#################### inxi -Fxzc0 ########################
System: Kernel: 5.9.3-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: GNOME 3.38.1
Distro: Manjaro Linux
Machine: Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40688 WIN serial: <filter>
UEFI [Legacy]: LENOVO v: EUCN19WW date: 05/12/2020
Battery: ID-1: BAT0 charge: 35.8 Wh condition: 57.8/60.0 Wh (96%) model: Celxpert L19C4PC0
status: Charging
CPU: Info: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen rev: 1 L2 cache: 4096 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 92660
Speed: 1397 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz): 1: 1397
2: 1724 3: 1397 4: 1396 5: 1397 6: 1396 7: 1397 8: 1396 9: 1661 10: 1630 11: 1660
12: 1642 13: 1663 14: 1907 15: 1397 16: 1397
Graphics: Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo driver: nvidia
v: 455.38 bus ID: 01:00.0
Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus ID: 05:00.0
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus ID: 1-3:2
Display: x11 server: X.org 1.20.9 driver: amdgpu,nvidia resolution: <xdpyinfo missing>
OpenGL: renderer: AMD RENOIR (DRM 3.39.0 5.9.3-1-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.2.1 direct render: Yes
Audio: Device-1: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo driver: N/A
bus ID: 05:00.5
Device-2: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus ID: 05:00.6
Sound Server: ALSA v: k5.9.3-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo
driver: r8169 v: kernel port: 2000 bus ID: 03:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 2000 bus ID: 04:00.0
IF: wlp4s0 state: down mac: <filter>
Drives: Local Storage: total: 476.94 GiB used: 263.00 GiB (55.1%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000L2 size: 476.94 GiB
Partition: ID-1: / size: 459.79 GiB used: 263.00 GiB (57.2%) fs: ext4 dev: /dev/nvme0n1p1
Swap: ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p2
Sensors: System Temperatures: cpu: 46.0 C mobo: N/A gpu: amdgpu temp: 37.0 C
Info: Processes: 357 Uptime: 59m Memory: 7.22 GiB used: 1.36 GiB (18.8%) Init: systemd
Compilers: gcc: 10.2.0 Packages: 1356 Client: shell wrapper v: 5.0.18-release
inxi: 3.1.08
Can’t seem to connect my bluetooth speaker. When I try using bluetoothctl
the devices doesn’t show. But when I go to settings and bluetooth then it shows up, even in bluetoothctl
. I can pair it and trust it but when I try to connect it connect for split second then disconnects.
