I was trying to install Peazip(flatpak) through Add/Remove programs and it didn’t install. Then I tried installing through the terminal and I got this error
Error: Error deploying: While trying to checkout 9e8105b66950ba6bf4da30bd0bac6add9efc093364fbb2c0f673d19bde2509ee into /var/lib/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/.9e8105b66950ba6bf4da30bd0bac6add9efc093364fbb2c0f673d19bde2509ee-OCJYF1: Opening content object b14d1ed5e5ec38270bad32d9df8e7a06dcc1ecb3976bc02e1374808ddd7285ee: Couldn’t find file object ‘b14d1ed5e5ec38270bad32d9df8e7a06dcc1ecb3976bc02e1374808ddd7285ee’ error: Failed to install org.kde.Platform: Error deploying: While trying to checkout 9e8105b66950ba6bf4da30bd0bac6add9efc093364fbb2c0f673d19bde2509ee into /var/lib/flatpak/runtime/org.kde.Platform/x86_64/5.15-21.08/.9e8105b66950ba6bf4da30bd0bac6add9efc093364fbb2c0f673d19bde2509ee-OCJYF1: Opening content object b14d1ed5e5ec38270bad32d9df8e7a06dcc1ecb3976bc02e1374808ddd7285ee: Couldn’t find file object ‘b14d1ed5e5ec38270bad32d9df8e7a06dcc1ecb3976bc02e1374808ddd7285ee’
I only face issues when I try to download through flatpak packages. Can anyone please help me.
00
comments
no comments yet
Be the first to share what you think!
Run sudo flatpak repair and try again. Also see this issue:
opened 09:02PM - 11 Feb 21 UTC
closed 01:32AM - 06 Apr 22 UTC
## Linux distribution and version
Manjaro Linux 20.2.1
## Flatpak version
Fla… tpak 1.10.1
## Description of the problem
I started Pamac GUI application to install com.visualstudio.code from "flathub" remote, during the installation I by accident pushed the cancel button which reverted the transaction, then I pressed on the install button once again. Then I get a message saying "Transaction successfully" within the Pamac GUI application, but the log message from Pamac GUI in Manjaro Linux:
> Installing runtime/org.freedesktop.Sdk/x86_64/20.08
> 2 metadata, 0 content objects fetched; 592 B transferred in 0 seconds
> While trying to checkout 305a04169e9092e7c31a0fde61c185d01e18dc1e8a710aac1e02e8479330ed64 into /var/lib/flatpak/runtime/org.freedesktop.Sdk/x86_64/20.08/.305a04169e9092e7c31a0fde61c185d01e18dc1e8a710aac1e02e8479330ed64-Y2RNY0: Opening content object 39e10c8d60a3debb1a2a497499b0404c9d40bb049a385a9515c5e1da162d8e04: Couldn't find file object '39e10c8d60a3debb1a2a497499b0404c9d40bb049a385a9515c5e1da162d8e04'
> Skipping com.visualstudio.code/x86_64/stable due to previous error
> Transaction successfully finished.
I get the same error when trying to install using the Flatpak CLI:
> [admin@laptop ~]$ flatpak install com.visualstudio.code
> Looking for matches…
> Found similar ref(s) for ‘com.visualstudio.code’ in remote ‘flathub’ (system).
> Use this remote? [Y/n]: y
> Required runtime for com.visualstudio.code/x86_64/stable (runtime/org.freedesktop.Sdk/x86_64/20.08) found in remote flathub
> Do you want to install it? [Y/n]: y
> com.visualstudio.code permissions:
> ipc network pulseaudio ssh-auth
> x11 devices devel file access [1]
> dbus access [2] system dbus access [3] tags [4]
> [1] host, xdg-config/kdeglobals:ro
> [2] com.canonical.AppMenu.Registrar, com.canonical.AppMenu.Registrar.*, org.freedesktop.Flatpak,
> org.freedesktop.Notifications, org.freedesktop.secrets
> [3] org.freedesktop.login1
> [4] proprietary
> ID Branch Op Remote Download
> 1. [✗] org.freedesktop.Sdk 20.08 i flathub 1,0 kB / 563,3 MB
> 2. [ ] com.visualstudio.code stable i flathub < 70,2 MB
> Error: Error deploying: While trying to checkout 305a04169e9092e7c31a0fde61c185d01e18dc1e8a710aac1e02e8479330ed64 into /var/lib/flatpak/runtime/org.freedesktop.Sdk/x86_64/20.08/.305a04169e9092e7c31a0fde61c185d01e18dc1e8a710aac1e02e8479330ed64-ID00Y0: Opening content object 39e10c8d60a3debb1a2a497499b0404c9d40bb049a385a9515c5e1da162d8e04: Couldn't find file object '39e10c8d60a3debb1a2a497499b0404c9d40bb049a385a9515c5e1da162d8e04'
> error: Failed to install org.freedesktop.Sdk: Error deploying: While trying to checkout 305a04169e9092e7c31a0fde61c185d01e18dc1e8a710aac1e02e8479330ed64 into /var/lib/flatpak/runtime/org.freedesktop.Sdk/x86_64/20.08/.305a04169e9092e7c31a0fde61c185d01e18dc1e8a710aac1e02e8479330ed64-ID00Y0: Opening content object 39e10c8d60a3debb1a2a497499b0404c9d40bb049a385a9515c5e1da162d8e04: Couldn't find file object '39e10c8d60a3debb1a2a497499b0404c9d40bb049a385a9515c5e1da162d8e04'
> [admin@laptop ~]$ flatpak install org.freedesktop.Sdk//20.08
> Found similar ref(s) for ‘org.freedesktop.Sdk//20.08’ in remote ‘flathub’ (system).
> Error: Error deploying: While trying to checkout 305a04169e9092e7c31a0fde61c185d01e18dc1e8a710aac1e02e8479330ed64 into /var/lib/flatpak/runtime/org.freedesktop.Sdk/x86_64/20.08/.305a04169e9092e7c31a0fde61c185d01e18dc1e8a710aac1e02e8479330ed64-VL6GY0: Opening content object 39e10c8d60a3debb1a2a497499b0404c9d40bb049a385a9515c5e1da162d8e04: Couldn't find file object '39e10c8d60a3debb1a2a497499b0404c9d40bb049a385a9515c5e1da162d8e04'
> error: Failed to install org.freedesktop.Sdk: Error deploying: While trying to checkout 305a04169e9092e7c31a0fde61c185d01e18dc1e8a710aac1e02e8479330ed64 into /var/lib/flatpak/runtime/org.freedesktop.Sdk/x86_64/20.08/.305a04169e9092e7c31a0fde61c185d01e18dc1e8a710aac1e02e8479330ed64-VL6GY0: Opening content object 39e10c8d60a3debb1a2a497499b0404c9d40bb049a385a9515c5e1da162d8e04: Couldn't find file object '39e10c8d60a3debb1a2a497499b0404c9d40bb049a385a9515c5e1da162d8e04'
## Steps to reproduce
1.) Install com.visualstudio.code using the Pamac GUI application, press cancel during installation.
2.) Press install button again.
3.) com.visualstudio.code can't be installed due to corrupt state with the runtime org.freedesktop.Sdk//20.08
