Doesn’t seem to make a difference…
Output of update-grub is still the same.
sh-5.1# update-grub
Found linux image: /boot/vmlinuz-5.15-rt-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-rt-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-rt-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.11-rt-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.11-rt-x86_64.img
Found initrd fallback image: /boot/initramfs-5.11-rt-x86_64-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sda1. Check your device.map.
done
yes it was probably an interrupted update…
now that you are back in your system provide output from: mhwd-kernel -li sudo update-grub - run this command after you finished installing kernels
ok so uninstall the 5.15rt and also the 5.17 since its going to be end of life kernel… you can install the 5.10 LTS as a backup kernel…
post outputs from these, because you have some remnats from 5.11 kernel: ls /etc/mkinitcpio.d/*.preset sudo ls /boot/initramfs-* sudo ls /boot/vmlinuz-* sudo ls /usr/lib/modules/*
