I’ve not had any serious problems until today. I went in to my Manjaro partition and it won’t boot - basically a black screen. It complains about a Fatal server error/ no screens found.
I tried to restore from a BTRFS snapshot but none are working either. I then went to the terminal and updated the databases and tried to reinstall the nvidia drivers but there is no change.
Reading from the terminal the /var/log/Xorg.0.log error states:
NVIDIA: Failed to initialize the NVIDIA kernel module.
As advised elsewhere in the forum I updated using pacman (sudo pacman -Sy) and reinstalled the NVIDIA driver (sudo pacman -S nvidia). There were no issues however it did not solve the boot problem. I also tried (sudo pacman-mirrors -f3) and startx at the prompt.
Updating grub (sudo update-grub) doesn’t seem to find the Manjaro partition but booting from the live disk does see the Manjaro grub entry.
As someone else suggested I booted with the live usb entered:
su
manjaro-chroot -a (at this point it doesn’t report a Manjaro grub entry either)
pacman -Syu grub (but then error: pacman: command not found)
I don’t see a repair option on the live USB so I am at a loss now on how to get back the partition.
sudo manjaro-chroot -a 1 ✘
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
==> Mounting (Fedora) [/dev/sda3]
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
mount: /mnt/etc/resolv.conf: mount point is a symbolic link to nowhere.
[root@manjaro-gnome /]# mhwd -li
bash: mhwd: command not found
Thanks for that follow-up. Everything was done successfully, however, the system remains in the same state. When using startx from the prompt I am still getting xinit: server error, no screens found. Is there anything else I can try?
At this point I seem destined to reinstall. But this incident is disturbing since it was working fine when I last used it a week or two ago. I’d like to determine the cause so this isn’t repeated and I don’t lose my setup again, after-all that’s what I thought the btrfs snapshots would have prevented.
Update:
Wow, I was able to boot into a btrfs snapshot from March 6 and I am in the gui right now. It tells me I need to restore it to keep using this version which I need to find out how to proceed as it looks that the task is much more complex than I thought. I am wondering if there is anything else I should be doing while its running.
I removed 5.13 and 5.14 (although 5.13 is still showing in grub) and updated. Kernel 5.15.28 was the first kernel listed in grub but it wouldn’t boot gui as before. 5.15.27 would boot so while I was in it I updated then I reinstalled Linux515 and Linux515-headers.
After performing the updates I can only boot to emergency mode with kernel5.15.27. System log (journalctl) complains about kernel modules and /boot/efi. The top grub entry, 5.15.28 is not bootable to gui as before.
Running sudo mkinitcpio -P again shows the following errors:
/lib/modules/5.13.19-2-MANJARO is not a valid kernel module directory
/lib/modules/5.15.27-1-MANJARO is not a valid kernel module directory
Grub is still finding remnants of 513:
Found linux image: /boot/vmlinuz-5.13-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.13-x86_64.img
Found initrd fallback image: /boot/initramfs-5.13-x86_64-fallback.img
Some warnings are:
Possible missing firmware for module: bfa
Possible missing firmware for module: qed
Possible missing firmware for module: qla2xxx
Possible missing firmware for module: qla1280
I managed to get in via snapshot again. Below are the answers.
sudo mhwd -li ✔
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2021.12.18 false PCI
sudo mhwd-kernel -li ✔ 4s
Currently running: 5.15.27-1-rt35-MANJARO (linux515)
* linux515
* linux515-rt
If you hawe “old” gpu you also may wish to keep old kernel&driver to avoid possible iusses
Right now i on 5.4 with nvida linux419-nvidia-470xx and it works fine (510 nvidia works badly if i remember corectly)
Thanks for the heads up concerning Nvidia. It is a recent card, RTX 2070 super. It seemed to be running fine until this incident occurred. I am not yet sure what the culprit is, NVIDIA, GRUB, BTRFS or Manjaro.
I deleted the items listed by stephane and confirmed by straycat.
Current status is, however, as before, Manjaro won’t finish booting into either the first grub entry (a black screen) or the optional kernel 5.15.27-rt (boots into emergency mode). Incidentally kernel 513 is still listed in the grub list. I can continue to boot into a btrfs snapshot but that doesn’t seem like a long term solution. A reinstall seems like the only option left.
