Hi!
For a few weeks now, I had trouble when booting into my pc. I had enough of always having to press Control-D to enter my pc (it works just fine after it), so I turn to you with my problem. I don’t really know which of the following lines are useful in my case.
If anyone helps, thank you for your time and assistance in advance.
sudo journalctl -p 3 -xb
-- Journal begins at Mon 2021-02-01 16:44:56 CET, ends at Mon 2021-03-01 10:34:27 CET. --
márc 01 10:08:55 manjaro kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT5._GTF.DSSP], AE_NOT_FOUND (20200717/psargs-330)
márc 01 10:08:55 manjaro kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT5._GTF due to previous error (AE_NOT_FOUND) (20200717/psparse-529)
márc 01 10:08:55 manjaro kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT4._GTF.DSSP], AE_NOT_FOUND (20200717/psargs-330)
márc 01 10:08:55 manjaro kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT4._GTF due to previous error (AE_NOT_FOUND) (20200717/psparse-529)
márc 01 10:08:55 manjaro systemd-fsck[231]: fsck failed with exit status 4.
márc 01 10:08:55 manjaro systemd[1]: Failed to start File System Check on Root Device.
░░ Subject: A start job for unit systemd-fsck-root.service has failed
░░ Defined-By: systemd
░░ A start job for unit systemd-fsck-root.service has finished with a failure.
░░ The job identifier is 43 and the job result is failed.
márc 01 10:09:01 manjaro kwin_x11[961]: kwin_xkbcommon: XKB: Couldn't process include statement for 'hu(\0)'
márc 01 10:09:01 manjaro kwin_x11[961]: kwin_xkbcommon: XKB: Abandoning symbols file "(unnamed)"
márc 01 10:09:01 manjaro kwin_x11[961]: kwin_xkbcommon: XKB: Failed to compile xkb_symbols
márc 01 10:09:01 manjaro kwin_x11[961]: kwin_xkbcommon: XKB: Failed to compile keymap
márc 01 10:09:26 manjaro pulseaudio[1066]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
márc 01 10:20:02 manjaro sudo[3833]: hakszi : a password is required ; TTY=pts/4 ; PWD=/home/hakszi ; USER=root ; COMMAND=/sbin/file -s /dev/sdc2
sudo systemctl --failed
UNIT LOAD ACTIVE SUB DESCRIPTION
● systemd-fsck-root.service loaded failed failed File System Check on Root Device
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
1 loaded units listed.
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=ea97171f-2e54-44d2-8bdb-fffc22720954 ro quiet apparmor=1
Desktop: KDE Plasma 5.21.1 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop Mobo: MSI model: H81M-E33 (MS-7817) v: 1.0 serial: <filter>
UEFI: American Megatrends v: 6.7 date: 04/21/2015
RAM: total: 15.58 GiB used: 3.17 GiB (20.4%)
Info: Quad Core model: Intel Core i5-4460 bits: 64 type: MCP arch: Haswell
family: 6 model-id: 3C (60) stepping: 3 microcode: 28 L2 cache: 6 MiB
bogomips: 25610
Speed: 2347 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 2347 2: 2299
3: 3294 4: 3296
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb
pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
xtopology xtpr
Type: l1tf
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] driver: nvidia v: 460.39
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1c02
class ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 101 s-size: 966x272mm (38.0x10.7")
s-diag: 1004mm (39.5")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
Monitor-2: DP-0 res: 1920x1080 hz: 60 dpi: 102 size: 480x270mm (18.9x10.6")
diag: 551mm (21.7")
OpenGL: renderer: GeForce GTX 1060 3GB/PCIe/SSE2 v: 4.6.0 NVIDIA 460.39
direct render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:8c20 class ID: 0403
Device-2: NVIDIA GP106 High Definition Audio driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 10de:10f1 class ID: 0403
Sound Server: ALSA v: k5.9.16-1-MANJARO
vendor: Micro-Star MSI driver: r8169 v: kernel port: d000 bus ID: 03:00.0
chip ID: 10ec:8168 class ID: 0200
Message: No Bluetooth data was found.
Local Storage: total: 1.13 TiB used: 398.46 GiB (34.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37120G
size: 111.79 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: J1A3 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: DT01ACA100
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: A750 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: SA400S37120G
size: 111.79 GiB block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
rotation: SSD serial: <filter> rev: B1D1 scheme: GPT
ID-1: / raw size: 111.49 GiB size: 109.24 GiB (97.98%)
used: 57.7 GiB (52.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: ea97171f-2e54-44d2-8bdb-fffc22720954
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 0B30-D85B
ID-3: /run/media/hakszi/HDD raw size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 340.75 GiB (36.6%) fs: ntfs dev: /dev/sdb1 maj-min: 8:17 label: HDD
uuid: 86029A42029A36E1
ID-1: /dev/sdc1 maj-min: 8:33 size: 100 MiB fs: vfat label: N/A
uuid: 8658-F46D
ID-2: /dev/sdc2 maj-min: 8:34 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sdc3 maj-min: 8:35 size: 111.18 GiB fs: ntfs label: N/A
uuid: B05863385862FC8A
ID-4: /dev/sdc4 maj-min: 8:36 size: 505 MiB fs: ntfs label: N/A
uuid: 8C4ADDA44ADD8AFA
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip ID: 8087:8008 class ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0
Device-1: 2-1:2 info: SteelSeries ApS SteelSeries Rival 100 Gaming Mouse
type: HID,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s chip ID: 1038:1702 class ID: 0301
Device-2: 2-2:3 info: Dell KB216 Wired Keyboard type: Keyboard,HID
chip ID: 413c:2113 class ID: 0300
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-5: 3-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s chip ID: 8087:8000 class ID: 0900
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003 class ID: 0900
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 48 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 11%
Processes: 213 Uptime: 27m wakeups: 0 Init: systemd v: 247 Compilers:
gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1529 lib: 507 flatpak: 0
Shell: Bash v: 5.1.0 running in: konsole inxi: 3.3.01
journalctl -xr
márc 01 10:36:49 manjaro konsole[6015]: Skipped method "setDefaultShortcuts" : Pointers are not supported: QAction*
márc 01 10:36:49 manjaro konsole[6015]: Invalid return type in method "addAction"
márc 01 10:36:49 manjaro konsole[6015]: Unsupported return type 65 QPixmap in method "grab"
márc 01 10:36:49 manjaro polkitd[620]: Unregistered Authentication Agent for unix-process:6079:167628 (system bus name :1.96, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale C)
márc 01 10:36:49 manjaro polkitd[620]: Registered Authentication Agent for unix-process:6079:167628 (system bus name :1.96 [flatpak list], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale C)
márc 01 10:36:49 manjaro kwin_x11[961]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 53986, resource id: 14712339, major code: 14 (GetGeometry), minor code: 0
márc 01 10:36:49 manjaro kwin_x11[961]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53985, resource id: 14712339, major code: 3 (GetWindowAttributes), minor code: 0
márc 01 10:36:49 manjaro systemd[893]: Started Konsole - Terminal.
░░ Subject: A start job for unit UNIT has finished successfully
░░ A start job for unit UNIT has finished successfully.
░░ The job identifier is 312.
márc 01 10:36:47 manjaro kwin_x11[961]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53340, resource id: 12582950, major code: 18 (ChangeProperty), minor code: 0
márc 01 10:36:47 manjaro systemd[893]: app-org.kde.konsole-8b00b0ec1f3c437c88e1573619fb132f.scope: Succeeded.
░░ Subject: Unit succeeded
░░ The unit UNIT has successfully entered the 'dead' state.
márc 01 10:36:47 manjaro kwin_x11[961]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53334, resource id: 81789082, major code: 18 (ChangeProperty), minor code: 0
márc 01 10:36:24 manjaro polkitd[620]: Unregistered Authentication Agent for unix-process:5997:165102 (system bus name :1.95, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale C)
márc 01 10:36:24 manjaro polkitd[620]: Registered Authentication Agent for unix-process:5997:165102 (system bus name :1.95 [/sbin/flatpak list], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale C)
-- Journal begins at Mon 2021-02-01 16:44:56 CET, ends at Mon 2021-03-01 10:36:49 CET. --
