I have three L2TP/IPSec VPNs and I cannot connect to any of them, even tested on a freshly installed system. The three VPNs use username/password and a PSK for IPSec.
I installed networkmanager-l2tp
and networkmanager-strongswan
for VPN support.
The log all looked alike and I didn’t find an explicit error.
Mar 04 14:38:20 MyPC audit[798]: USYS_CONFIG pid=798 uid=0 auid=4294967295 ses=4294967295 msg='op=connection-activate uuid=0f603eb2-c739-4f11-8e3b-1d9e31a025ee name="WorkVPN" pid=2467 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mar 04 14:38:20 MyPC NetworkManager[798]: <info> [1646375900.6522] audit: op="connection-activate" uuid="0f603eb2-c739-4f11-8e3b-1d9e31a025ee" name="WorkVPN" pid=2467 uid=1000 result="success"
Mar 04 14:38:20 MyPC kernel: audit: type=1111 audit(1646375900.649:698): pid=798 uid=0 auid=4294967295 ses=4294967295 msg='op=connection-activate uuid=0f603eb2-c739-4f11-8e3b-1d9e31a025ee name="WorkVPN" pid=2467 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mar 04 14:38:20 MyPC NetworkManager[798]: <info> [1646375900.6573] vpn-connection[0x556438f144c0,0f603eb2-c739-4f11-8e3b-1d9e31a025ee,"WorkVPN",0]: Started the VPN service, PID 1735890
Mar 04 14:38:20 MyPC NetworkManager[798]: <info> [1646375900.6693] vpn-connection[0x556438f144c0,0f603eb2-c739-4f11-8e3b-1d9e31a025ee,"WorkVPN",0]: Saw the service appear; activating connection
Mar 04 14:38:20 MyPC NetworkManager[798]: <info> [1646375900.6861] vpn-connection[0x556438f144c0,0f603eb2-c739-4f11-8e3b-1d9e31a025ee,"WorkVPN",0]: VPN connection: (ConnectInteractive) reply received
Mar 04 14:38:20 MyPC nm-l2tp-service[1735890]: Check port 1701
Mar 04 14:38:20 MyPC NetworkManager[1735903]: Stopping strongSwan IPsec failed: starter is not running
Mar 04 14:38:22 MyPC NetworkManager[1735900]: Starting strongSwan 5.9.5 IPsec [starter]...
Mar 04 14:38:22 MyPC NetworkManager[1735900]: Loading config setup
Mar 04 14:38:22 MyPC NetworkManager[1735900]: Loading conn '0f603eb2-c739-4f11-8e3b-1d9e31a025ee'
Mar 04 14:38:22 MyPC ipsec_starter[1735900]: Starting strongSwan 5.9.5 IPsec [starter]...
Mar 04 14:38:22 MyPC ipsec_starter[1735900]: Loading config setup
Mar 04 14:38:22 MyPC ipsec_starter[1735900]: Loading conn '0f603eb2-c739-4f11-8e3b-1d9e31a025ee'
Mar 04 14:38:22 MyPC ipsec_starter[1735963]: Attempting to start charon...
Mar 04 14:38:22 MyPC charon[1735964]: 00[DMN] Starting IKE charon daemon (strongSwan 5.9.5, Linux 5.15.25-1-MANJARO, x86_64)
Mar 04 14:38:22 MyPC charon[1735964]: 00[CFG] PKCS11 module '<name>' lacks library path
Mar 04 14:38:22 MyPC charon[1735964]: 00[LIB] plugin 'mysql' failed to load: libmariadb.so.3: cannot open shared object file: No such file or directory
Mar 04 14:38:22 MyPC charon[1735964]: 00[CFG] attr-sql plugin: database URI not set
Mar 04 14:38:22 MyPC charon[1735964]: 00[NET] using forecast interface wlo1
Mar 04 14:38:22 MyPC charon[1735964]: 00[CFG] joining forecast multicast groups: 224.0.0.1,224.0.0.22,224.0.0.251,224.0.0.252,239.255.255.250
Mar 04 14:38:22 MyPC charon[1735964]: 00[CFG] loading ca certificates from '/etc/ipsec.d/cacerts'
Mar 04 14:38:22 MyPC charon[1735964]: 00[CFG] loading aa certificates from '/etc/ipsec.d/aacerts'
Mar 04 14:38:22 MyPC charon[1735964]: 00[CFG] loading ocsp signer certificates from '/etc/ipsec.d/ocspcerts'
Mar 04 14:38:22 MyPC charon[1735964]: 00[CFG] loading attribute certificates from '/etc/ipsec.d/acerts'
Mar 04 14:38:22 MyPC charon[1735964]: 00[CFG] loading crls from '/etc/ipsec.d/crls'
Mar 04 14:38:22 MyPC charon[1735964]: 00[CFG] loading secrets from '/etc/ipsec.secrets'
Mar 04 14:38:22 MyPC charon[1735964]: 00[CFG] loading secrets from '/etc/ipsec.d/ipsec.nm-l2tp.secrets'
Mar 04 14:38:22 MyPC charon[1735964]: 00[CFG] loaded IKE secret for %any
Mar 04 14:38:22 MyPC charon[1735964]: 00[CFG] sql plugin: database URI not set
Mar 04 14:38:22 MyPC charon[1735964]: 00[CFG] opening triplet file /etc/ipsec.d/triplets.dat failed: No such file or directory
Mar 04 14:38:22 MyPC charon[1735964]: 00[CFG] loaded 0 RADIUS server configurations
Mar 04 14:38:22 MyPC charon[1735964]: 00[CFG] HA config misses local/remote address
Mar 04 14:38:22 MyPC charon[1735964]: 00[CFG] no script for ext-auth script defined, disabled
Mar 04 14:38:22 MyPC charon[1735964]: 00[LIB] loaded plugins: charon ldap pkcs11 aesni aes des rc2 sha2 sha3 sha1 md5 mgf1 random nonce x509 revocation constraints pubkey pkcs1 pkcs7 pkcs8 pkcs12 pgp dnskey sshkey pem openssl fips-prf gmp curve25519 agent chapoly xcbc cmac hmac ntru drbg newhope bliss curl sqlite attr kernel-netlink resolve socket-default bypass-lan connmark forecast farp stroke vici updown eap-identity eap-sim eap-aka eap-aka-3gpp2 eap-simaka-pseudonym eap-simaka-reauth eap-md5 eap-gtc eap-mschapv2 eap-dynamic eap-radius eap-tls eap-ttls eap-peap xauth-generic xauth-eap xauth-pam xauth-noauth dhcp radattr unity counters
Mar 04 14:38:22 MyPC charon[1735964]: 00[LIB] dropped capabilities, running as uid 0, gid 0
Mar 04 14:38:22 MyPC charon[1735964]: 00[JOB] spawning 16 worker threads
Mar 04 14:38:22 MyPC audit: MAC_IPSEC_EVENT op=SPD-add auid=4294967295 ses=4294967295 res=1 src=10.0.1.0 src_prefixlen=24 dst=10.0.1.0 dst_prefixlen=24
Mar 04 14:38:22 MyPC audit[1735964]: SYSCALL arch=c000003e syscall=44 success=yes exit=184 a0=9 a1=7fb7030e24a0 a2=b8 a3=0 items=0 ppid=1735963 pid=1735964 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="charon" exe="/usr/lib/strongswan/charon" key=(null)
Mar 04 14:38:22 MyPC audit: PROCTITLE proctitle=2F7573722F6C69622F7374726F6E677377616E2F636861726F6E002D2D7573652D7379736C6F67
Mar 04 14:38:22 MyPC audit: MAC_IPSEC_EVENT op=SPD-add auid=4294967295 ses=4294967295 res=1 src=192.168.1.0 src_prefixlen=24 dst=192.168.1.0 dst_prefixlen=24
Mar 04 14:38:22 MyPC audit: MAC_IPSEC_EVENT op=SPD-add auid=4294967295 ses=4294967295 res=1 src=0000:0000:0000:0000:0000:0000:0000:0001 dst=0000:0000:0000:0000:0000:0000:0000:0001
Mar 04 14:38:22 MyPC audit: MAC_IPSEC_EVENT op=SPD-add auid=4294967295 ses=4294967295 res=1 src=fdcb:1959:eae1:0000:0000:0000:0000:09f9 dst=fdcb:1959:eae1:0000:0000:0000:0000:09f9
Mar 04 14:38:22 MyPC kernel: audit: type=1415 audit(1646375902.765:699): op=SPD-add auid=4294967295 ses=4294967295 res=1 src=10.0.1.0 src_prefixlen=24 dst=10.0.1.0 dst_prefixlen=24
Mar 04 14:38:22 MyPC kernel: audit: type=1300 audit(1646375902.765:699): arch=c000003e syscall=44 success=yes exit=184 a0=9 a1=7fb7030e24a0 a2=b8 a3=0 items=0 ppid=1735963 pid=1735964 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="charon" exe="/usr/lib/strongswan/charon" key=(null)
Mar 04 14:38:22 MyPC kernel: audit: type=1327 audit(1646375902.765:699): proctitle=2F7573722F6C69622F7374726F6E677377616E2F636861726F6E002D2D7573652D7379736C6F67
Mar 04 14:38:22 MyPC kernel: audit: type=1415 audit(1646375902.765:700): op=SPD-add auid=4294967295 ses=4294967295 res=1 src=10.0.1.0 src_prefixlen=24 dst=10.0.1.0 dst_prefixlen=24
Mar 04 14:38:22 MyPC kernel: audit: type=1300 audit(1646375902.765:700): arch=c000003e syscall=44 success=yes exit=184 a0=9 a1=7fb7030e24a0 a2=b8 a3=0 items=0 ppid=1735963 pid=1735964 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="charon" exe="/usr/lib/strongswan/charon" key=(null)
Mar 04 14:38:22 MyPC kernel: audit: type=1327 audit(1646375902.765:700): proctitle=2F7573722F6C69622F7374726F6E677377616E2F636861726F6E002D2D7573652D7379736C6F67
Mar 04 14:38:22 MyPC kernel: audit: type=1415 audit(1646375902.765:701): op=SPD-add auid=4294967295 ses=4294967295 res=1 src=10.0.1.0 src_prefixlen=24 dst=10.0.1.0 dst_prefixlen=24
Mar 04 14:38:22 MyPC kernel: audit: type=1300 audit(1646375902.765:701): arch=c000003e syscall=44 success=yes exit=184 a0=9 a1=7fb7030e24a0 a2=b8 a3=0 items=0 ppid=1735963 pid=1735964 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="charon" exe="/usr/lib/strongswan/charon" key=(null)
Mar 04 14:38:22 MyPC kernel: audit: type=1327 audit(1646375902.765:701): proctitle=2F7573722F6C69622F7374726F6E677377616E2F636861726F6E002D2D7573652D7379736C6F67
Mar 04 14:38:22 MyPC audit: MAC_IPSEC_EVENT op=SPD-add auid=4294967295 ses=4294967295 res=1 src=fdcb:1959:eae1:0000:0000:0000:0000:0000 src_prefixlen=64 dst=fdcb:1959:eae1:0000:0000:0000:0000:0000 dst_prefixlen=64
Mar 04 14:38:22 MyPC audit: MAC_IPSEC_EVENT op=SPD-add auid=4294967295 ses=4294967295 res=1 src=fe80:0000:0000:0000:0000:0000:0000:0000 src_prefixlen=64 dst=fe80:0000:0000:0000:0000:0000:0000:0000 dst_prefixlen=64
Mar 04 14:38:22 MyPC charon[1735964]: 06[IKE] installed bypass policy for 10.0.1.0/24
Mar 04 14:38:22 MyPC charon[1735964]: 06[IKE] installed bypass policy for 192.168.1.0/24
Mar 04 14:38:22 MyPC charon[1735964]: 06[IKE] installed bypass policy for ::1/128
Mar 04 14:38:22 MyPC charon[1735964]: 06[IKE] installed bypass policy for fdcb:1959:eae1::9f9/128
Mar 04 14:38:22 MyPC charon[1735964]: 06[IKE] installed bypass policy for fdcb:1959:eae1::/64
Mar 04 14:38:22 MyPC charon[1735964]: 06[IKE] installed bypass policy for fe80::/64
Mar 04 14:38:22 MyPC ipsec_starter[1735963]: charon (1735964) started after 40 ms
Mar 04 14:38:22 MyPC charon[1735964]: 13[CFG] received stroke: add connection '0f603eb2-c739-4f11-8e3b-1d9e31a025ee'
Mar 04 14:38:22 MyPC charon[1735964]: 13[CFG] added configuration '0f603eb2-c739-4f11-8e3b-1d9e31a025ee'
Mar 04 14:38:23 MyPC charon[1735964]: 15[CFG] rereading secrets
Mar 04 14:38:23 MyPC charon[1735964]: 15[CFG] loading secrets from '/etc/ipsec.secrets'
Mar 04 14:38:23 MyPC charon[1735964]: 15[CFG] loading secrets from '/etc/ipsec.d/ipsec.nm-l2tp.secrets'
Mar 04 14:38:23 MyPC charon[1735964]: 15[CFG] loaded IKE secret for %any
Mar 04 14:38:23 MyPC charon[1735964]: 04[CFG] received stroke: initiate '0f603eb2-c739-4f11-8e3b-1d9e31a025ee'
Mar 04 14:38:23 MyPC charon[1735964]: 08[IKE] initiating Main Mode IKE_SA 0f603eb2-c739-4f11-8e3b-1d9e31a025ee[1] to 123.123.123.123
Mar 04 14:38:23 MyPC charon[1735964]: 08[ENC] generating ID_PROT request 0 [ SA V V V V V ]
Mar 04 14:38:23 MyPC charon[1735964]: 08[NET] sending packet: from 192.168.1.102[500] to 123.123.123.123[500] (532 bytes)
Mar 04 14:38:24 MyPC wpa_supplicant[935]: wlo1: Reject scan trigger since one is already pending
Mar 04 14:38:27 MyPC charon[1735964]: 10[IKE] sending retransmit 1 of request message ID 0, seq 1
Mar 04 14:38:27 MyPC charon[1735964]: 10[NET] sending packet: from 192.168.1.102[500] to 123.123.123.123[500] (532 bytes)
Mar 04 14:38:33 MyPC NetworkManager[1736282]: Stopping strongSwan IPsec...
Mar 04 14:38:33 MyPC kernel: kauditd_printk_skb: 45 callbacks suppressed
Mar 04 14:38:33 MyPC kernel: audit: type=1415 audit(1646375913.792:717): op=SPD-delete auid=4294967295 ses=4294967295 res=1 src=fe80:0000:0000:0000:0000:0000:0000:0000 src_prefixlen=64 dst=fe80:0000:0000:0000:0000:0000:0000:0000 dst_prefixlen=64
Mar 04 14:38:33 MyPC kernel: audit: type=1300 audit(1646375913.792:717): arch=c000003e syscall=44 success=yes exit=80 a0=9 a1=7fff54dfdc50 a2=50 a3=0 items=0 ppid=1735963 pid=1735964 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="charon" exe="/usr/lib/strongswan/charon" key=(null)
Mar 04 14:38:33 MyPC kernel: audit: type=1327 audit(1646375913.792:717): proctitle=2F7573722F6C69622F7374726F6E677377616E2F636861726F6E002D2D7573652D7379736C6F67
Mar 04 14:38:33 MyPC kernel: audit: type=1415 audit(1646375913.792:718): op=SPD-delete auid=4294967295 ses=4294967295 res=1 src=fe80:0000:0000:0000:0000:0000:0000:0000 src_prefixlen=64 dst=fe80:0000:0000:0000:0000:0000:0000:0000 dst_prefixlen=64
Mar 04 14:38:33 MyPC kernel: audit: type=1300 audit(1646375913.792:718): arch=c000003e syscall=44 success=yes exit=80 a0=9 a1=7fff54dfdc50 a2=50 a3=0 items=0 ppid=1735963 pid=1735964 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="charon" exe="/usr/lib/strongswan/charon" key=(null)
Mar 04 14:38:33 MyPC kernel: audit: type=1327 audit(1646375913.792:718): proctitle=2F7573722F6C69622F7374726F6E677377616E2F636861726F6E002D2D7573652D7379736C6F67
Mar 04 14:38:33 MyPC kernel: audit: type=1415 audit(1646375913.792:719): op=SPD-delete auid=4294967295 ses=4294967295 res=1 src=fe80:0000:0000:0000:0000:0000:0000:0000 src_prefixlen=64 dst=fe80:0000:0000:0000:0000:0000:0000:0000 dst_prefixlen=64
Mar 04 14:38:33 MyPC kernel: audit: type=1300 audit(1646375913.792:719): arch=c000003e syscall=44 success=yes exit=80 a0=9 a1=7fff54dfdc50 a2=50 a3=0 items=0 ppid=1735963 pid=1735964 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="charon" exe="/usr/lib/strongswan/charon" key=(null)
Mar 04 14:38:33 MyPC kernel: audit: type=1327 audit(1646375913.792:719): proctitle=2F7573722F6C69622F7374726F6E677377616E2F636861726F6E002D2D7573652D7379736C6F67
Mar 04 14:38:33 MyPC kernel: audit: type=1415 audit(1646375913.792:720): op=SPD-delete auid=4294967295 ses=4294967295 res=1 src=fdcb:1959:eae1:0000:0000:0000:0000:0000 src_prefixlen=64 dst=fdcb:1959:eae1:0000:0000:0000:0000:0000 dst_prefixlen=64
Mar 04 14:38:33 MyPC audit: MAC_IPSEC_EVENT op=SPD-delete auid=4294967295 ses=4294967295 res=1 src=fe80:0000:0000:0000:0000:0000:0000:0000 src_prefixlen=64 dst=fe80:0000:0000:0000:0000:0000:0000:0000 dst_prefixlen=64
Mar 04 14:38:33 MyPC audit[1735964]: SYSCALL arch=c000003e syscall=44 success=yes exit=80 a0=9 a1=7fff54dfdc50 a2=50 a3=0 items=0 ppid=1735963 pid=1735964 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="charon" exe="/usr/lib/strongswan/charon" key=(null)
Mar 04 14:38:33 MyPC audit: PROCTITLE proctitle=2F7573722F6C69622F7374726F6E677377616E2F636861726F6E002D2D7573652D7379736C6F67
Mar 04 14:38:33 MyPC audit: MAC_IPSEC_EVENT op=SPD-delete auid=4294967295 ses=4294967295 res=1 src=fdcb:1959:eae1:0000:0000:0000:0000:0000 src_prefixlen=64 dst=fdcb:1959:eae1:0000:0000:0000:0000:0000 dst_prefixlen=64
Mar 04 14:38:33 MyPC audit: MAC_IPSEC_EVENT op=SPD-delete auid=4294967295 ses=4294967295 res=1 src=fdcb:1959:eae1:0000:0000:0000:0000:09f9 dst=fdcb:1959:eae1:0000:0000:0000:0000:09f9
Mar 04 14:38:33 MyPC audit: MAC_IPSEC_EVENT op=SPD-delete auid=4294967295 ses=4294967295 res=1 src=0000:0000:0000:0000:0000:0000:0000:0001 dst=0000:0000:0000:0000:0000:0000:0000:0001
Mar 04 14:38:33 MyPC audit: MAC_IPSEC_EVENT op=SPD-delete auid=4294967295 ses=4294967295 res=1 src=192.168.1.0 src_prefixlen=24 dst=192.168.1.0 dst_prefixlen=24
Mar 04 14:38:33 MyPC audit: MAC_IPSEC_EVENT op=SPD-delete auid=4294967295 ses=4294967295 res=1 src=10.0.1.0 src_prefixlen=24 dst=10.0.1.0 dst_prefixlen=24
Mar 04 14:38:33 MyPC NetworkManager[1736018]: initiating Main Mode IKE_SA 0f603eb2-c739-4f11-8e3b-1d9e31a025ee[1] to 123.123.123.123
Mar 04 14:38:33 MyPC NetworkManager[1736018]: generating ID_PROT request 0 [ SA V V V V V ]
Mar 04 14:38:33 MyPC NetworkManager[1736018]: sending packet: from 192.168.1.102[500] to 123.123.123.123[500] (532 bytes)
Mar 04 14:38:33 MyPC NetworkManager[1736018]: sending retransmit 1 of request message ID 0, seq 1
Mar 04 14:38:33 MyPC NetworkManager[1736018]: destroying IKE_SA in state CONNECTING without notification
Mar 04 14:38:33 MyPC NetworkManager[1736018]: establishing connection '0f603eb2-c739-4f11-8e3b-1d9e31a025ee' failed
Mar 04 14:38:33 MyPC charon[1735964]: 00[DMN] SIGINT received, shutting down
Mar 04 14:38:33 MyPC charon[1735964]: 00[IKE] destroying IKE_SA in state CONNECTING without notification
Mar 04 14:38:33 MyPC charon[1735964]: 00[IKE] uninstalling bypass policy for 10.0.1.0/24
Mar 04 14:38:33 MyPC charon[1735964]: 00[IKE] uninstalling bypass policy for 192.168.1.0/24
Mar 04 14:38:33 MyPC charon[1735964]: 00[IKE] uninstalling bypass policy for ::1/128
Mar 04 14:38:33 MyPC charon[1735964]: 00[IKE] uninstalling bypass policy for fdcb:1959:eae1::9f9/128
Mar 04 14:38:33 MyPC charon[1735964]: 00[IKE] uninstalling bypass policy for fdcb:1959:eae1::/64
Mar 04 14:38:33 MyPC charon[1735964]: 00[IKE] uninstalling bypass policy for fe80::/64
Mar 04 14:38:33 MyPC ipsec_starter[1735963]: child 1735964 (charon) has quit (exit code 0)
Mar 04 14:38:33 MyPC ipsec_starter[1735963]: charon stopped after 200 ms
Mar 04 14:38:33 MyPC ipsec_starter[1735963]: ipsec starter stopped
Mar 04 14:38:33 MyPC nm-l2tp-service[1735890]: g_dbus_method_invocation_take_error: assertion 'error != NULL' failed
Mar 04 14:38:33 MyPC NetworkManager[798]: <info> [1646375913.9012] vpn-connection[0x556438f144c0,0f603eb2-c739-4f11-8e3b-1d9e31a025ee,"WorkVPN",0]: VPN plugin: state changed: stopped (6)
Mar 04 14:38:33 MyPC NetworkManager[798]: <info> [1646375913.9025] vpn-connection[0x556438f144c0,0f603eb2-c739-4f11-8e3b-1d9e31a025ee,"WorkVPN",0]: VPN service disappeared
Mar 04 14:38:33 MyPC NetworkManager[798]: <warn> [1646375913.9029] vpn-connection[0x556438f144c0,0f603eb2-c739-4f11-8e3b-1d9e31a025ee,"WorkVPN",0]: VPN connection: failed to connect: 'Message recipient disconnected from message bus without replying'
I tested with Windows and Android, they connect without any problem.
Any help is appreciated.
