Hi there, it’s my first post here so I apologize if I’m missing something but I’m having almost the same problem as the original post which is that after trying to repair my system via chroot (and doing the system update )the screen just gets stock on dell’s logo.
I’ve tried everything until this part of the thread (some commands didn’t worked like mhwd -l && mhwd -li) but, when I run journalctl -b-1 -p3 --no-pager, this is the output:
[manjaro /]# journalctl -b-1 -p3 --no-pager
Aug 04 00:10:46 peter kernel: [Firmware Bug]: TSC_DEADLINE disabled due to Errata; please update microcode to version: 0x20 (or later)
Aug 04 00:10:46 peter kernel: dw_dmac INTL9C60:00: Missing DT data
Aug 04 00:10:49 peter libvirtd[529]: internal error: Missing udev property 'ID_VENDOR_ID' on '1-1.1'
Aug 04 00:10:49 peter libvirtd[529]: internal error: Missing udev property 'ID_VENDOR_ID' on '1-1.5'
Aug 04 00:10:49 peter libvirtd[529]: internal error: Missing udev property 'ID_VENDOR_ID' on '1-1.6'
Aug 04 00:10:49 peter libvirtd[529]: internal error: Missing udev property 'ID_VENDOR_ID' on '1-1.8'
Aug 04 00:10:55 peter kernel: sd 4:0:0:0: [sdb] No Caching mode page found
Aug 04 00:10:55 peter kernel: sd 4:0:0:0: [sdb] Assuming drive cache: write through
Aug 04 00:11:43 peter agetty[1130]: tty4: invalid character conversion for login name
Aug 04 00:15:34 peter systemd-cryptsetup[1275]: Device luks-b5bde9d0-fb81-4b62-9ae6-a9b1943bc32c is still in use.
Aug 04 00:15:34 peter systemd-cryptsetup[1275]: Failed to deactivate: Device or resource busy
By the way, this is the output from mhwd -l and mhwd -li
[manjaro /]# mhwd -l
mhwd: error while loading shared libraries: libx86emu.so.3: cannot open shared object file: No such file or directory
[manjaro /]# mhwd -li
And this is the output for the kernel
[manjaro /]# mhwd-kernel -li
Currently running: 5.15.53-1-MANJARO (linux515)
* linux414
* linux515
* linux59
