I’ve just noticed during a restart that I get this error on boot:
[FAILED] Failed to start Load Kernel Modules
That’s it, nothing else, just this single line. Then, the computer proceeds to boot.
I’ve had Manjaro installed on my Laptop for less than 3 days, and have barely installed anything on it. I don’t have a dedicated GPU, just my ol’ trusty Intel HD 4000. I am running Manjaro 21.0 XFCE, with Kernel 5.9.16. Edit: I’ve installed 5.10 and currently running on it, the issue persists.
For the moment, everything works, but I am afraid of my installation breaking at some point because of this. I don’t think this happened after an update, because I’m not sure if I even updated anything.
As for software, I’ve recently installed Onlyoffice, Redshift, Flameshot, Chromium, some TLP Packages for Thinkpads, Microsoft fonts, and a few others.
Can I do something about this? I can provide any further information necessary.
Thank you.
**sudo mhwd-kernel -li**
Currently running: 5.10.23-1-MANJARO (linux510)
* linux414
* linux510
* linux59
**sudo ls /etc/mkinitcpio.d/*.preset**
/etc/mkinitcpio.d/linux414.preset /etc/mkinitcpio.d/linux59.preset
/etc/mkinitcpio.d/linux510.preset
You’re a godsend. The culprit was in fact tp_smapi.
I’m using an X230, and did not check if my model is supported by that package. It isn’t.
I just uninstalled it, and everything went back to normal. Thank you so much!
