If you haven’t removed the previously used kernel it should be avaible in the grub boot menu.
IIRC pressing ESC when booting will bring it up. Make your selection there.
Yes I tried that under advanced options
It looks like I must have removed other kernels on the past as it only gives me the current one being 5.11-rt plus fallback initramfs
Right so I think I managed to mount my encrypted drive and boot.
Checking on the kernel installed I get the following:
sh-5.1# mhwd-kernel -li
Currently running: 5.15.32-1-MANJARO (linux515)
error: could not open file /var/lib/pacman/local/go-2:1.18.3-1/desc: No such file or directory
* linux515-rt
sh-5.1#
sh-5.1# sudo touch /var/lib/pacman/local/go-2:1.18.3-1/desc
sh-5.1# sudo pacman -S go
error: failed to init transaction (unable to lock database)
error: could not lock database: File exists
if you're sure a package manager is not already
running, you can remove /var/lib/pacman/db.lck
warning: go-2:1.18.3-1 is up to date -- reinstalling
resolving dependencies...
error: could not open file /var/lib/pacman/local/go-2:1.18.3-1/files: No such file or directory
warning: could not fully load metadata for package go-2:1.18.3-1
error: failed to prepare transaction (invalid or corrupted package)
sh-5.1# sudo touch /var/lib/pacman/local/go-2:1.18.3-1/files
Packages (1) go-2:1.18.3-1
Total Installed Size: 409.08 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
go-2:1.18.3-1-x86_64.pkg.tar.zst failed to download
error: failed retrieving file 'go-2:1.18.3-1-x86_64.pkg.tar.zst' from mirror.fcix.net : Could not resolve host: mirror.fcix.net
warning: too many errors from mirror.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'go-2:1.18.3-1-x86_64.pkg.tar.zst' from ftp.tsukuba.wide.ad.jp : Could not resolve host: ftp.tsukuba.wide.ad.jp
warning: too many errors from ftp.tsukuba.wide.ad.jp, skipping for the remainder of this transaction
error: failed retrieving file 'go-2:1.18.3-1-x86_64.pkg.tar.zst' from mirror.xenyth.net : Could not resolve host: mirror.xenyth.net
warning: too many errors from mirror.xenyth.net, skipping for the remainder of this transaction
error: failed retrieving file 'go-2:1.18.3-1-x86_64.pkg.tar.zst' from mirror.kku.ac.th : Could not resolve host: mirror.kku.ac.th
warning: too many errors from mirror.kku.ac.th, skipping for the remainder of this transaction
error: failed retrieving file 'go-2:1.18.3-1-x86_64.pkg.tar.zst' from mirrors.ocf.berkeley.edu : Could not resolve host: mirrors.ocf.berkeley.edu
warning: too many errors from mirrors.ocf.berkeley.edu, skipping for the remainder of this transaction
error: failed retrieving file 'go-2:1.18.3-1-x86_64.pkg.tar.zst' from mirror.ufro.cl : Could not resolve host: mirror.ufro.cl
warning: too many errors from mirror.ufro.cl, skipping for the remainder of this transaction
error: failed retrieving file 'go-2:1.18.3-1-x86_64.pkg.tar.zst' from manjaro.mirror.garr.it : Could not resolve host: manjaro.mirror.garr.it
warning: too many errors from manjaro.mirror.garr.it, skipping for the remainder of this transaction
warning: failed to retrieve some files
error: failed to commit transaction (invalid url for server)
That might be the case, do I need to redo the chroot making sure I’m connected?
The output is instant, it’s like it’s not even pinging the servers… do you still want that output? It’s long…
