Fail2ban filter - ignoreregex for location - path?
I use a custom filter and in some cases it get’s triggered by letsencrypt challenges …
Can location (part of a path) used with “ignoreregex” e.g.
ignoreregex = /.well-known/acme-challenge/
and should slashes be escaped?
something like this?
ignoreregex = ^<HOST> -.*"GET /.well-known/acme-challenge.*
For this kind of question, LLM can often be a starting point to understanding how things work (but it can sometimes say BS so just use it at starting point to learn basic things). Example here from GPT:
Answer from your post (click):
Yes. If you’re referring to a Fail2Ban filter, ignoreregex is a regular expression that’s matched against the log line, not just the URL path. So you can absolutely match a path such as:
However, there are a couple of things to keep in mind:
  1. The / characters do not need to be escaped in Python regular expressions (which Fail2Ban uses). So this is fine:
  1. The . in .well-known should be escaped if you want to match a literal dot. Otherwise . matches any character:
ignoreregex = /\.well-known/acme-challenge/
  1. Since ignoreregex is applied to the entire log line, you don’t usually need anchors unless you specifically want them. A more robust version might be:
ignoreregex = .*\/\.well-known/acme-challenge/.*
although the leading/trailing .* are often unnecessary because the regex engine searches the line for a match.
Example
If your log line is:
192.0.2.1 - - [14/Jul/2026:10:00:00 +0000] "GET /.well-known/acme-challenge/abc123 HTTP/1.1" 404 153
then this is sufficient:
Verify it
You can check whether your ignoreregex is working with:
fail2ban-regex /path/to/logfile /etc/fail2ban/filter.d/yourfilter.conf
This will show which lines match failregex and which are excluded by ignoreregex.
If you can share your current failregex and a sample log line that is incorrectly triggering the ban, I can suggest the minimal ignoreregex needed.
//EDIT: note that it is quick explanation from LLM and sometimes it is not accurate, but I think for this simple question it may be good enough to test things carefully (don’t copy paste everything it says without understanding).
