Nothing seems to happen after I press the F6 key on my laptop but Fn+F6 really works well. My laptop model is Lenovo XiaoXin Chao 5000 and the machine runs Manjaro KDE with daily full system upgrade.
Here is some further information:
$ inxi -Fxza
System: Kernel: 5.10.59-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=d1bc4347-645a-445d-ba7f-4ad3280500b2 rw quiet apparmor=1
security=apparmor resume=UUID=4ee8fe3b-df7e-40ba-9f5a-6688f3bb3b4c udev.log_priority=3
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux
base: Arch Linux
Machine: Type: Laptop System: LENOVO product: 80Y3 v: Lenovo XiaoXin CHAO5000 serial: <filter> Chassis: type: 10
Mobo: LENOVO model: LNVNB161216 v: SDK0K09938 WIN serial: <filter> UEFI: LENOVO v: 4WCN29WW date: 09/30/2017
Battery: ID-1: BAT0 charge: 25.6 Wh (100.0%) condition: 25.6/30.6 Wh (83.5%) volts: 8.5 min: 7.6 model: CPT-COS L16C2PB2
type: Li-poly serial: <filter> status: Full
CPU: Info: Dual Core model: Intel Core i7-7500U bits: 64 type: MT MCP arch: Amber/Kaby Lake note: check family: 6
model-id: 8E (142) stepping: 9 microcode: EA cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 23209
Speed: 1100 MHz min/max: 400/3500 MHz Core speeds (MHz): 1: 1100 2: 1100 3: 1100 4: 1100
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel HD Graphics 620 vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:5916
class-ID: 0300
Device-2: Acer EasyCamera type: USB driver: uvcvideo bus-ID: 1-8:3 chip-ID: 5986:1127 class-ID: 0e02
serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: amdgpu,ati,intel unloaded: modesetting
alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.6 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel alternate: snd_soc_skl
bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.10.59-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169 v: kernel port: 3000
bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi v: kernel port: 3000 bus-ID: 03:00.0
chip-ID: 8086:3166 class-ID: 0280
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-7:2 chip-ID: 8087:0a2a
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
address: see --recommends
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: 5060 bus-ID: 00:17.0
chip-ID: 8086.282a rev: 21 class-ID: 0104
Drives: Local Storage: total: 1.03 TiB used: 26.3 GiB (2.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: SK Hynix model: HFS128G3BTND-N210A size: 119.24 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 1P10 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10SPZX-24Z10T0 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 1A01 scheme: GPT
Partition: ID-1: / raw-size: 19.99 GiB size: 19.51 GiB (97.59%) used: 4.65 GiB (23.8%) fs: ext4 dev: /dev/sda4 maj-min: 8:4
ID-2: /boot/efi raw-size: 261 MiB size: 260.8 MiB (99.94%) used: 32.5 MiB (12.5%) fs: vfat dev: /dev/sda1
maj-min: 8:1
ID-3: /home raw-size: 40 GiB size: 39.08 GiB (97.69%) used: 10.98 GiB (28.1%) fs: ext4 dev: /dev/sdb4 maj-min: 8:20
ID-4: /usr raw-size: 30 GiB size: 29.36 GiB (97.87%) used: 10.56 GiB (36.0%) fs: ext4 dev: /dev/sdb5 maj-min: 8:21
Swap: Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 8 GiB used: 70.9 MiB (0.9%) priority: -2 dev: /dev/sdb6 maj-min: 8:22
Sensors: System Temperatures: cpu: 44.0 C mobo: N/A gpu: amdgpu temp: 40.0 C
Info: Processes: 202 Uptime: 4h 42m wakeups: 4 Memory: 3.62 GiB used: 2.26 GiB (62.4%) Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1285 lib: 331 flatpak: 0 Shell: Zsh v: 5.8
running-in: konsole inxi: 3.3.06
And I also tried sudo showkey, it showed like below:
$ sudo showkey
[sudo] password for littleye233:
kb mode was ?UNKNOWN?
[ if you are trying this under X, it might not work
since the X server is also reading /dev/console ]
press any key (program terminates 10s after last keypress)...
^[[17~keycode 64 press # Fn+F6
keycode 64 release
^[[15~keycode 63 press # Fn+F5
keycode 63 release
^[[18~keycode 65 press # Fn+F7
keycode 65 release
^[[15~keycode 63 press # F5
keycode 63 release
# Here I pressed a single `F6` but nothing happened.
keycode 29 press # Ctrl+C
^Ccaught signal 2, cleaning up...
So this problem is raised by whether hardware or software? And can it be fixed? Any reply will be appreciated.
