 amd-burk DiscoverNotifier[1461]: couldn't load "/usr/lib/qt6/plugins/discover-notifier/DiscoverPackageKitNotifier.so" because "Cannot load library /usr/lib/qt6/plugins/discover-notifier/DiscoverPackageKitNotifier.so: libpackagekitqt6.so.1: cannot open shared object file: No such file or directory"
mar 18 19:38:44 amd-burk kdeconnectd[1441]: 2025-03-18T19:38:44 default: Error sending UDP packet: QAbstractSocket::NetworkError
mar 18 19:38:44 amd-burk kdeconnectd[1441]: 2025-03-18T19:38:44 kdeconnect.core: Failed to open any MDNS client sockets
mar 18 19:38:44 amd-burk kdeconnectd[1441]: 2025-03-18T19:38:44 kdeconnect.core: Failed to open any MDNS server sockets
mar 18 19:38:45 amd-burk corectrl[1439]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "&Yes" msgid_plural: "" msgctxt: "@action:button"
mar 18 19:38:45 amd-burk corectrl[1439]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "&No" msgid_plural: "" msgctxt: "@action:button"
mar 18 19:38:47 amd-burk bluetoothd[753]: src/profile.c:register_profile() :1.67 tried to register 0000111f-0000-1000-8000-00805f9b34fb which is already registered
mar 18 19:38:47 amd-burk pulseaudio[1142]: org.bluez.ProfileManager1.RegisterProfile() failed: org.bluez.Error.NotPermitted: UUID already registered
mar 18 19:38:47 amd-burk kconf_update[2277]: kf.config.kconf_update: /usr/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
mar 18 19:38:47 amd-burk kconf_update[2277]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
mar 18 19:38:47 amd-burk kconf_update[2277]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_detailsmodesettings.upd defined Version=5 but Version=6 was expected
mar 18 19:38:47 amd-burk kconf_update[2277]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_directorysizemode.upd defined Version=5 but Version=6 was expected
mar 18 19:38:47 amd-burk kconf_update[2277]: kf.config.kconf_update: /usr/share/kconf_update/konsole.upd defined Version=5 but Version=6 was expected
mar 18 19:38:47 amd-burk kconf_update[2277]: kf.config.kconf_update: /usr/share/kconf_update/okular.upd defined Version=5 but Version=6 was expected
mar 18 19:38:47 amd-burk plasmashell[2270]: QThreadStorage: Thread 0x5f2a4e255540 exited after QThreadStorage 8 destroyed
mar 18 19:38:47 amd-burk plasmashell[2274]: QThreadStorage: Thread 0x5b2973d62540 exited after QThreadStorage 8 destroyed
mar 18 19:38:47 amd-burk plasmashell[2270]: QThreadStorage: Thread 0x5f2a4e255540 exited after QThreadStorage 3 destroyed
mar 18 19:38:47 amd-burk plasmashell[2274]: QThreadStorage: Thread 0x5b2973d62540 exited after QThreadStorage 3 destroyed
mar 18 19:38:47 amd-burk plasmashell[2270]: QThreadStorage: Thread 0x5f2a4e255540 exited after QThreadStorage 2 destroyed
mar 18 19:38:47 amd-burk plasmashell[2274]: QThreadStorage: Thread 0x5b2973d62540 exited after QThreadStorage 2 destroyed
mar 18 19:38:47 amd-burk pulseaudio[1142]: Failed to open connection to session manager: None of the authentication protocols specified are supported
mar 18 19:38:47 amd-burk pulseaudio[1142]: Failed to load module "module-x11-xsmp" (argument: "display=:1 xauthority=/run/user/1000/xauth_DTuivF session_manager=local/amd-burk:@/tmp/.ICE-unix/1159,unix/amd-burk:/tmp/.ICE-unix/1159"): initialization failed.
mar 18 19:38:47 amd-burk systemd[914]: app-pulseaudio@autostart.service: Failed with result 'exit-code'.
mar 18 19:38:47 amd-burk kded6[1161]: kf.bluezqt: PendingCall Error: "The name is not activatable"
mar 18 19:38:47 amd-burk plasmashell[1224]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/main.qml:310:13: QML Image: Cannot open: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/application-menu
mar 18 19:38:47 amd-burk plasmashell[1224]: org.kde.applets.brightness: D-Bus action "KeyboardBrightnessControl" is not available at service "org.kde.Solid.PowerManagement"
mar 18 19:38:48 amd-burk kwalletmanager5[2382]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
mar 18 19:38:49 amd-burk dbus-broker-launch[748]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
mar 18 19:38:49 amd-burk kdeconnectd[1441]: 2025-03-18T19:38:49 kdeconnect.core: Failed to send mDNS query: Cannot assign requested address
mar 18 19:38:51 amd-burk bluetoothd[753]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Operation already in progress
mar 18 19:38:52 amd-burk xdg-desktop-por[991]: Realtime error: Could not get pidns: Could not fstatat ns/pid: Not a directory
mar 18 19:38:52 amd-burk systemd-coredump[3569]: [🡕] Process 3567 (gldriverquery) of user 1000 dumped core.
                                                 Stack trace of thread 3567:
                                                 #0  0x00000000ef169579 __kernel_vsyscall (linux-gate.so.1 + 0x579)
                                                 #1  0x00000000eef5e71f n/a (libc.so.6 + 0x9471f)
                                                 #2  0x00000000eef032c7 raise (libc.so.6 + 0x392c7)
                                                 #3  0x00000000eeeea1f2 abort (libc.so.6 + 0x201f2)
                                                 #4  0x00000000ef10c858 n/a (libSDL2-2.0.so.0 + 0xf858)
                                                 #5  0x00000000ef1701cb n/a (ld-linux.so.2 + 0x51cb)
                                                 #6  0x00000000ef1702ab n/a (ld-linux.so.2 + 0x52ab)
                                                 #7  0x00000000ef186a60 n/a (ld-linux.so.2 + 0x1ba60)
                                                 ELF object binary architecture: Intel 80386
mar 18 19:38:54 amd-burk kwin_wayland[982]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
mar 18 19:38:55 amd-burk kwin_wayland[982]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
mar 18 19:38:56 amd-burk plasmashell[1224]: org.kde.plasma.taskmanager: applications:com.discordapp.Discord.desktop: Progress value -100 is out of bounds!
mar 18 19:38:57 amd-burk kwin_wayland[982]: kwin_core: Cannot grant a token to KWin::ClientConnection(0x558c30d48230)
mar 18 19:40:30 amd-burk plasmashell[1224]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/items/PlasmoidItem.qml:24: TypeError: Cannot read property 'toolTipMainText' of null
mar 18 19:43:40 amd-burk plasmashell[1224]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/items/PlasmoidItem.qml:24: TypeError: Cannot read property 'toolTipMainText' of null
mar 18 19:43:55 amd-burk kwin_wayland[982]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsupported buffer GL_BACK_LEFT)
mar 18 19:44:46 amd-burk bluetoothd[753]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
mar 18 19:47:14 amd-burk plasmashell[1224]: qt.qml.signalhandler: Property 'onPressed' of object QQuickMouseArea_QML_173(0x55f08a42a5d0) is a signal handler. You should not call it directly. Make it a proper function and call that or emit the signal.
mar 18 19:47:15 amd-burk plasmashell[1224]: kf.plasma.quick: location should be set before showing popup window
mar 18 19:47:17 amd-burk bluetoothd[753]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
mar 18 19:48:02 amd-burk bluetoothd[753]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
mar 18 19:48:25 amd-burk plasmashell[1224]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/items/PlasmoidItem.qml:24: TypeError: Cannot read property 'toolTipMainText' of null
mar 18 19:48:50 amd-burk pulseaudio[1142]: Failed to create sink input: sink is suspended.
mar 18 19:48:56 amd-burk kwin_wayland[982]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
mar 18 19:49:03 amd-burk kwin_wayland[982]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsupported buffer GL_BACK_LEFT)
mar 18 19:49:27 amd-burk systemsettings[6534]: qrc:/kcm/kcm_pulseaudio/DeviceListItem.qml:181:9: QML MuteButton: Binding loop detected for property "muted":
                                               qrc:/kcm/kcm_pulseaudio/DeviceListItem.qml:184:13
mar 18 19:49:28 amd-burk systemsettings[6534]: qrc:/kcm/kcm_pulseaudio/DeviceListItem.qml:181:9: QML MuteButton: Binding loop detected for property "muted":
mar 18 19:49:42 amd-burk vlc[6843]: uint DBusMenuExporterDBus::GetLayout(int, int, const QStringList&, DBusMenuLayoutItem&): Condition failed: menu
mar 18 19:49:42 amd-burk plasmashell[1224]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/items/PlasmoidItem.qml:24: TypeError: Cannot read property 'toolTipMainText' of null
Well :frowning_face: errors and in the audio sound card rules… ****
Next inix
    ~  inxi -Farz         ✔
  Kernel: 6.12.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=650fe6ed-2034-479f-9ce2-081f608ce8fc rw quiet
    cryptdevice=UUID=e92b8294-fad6-4d8f-bc1b-9b7b507b8a07:luks-e92b8294-fad6-4d8f-bc1b-9b7b507b8a07
    root=/dev/mapper/luks-e92b8294-fad6-4d8f-bc1b-9b7b507b8a07 splash
    udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
  Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.11.0
  Mobo: ASUSTeK model: ROG STRIX B650E-F GAMING WIFI v: Rev 1.xx
    UEFI: American Megatrends v: 1616 date: 05/16/2023
  Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 4
    level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
    model-id: 0x61 (97) stepping: 2 microcode: 0xA601209
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 2988 min/max: 400/5573 boost: enabled scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 2988 2: 2988 3: 2988
    4: 2988 5: 2988 6: 2988 7: 2988 8: 2988 9: 2988 10: 2988 11: 2988 12: 2988
    13: 2988 14: 2988 15: 2988 16: 2988 bogomips: 144056
    conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
    BHI: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT
    / 6900 XT] driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: DP-3 empty: DP-1, DP-2, HDMI-A-1, Writeback-1
    bus-ID: 03:00.0 chip-ID: 1002:73bf class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: ASUSTeK
    driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
    empty: DP-4,HDMI-A-2,Writeback-2 bus-ID: 0e:00.0 chip-ID: 1002:164e
    class-ID: 0300 temp: 33.0 C
  Device-3: Lenovo Performance Camera driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2.2.1:13
    chip-ID: 17ef:4839 class-ID: 0102 serial: <filter>
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: DP-3 model: Samsung LS49A950U serial: <filter> built: 2021 res:
    mode: 5120x1440 hz: 60 scale: 100% (1) dpi: 82 gamma: 1.2
    size: 1192x336mm (46.93x13.23") diag: 1238mm (48.8") modes: max: 5120x1440
    min: 720x400
    device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: radeonsi
    surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6900 XT (radeonsi
    navi21 LLVM 19.1.7 DRM 3.61 6.12.19-1-MANJARO) device-ID: 1002:73bf
    memory: 15.62 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.304 layers: 4 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6900 XT (RADV NAVI21) driver: N/A device-ID: 1002:73bf
    surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: N/A device-ID: 1002:164e
    de: kscreen-console,kscreen-doctor gpu: corectrl wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
    bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
    Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0e:00.1 chip-ID: 1002:1640
    class-ID: 0403
  Device-3: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2
    chip-ID: 0b05:1a52 class-ID: 0300
  Device-4: Lenovo Performance Camera driver: snd-usb-audio,uvcvideo
  Device-5: Texas Instruments PCM2902 Audio Codec
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 5-2.2.3.4.4:20 chip-ID: 08bb:2902
    class-ID: 0300
  API: ALSA v: k6.12.19-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.1 status: active with: wireplumber
    status: active tools: pw-cat,pw-cli,wpctl
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
  Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 09:00.0 chip-ID: 8086:15f3
    class-ID: 0200
  Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 0a:00.0 chip-ID: 14c3:0608
    class-ID: 0280
  IF: wlp10s0 state: up mac: <filter>
  Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:5 chip-ID: 0e8d:0608
  Local Storage: total: 5.46 TiB used: 742.62 GiB (13.3%)
    model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 111130WD temp: 33.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM001-1CH164
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC27 scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HTS541010A9E680
    tech: HDD rpm: 5400 serial: <filter> fw-rev: A560 scheme: MBR
  ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital
    model: WD20EZRX-00DC0B0 size: 1.82 TiB block-size: physical: 512 B
    logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0
    tech: N/A serial: <filter> fw-rev: 2021 scheme: MBR
  ID-1: / raw-size: 931.21 GiB size: 915.52 GiB (98.32%)
    used: 324.57 GiB (35.5%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-e92b8294-fad6-4d8f-bc1b-9b7b507b8a07
    used: 448 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 49.9 C mobo: 38.0 C
  Fan Speeds (rpm): N/A
  GPU: device: amdgpu temp: 34.0 C device: amdgpu temp: 35.0 C mem: 36.0 C
    fan: 0 watts: 17.00
  Packages: 1566 pm: pacman pkgs: 1542 libs: 460 tools: pamac pm: appimage
    pkgs: 0 pm: flatpak pkgs: 24
    1: https://mirrors2.manjaro.org/stable/$repo/$arch
    2: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    3: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    4: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    5: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    6: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    7: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    8: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
  Memory: total: 32 GiB note: est. available: 30.5 GiB used: 7.42 GiB (24.3%)
  Processes: 441 Power: uptime: 21m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.18 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.37 running-in: konsole inxi: 3.3.37
Lastly my usb dac is found through the alsactl info command but I can’t seem to find my bluetooth headset eventhough kde plasma is showing me that it is connected.
Just tried booting in the 6.6 kernel and i’m getting the same issue :frowning:
mar 18 20:11:05 amd-burk kernel: acpi PNP0C14:03: duplicate WMI GUID 97845ED0-4E6D-11DE-8A39-0800200C9A66 (first instance was on PNP0C14:00)
mar 18 20:11:05 amd-burk kernel: hub 8-0:1.0: config failed, hub doesn't have any ports! (err -19)
mar 18 20:11:05 amd-burk kernel: sd 6:0:0:0: [sdc] No Caching mode page found
mar 18 20:11:05 amd-burk kernel: sd 6:0:0:0: [sdc] Assuming drive cache: write through
mar 18 20:11:05 amd-burk kernel: systemd[1]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
mar 18 20:11:05 amd-burk kernel: asus_wmi: Failed to get WMI notify code: AE_NOT_FOUND
mar 18 20:11:05 amd-burk kernel: asus_wmi: Failed to get event during flush: -5
mar 18 20:11:13 amd-burk kernel: usb 5-2.2.1: 5:1: cannot set freq 16000 to ep 0x83
mar 18 20:11:13 amd-burk kernel: usb 5-2.2.1: 5:4: cannot get min/max values for control 2 (id 5)
mar 18 20:11:13 amd-burk kernel: usb 5-2.2.1: Failed to query (GET_INFO) UVC control 2 on unit 3: -19 (exp. 1).
mar 18 20:11:13 amd-burk kernel: usb 5-2.2.1: Failed to query (GET_INFO) UVC control 3 on unit 3: -19 (exp. 1).
mar 18 20:11:13 amd-burk kernel: usb 5-2.2.1: Failed to query (GET_INFO) UVC control 6 on unit 3: -19 (exp. 1).
mar 18 20:11:13 amd-burk kernel: usb 5-2.2.1: Failed to query (GET_INFO) UVC control 7 on unit 3: -19 (exp. 1).
mar 18 20:11:13 amd-burk kernel: usb 5-2.2.1: Failed to query (GET_INFO) UVC control 8 on unit 3: -19 (exp. 1).
mar 18 20:11:13 amd-burk kernel: usb 5-2.2.1: Failed to query (GET_INFO) UVC control 9 on unit 3: -19 (exp. 1).
mar 18 20:11:13 amd-burk kernel: usb 5-2.2.1: Failed to query (GET_INFO) UVC control 10 on unit 3: -19 (exp. 1).
mar 18 20:11:13 amd-burk kernel: usb 5-2.2.1: Failed to query (GET_INFO) UVC control 1 on unit 3: -19 (exp. 1).
mar 18 20:11:13 amd-burk kernel: usb 5-2.2.1: Failed to query (GET_INFO) UVC control 5 on unit 3: -19 (exp. 1).
mar 18 20:11:13 amd-burk kernel: usb 5-2.2.1: Failed to query (GET_INFO) UVC control 11 on unit 3: -19 (exp. 1).
mar 18 20:11:13 amd-burk kernel: usb 5-2.2.1: Failed to query (GET_INFO) UVC control 2 on unit 1: -19 (exp. 1).
mar 18 20:11:13 amd-burk kernel: usb 5-2.2.1: Failed to query (GET_INFO) UVC control 4 on unit 1: -19 (exp. 1).
mar 18 20:11:13 amd-burk kernel: usb 5-2.2.1: Failed to query (GET_INFO) UVC control 11 on unit 1: -19 (exp. 1).
mar 18 20:11:13 amd-burk kernel: usb 5-2.2.1: Failed to query (GET_INFO) UVC control 13 on unit 1: -19 (exp. 1).
mar 18 20:11:13 amd-burk kernel: uvcvideo 5-2.2.1:1.1: Failed to query (129) UVC probe control : -19 (exp. 26).
mar 18 20:11:13 amd-burk kernel: uvcvideo 5-2.2.1:1.1: Failed to initialize the device (-5).
mar 18 20:11:13 amd-burk kernel: uvcvideo 5-2.2.1:1.3: Failed to query (129) UVC probe control : -19 (exp. 26).
mar 18 20:11:13 amd-burk kernel: uvcvideo 5-2.2.1:1.3: Failed to initialize the device (-5).
mar 18 20:11:13 amd-burk kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
mar 18 20:11:13 amd-burk kernel: usb 5-2.2.3.4.4: 3:0: failed to get current value for ch 0 (-22)
mar 18 20:11:13 amd-burk kernel: usb 5-2.2.3.4.4: 3:0: cannot get min/max values for control 2 (id 3)
mar 18 20:11:06 amd-burk bluetoothd[733]: src/plugin.c:init_plugin() System does not support bap plugin
mar 18 20:11:06 amd-burk bluetoothd[733]: src/plugin.c:init_plugin() System does not support bass plugin
mar 18 20:11:06 amd-burk bluetoothd[733]: src/plugin.c:init_plugin() System does not support mcp plugin
mar 18 20:11:06 amd-burk bluetoothd[733]: src/plugin.c:init_plugin() System does not support vcp plugin
mar 18 20:11:06 amd-burk bluetoothd[733]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
mar 18 20:11:06 amd-burk bluetoothd[733]: src/plugin.c:init_plugin() System does not support micp plugin
mar 18 20:11:06 amd-burk bluetoothd[733]: src/plugin.c:init_plugin() System does not support ccp plugin
mar 18 20:11:06 amd-burk bluetoothd[733]: src/plugin.c:init_plugin() System does not support csip plugin
mar 18 20:11:06 amd-burk bluetoothd[733]: src/plugin.c:init_plugin() System does not support asha plugin
mar 18 20:11:14 amd-burk (udev-worker)[547]: controlC0: /usr/lib/udev/rules.d/78-sound-card.rules:5 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:08.1/0000:0e:00.4/usb5/5-2/5-2.2/5-2.2.1/5-2.2.1:1.4/sound/card0/controlC0/../uevent}="change", ignoring: No such file or directory
mar 18 20:11:14 amd-burk (udev-worker)[567]: controlC0: /usr/lib/udev/rules.d/78-sound-card.rules:5 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:08.1/0000:0e:00.4/usb5/5-2/5-2.2/5-2.2.3/5-2.2.3.4/5-2.2.3.4.4/5-2.2.3.4.4:1.0/sound/card0/controlC0/../uevent}="change", ignoring: Filen eller katalogen finns inte
mar 18 20:11:14 amd-burk sddm[831]: Could not setup default cursor
mar 18 20:11:14 amd-burk dbus-broker-launch[729]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
mar 18 20:11:14 amd-burk NetworkManager[731]: <warn>  [1742325074.7387] device (wlp10s0): no secrets: No agents were available for this request.
mar 18 20:11:14 amd-burk NetworkManager[731]: <warn>  [1742325074.7388] device (wlp10s0): Activation: failed for connection 'The white box'
mar 18 20:11:15 amd-burk kernel: usb 5-2.2.1: Warning! Unlikely big volume range (=5120), cval->res is probably wrong.
mar 18 20:11:15 amd-burk kernel: usb 5-2.2.1: [5] FU [Microphone Capture Volume] ch = 1, val = -2560/2560/1
mar 18 20:11:15 amd-burk dbus-broker-launch[946]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
mar 18 20:11:15 amd-burk dbus-broker-launch[946]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
mar 18 20:11:15 amd-burk dbus-broker-launch[946]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
mar 18 20:11:15 amd-burk kernel: block nvme0n1: No UUID available providing old NGUID
mar 18 20:11:16 amd-burk kded6[1159]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
mar 18 20:11:16 amd-burk kded6[1159]: QDBusObjectPath: invalid path "/modules/oom-notifier"
mar 18 20:11:16 amd-burk kded6[1159]: kf.dbusaddons: The kded module name "oom-notifier" is invalid!
mar 18 20:11:16 amd-burk kded6[1159]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
mar 18 20:11:16 amd-burk kded6[1159]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
mar 18 20:11:16 amd-burk kactivitymanagerd[1239]: kf.windowsystem: virtual void KX11Extras::connectNotify(const QMetaMethod&) may only be used on X11
mar 18 20:11:16 amd-burk plasmashell[1209]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth":
mar 18 20:11:16 amd-burk plasmashell[1209]: Toolbox not loading, toolbox package is either invalid or disabled.
mar 18 20:11:17 amd-burk baloo_file[964]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.24'
mar 18 20:11:17 amd-burk baloo_file[964]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.28'
mar 18 20:11:17 amd-burk backlighthelper[1397]: org.kde.powerdevil: no kernel backlight interface found
mar 18 20:11:17 amd-burk org_kde_powerdevil[1243]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
mar 18 20:11:17 amd-burk org_kde_powerdevil[1243]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
mar 18 20:11:17 amd-burk org_kde_powerdevil[1243]: org.kde.powerdevil: Handle button events action could not check for screen configuration
mar 18 20:11:19 amd-burk kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
mar 18 20:11:17 amd-burk DiscoverNotifier[1452]: couldn't load "/usr/lib/qt6/plugins/discover-notifier/DiscoverPackageKitNotifier.so" because "Cannot load library /usr/lib/qt6/plugins/discover-notifier/DiscoverPackageKitNotifier.so: libpackagekitqt6.so.1: cannot open shared object file: No such file or directory"
mar 18 20:11:17 amd-burk kdeconnectd[1420]: 2025-03-18T20:11:17 default: Error sending UDP packet: QAbstractSocket::NetworkError
mar 18 20:11:17 amd-burk kdeconnectd[1420]: 2025-03-18T20:11:17 kdeconnect.core: Failed to open any MDNS client sockets
mar 18 20:11:17 amd-burk kdeconnectd[1420]: 2025-03-18T20:11:17 kdeconnect.core: Failed to open any MDNS server sockets
mar 18 20:11:18 amd-burk corectrl[1417]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "&Yes" msgid_plural: "" msgctxt: "@action:button"
mar 18 20:11:18 amd-burk corectrl[1417]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "&No" msgid_plural: "" msgctxt: "@action:button"
mar 18 20:11:20 amd-burk bluetoothd[733]: src/profile.c:register_profile() :1.67 tried to register 0000111f-0000-1000-8000-00805f9b34fb which is already registered
mar 18 20:11:20 amd-burk pulseaudio[1127]: org.bluez.ProfileManager1.RegisterProfile() failed: org.bluez.Error.NotPermitted: UUID already registered
mar 18 20:11:21 amd-burk kconf_update[2263]: kf.config.kconf_update: /usr/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
mar 18 20:11:21 amd-burk kconf_update[2263]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
mar 18 20:11:21 amd-burk kconf_update[2263]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_detailsmodesettings.upd defined Version=5 but Version=6 was expected
mar 18 20:11:21 amd-burk kconf_update[2263]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_directorysizemode.upd defined Version=5 but Version=6 was expected
mar 18 20:11:21 amd-burk kconf_update[2263]: kf.config.kconf_update: /usr/share/kconf_update/konsole.upd defined Version=5 but Version=6 was expected
mar 18 20:11:21 amd-burk kconf_update[2263]: kf.config.kconf_update: /usr/share/kconf_update/okular.upd defined Version=5 but Version=6 was expected
mar 18 20:11:21 amd-burk plasmashell[2260]: QThreadStorage: Thread 0x55a10d3c7540 exited after QThreadStorage 8 destroyed
mar 18 20:11:21 amd-burk plasmashell[2260]: QThreadStorage: Thread 0x55a10d3c7540 exited after QThreadStorage 3 destroyed
mar 18 20:11:21 amd-burk plasmashell[2260]: QThreadStorage: Thread 0x55a10d3c7540 exited after QThreadStorage 2 destroyed
mar 18 20:11:21 amd-burk plasmashell[2256]: QThreadStorage: Thread 0x55c898b24540 exited after QThreadStorage 8 destroyed
mar 18 20:11:21 amd-burk plasmashell[2256]: QThreadStorage: Thread 0x55c898b24540 exited after QThreadStorage 3 destroyed
mar 18 20:11:21 amd-burk plasmashell[2256]: QThreadStorage: Thread 0x55c898b24540 exited after QThreadStorage 2 destroyed
mar 18 20:11:21 amd-burk pulseaudio[1127]: Failed to open connection to session manager: None of the authentication protocols specified are supported
mar 18 20:11:21 amd-burk pulseaudio[1127]: Failed to load module "module-x11-xsmp" (argument: "display=:1 xauthority=/run/user/1000/xauth_aQVUOI session_manager=local/amd-burk:@/tmp/.ICE-unix/1157,unix/amd-burk:/tmp/.ICE-unix/1157"): initialization failed.
mar 18 20:11:21 amd-burk systemd[896]: app-pulseaudio@autostart.service: Failed with result 'exit-code'.
mar 18 20:11:21 amd-burk kded6[1159]: kf.bluezqt: PendingCall Error: "The name is not activatable"
mar 18 20:11:21 amd-burk plasmashell[1209]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/main.qml:310:13: QML Image: Cannot open: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/application-menu
mar 18 20:11:21 amd-burk plasmashell[1209]: org.kde.applets.brightness: D-Bus action "KeyboardBrightnessControl" is not available at service "org.kde.Solid.PowerManagement"
mar 18 20:11:21 amd-burk kwalletmanager5[2378]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
mar 18 20:11:23 amd-burk wpa_supplicant[858]: bgscan simple: Failed to enable signal strength monitoring
mar 18 20:11:23 amd-burk dbus-broker-launch[729]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
mar 18 20:11:23 amd-burk kdeconnectd[1420]: 2025-03-18T20:11:23 kdeconnect.core: Failed to send mDNS query: Cannot assign requested address
mar 18 20:11:26 amd-burk kwin_wayland[965]: kwin_core: Cannot grant a token to KWin::ClientConnection(0x564690a3a790)
mar 18 20:11:27 amd-burk xdg-desktop-por[973]: Realtime error: Could not get pidns: Could not fstatat ns/pid: Not a directory
mar 18 20:11:28 amd-burk systemd-coredump[3471]: [🡕] Process 3469 (gldriverquery) of user 1000 dumped core.
                                                 Stack trace of thread 3469:
                                                 #0  0x00000000f7f96579 __kernel_vsyscall (linux-gate.so.1 + 0x579)
                                                 #1  0x00000000f7d8b71f n/a (libc.so.6 + 0x9471f)
                                                 #2  0x00000000f7d302c7 raise (libc.so.6 + 0x392c7)
                                                 #3  0x00000000f7d171f2 abort (libc.so.6 + 0x201f2)
                                                 #4  0x00000000f7f39858 n/a (libSDL2-2.0.so.0 + 0xf858)
                                                 #5  0x00000000f7f9d1cb n/a (ld-linux.so.2 + 0x51cb)
                                                 #6  0x00000000f7f9d2ab n/a (ld-linux.so.2 + 0x52ab)
                                                 #7  0x00000000f7fb3a60 n/a (ld-linux.so.2 + 0x1ba60)
mar 18 20:11:29 amd-burk plasmashell[1209]: org.kde.plasma.taskmanager: applications:com.discordapp.Discord.desktop: Progress value -100 is out of bounds!
mar 18 20:11:30 amd-burk kwin_wayland[965]: kwin_core: Cannot grant a token to KWin::ClientConnection(0x56469072f2e0)
mar 18 20:11:30 amd-burk kwin_wayland[965]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
mar 18 20:11:31 amd-burk kwin_wayland[965]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
mar 18 20:11:37 amd-burk kwin_wayland[965]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsupported buffer GL_BACK_LEFT)
mar 18 20:11:38 amd-burk kwin_wayland[965]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsupported buffer GL_BACK_LEFT)
mar 18 20:11:39 amd-burk kwin_wayland[965]: file:///usr/share/kwin/tabbox/compact/contents/ui/main.qml:36: TypeError: Cannot call method 'longestCaption' of null
mar 18 20:11:39 amd-burk kwin_wayland[965]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsupported buffer GL_BACK_LEFT)
mar 18 20:11:40 amd-burk kwin_wayland[965]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsupported buffer GL_BACK_LEFT)
mar 18 20:11:41 amd-burk kwin_wayland[965]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsupported buffer GL_BACK_LEFT)
  Kernel: 6.6.83-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
  Speed (MHz): avg: 400 min/max: 400/5573 scaling: driver: amd-pstate-epp
    governor: performance cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400
    7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400 15: 400
    16: 400 bogomips: 144060
    BHI: Not affected
    lanes: 16 ports: active: DP-3 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 03:00.0
    empty: DP-4,HDMI-A-2 bus-ID: 0e:00.0 chip-ID: 1002:164e class-ID: 0300
    temp: 33.0 C
    type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2.2.1:14
    min: 720x400
    navi21 LLVM 19.1.7 DRM 3.54 6.6.83-1-MANJARO) device-ID: 1002:73bf
    class-ID: 0403
    class-ID: 0300
  API: ALSA v: k6.6.83-1-MANJARO status: kernel-api with: aoss
    class-ID: 0200
    class-ID: 0280
  Local Storage: total: 5.46 TiB used: 742.65 GiB (13.3%)
    fw-rev: 111130WD temp: 32.9 C scheme: GPT
    used: 324.59 GiB (35.5%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
  System Temperatures: cpu: 59.9 C mobo: 36.0 C
  GPU: device: amdgpu temp: 33.0 C mem: 34.0 C fan: 0 watts: 15.00
  Memory: total: 32 GiB note: est. available: 30.5 GiB used: 7.5 GiB (24.6%)
  Processes: 483 Power: uptime: 3m states: freeze,mem,disk suspend: deep
    tool: systemctl
How did you install PipeWire? I did so using
sudo pacman -Syu manjaro-pipewire helvum
… you might not need helvum but I did; can’t remember why.
After this, I don’t see references to PulseAudio as a server on my system:
  Server-3: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: active 3: pipewire-alsa
    type: plugin tools: pactl,pw-cat,pw-cli
Maybe that will fix things, but I’m no audio expert.
I think i did it through the gui, but I’m not certain anymore.
Also did a revert of all my packages with the help of timeshift since i had a snapshot taken this weekend, and after doing a new update I saw that pipewire was going to be updated.
P.S. or was it pulse… I’m to tired to think
Love conflicting files.
sudo pacman -Syu manjaro-pipewire helvum         ✔
[sudo] password for eriase:
:: Synchronising package databases...
 core is up to date
 extra is up to date
 multilib is up to date
resolving dependencies...
:: manjaro-pipewire-20231009-1 and manjaro-pulse-20240817-1 are in conflict.
Using the command I posted above should fix that, but you may need to try first without the yu (just sudo pacman -S manjaro-pipewire).
Add helvum only if it complains that it needs it.
It’s basically a script which installs PipeWire and removes conflicting PulseAudio modules. This should hopefully resolve the conflict.
EDIT:
You could also perhaps try removing Pulse first:
sudo pacman -Rns manjaro-pulse
Yeah did that, but checked all the messages that the GUI gave me about this might break XXXX depenedcy if uninstalled, but now it works after installing the manjaro-pipewire, and just because i don’t really know what i needed i checked all the boxes for the extras.
Damn now i miss the plasma-pa interface
Wait a second :open_mouth: i should have the pipewire-pulse package now so what happens if I reinstall the plasma-pa
And restart
I wouldn’t do that if PipeWire works now. I had issues when I tried that a while back and went straight back to PipeWire.
The PipeWire interface did take a bit of getting used to for me as well! :thinking:
The only thing left to do on mine is get simultaneous output working again.
I just took the quick route and tried now.
Have the kde plasma audio configuration panel back and this is what i did
[2025-03-18T21:23:44+0100] [ALPM] installed plasma-pa (6.3.3-1)
[2025-03-18T21:19:31+0100] [ALPM] installed helvum (0.5.1-1)
[2025-03-18T21:13:34+0100] [ALPM] installed realtime-privileges (4-3)
[2025-03-18T21:13:34+0100] [ALPM] installed easyeffects (7.2.3-2)
[2025-03-18T21:13:34+0100] [ALPM] installed libsigc++-3.0 (3.6.0-1)
[2025-03-18T21:13:34+0100] [ALPM] installed gsl (2.8-1)
[2025-03-18T21:13:34+0100] [ALPM] installed rnnoise (1:0.2-1)
[2025-03-18T21:13:34+0100] [ALPM] installed pipewire-x11-bell (1:1.4.1-0)
[2025-03-18T21:13:34+0100] [ALPM] installed pipewire-jack (1:1.4.1-0)
[2025-03-18T21:13:34+0100] [ALPM] installed pipewire-zeroconf (1:1.4.1-0)
[2025-03-18T21:13:33+0100] [ALPM] installed zita-convolver (4.0.3-4)
[2025-03-18T21:13:33+0100] [ALPM] installed ladspa (1.17-5)
[2025-03-18T21:13:33+0100] [ALPM] installed pipewire-v4l2 (1:1.4.1-0)
[2025-03-18T21:13:33+0100] [ALPM] installed manjaro-pipewire (20231009-1)
[2025-03-18T21:13:33+0100] [ALPM] installed pipewire-pulse (1:1.4.1-0)
[2025-03-18T21:13:33+0100] [ALPM] installed pipewire-alsa (1:1.4.1-0)
[2025-03-18T21:13:33+0100] [ALPM] removed pulseaudio (17.0+r43+g3e2bb8a1e-1)
[2025-03-18T21:13:33+0100] [ALPM] removed jack2 (1.9.22-1)
[2025-03-18T21:13:33+0100] [ALPM] removed plasma-pa (6.3.3-1)
[2025-03-18T21:13:33+0100] [ALPM] removed pulseaudio-zeroconf (17.0+r43+g3e2bb8a1e-1)
[2025-03-18T21:13:33+0100] [ALPM] removed pulseaudio-bluetooth (17.0+r43+g3e2bb8a1e-1)
[2025-03-18T21:09:46+0100] [ALPM] removed manjaro-pulse (20240817-1)
@BG405 Thanks for the help by telling me to install manjaro-pipewire instead
