Hi all,
after update I have not the graphical login and I can not execute startx.
mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia-390xx 2021.12.18 false PCI
network-r8168 2016.04.20 true PCI
Device-1: NVIDIA GT218 [GeForce 210] driver: N/A
Device-2: Owon USB CAMERA type: USB driver: snd-usb-audio,uvcvideo
Display: server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3 driver: X: loaded: nvidia
gpu: N/A
Message: No GL data found on this system.
nvidia-settings
ERROR: The control display is undefined; please run `nvidia-settings --help` for usage information.
mhwd-kernel -li
Currently running: 5.15.60-1-MANJARO (linux515)
* linux419
* linux510
* linux515
* linux54
I try to read various forum and guidelines but I do not found a solution to this problem. I had god two identical video card and I try to exchange it without good results.
Someone can please help me?
Thx MR
PS Follows the logs
grep EE /var/log/Xorg.*
/var/log/Xorg.0.log:[ 174.315] Current Operating System: Linux i7 5.15.60-1-MANJARO #1 SMP PREEMPT Thu Aug 11 13:14:05 UTC 2022 x86_64
/var/log/Xorg.0.log: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
/var/log/Xorg.0.log:[ 174.340] (EE) No devices detected.
/var/log/Xorg.0.log:[ 174.340] (EE) no screens found(EE)
/var/log/Xorg.0.log:[ 174.340] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
/var/log/Xorg.0.log:[ 174.343] (EE) Server terminated with error (1). Closing log file.
/var/log/Xorg.0.log.old:[ 57.353] Current Operating System: Linux i7 5.15.60-1-MANJARO #1 SMP PREEMPT Thu Aug 11 13:14:05 UTC 2022 x86_64
/var/log/Xorg.0.log.old: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
/var/log/Xorg.0.log.old:[ 57.394] (EE) No devices detected.
/var/log/Xorg.0.log.old:[ 57.394] (EE) no screens found(EE)
/var/log/Xorg.0.log.old:[ 57.394] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
/var/log/Xorg.0.log.old:[ 57.397] (EE) Server terminated with error (1). Closing log file.
/var/log/Xorg.1.log:[ 2045.618] Current Operating System: Linux i7 5.15.60-1-MANJARO #1 SMP PREEMPT Thu Aug 11 13:14:05 UTC 2022 x86_64
/var/log/Xorg.1.log: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
/var/log/Xorg.1.log:[ 2045.659] (EE) No devices detected.
/var/log/Xorg.1.log:[ 2045.659] (EE) no screens found(EE)
/var/log/Xorg.1.log:[ 2045.659] (EE) Please also check the log file at "/var/log/Xorg.1.log" for additional information.
/var/log/Xorg.1.log:[ 2045.662] (EE) Server terminated with error (1). Closing log file.
/var/log/Xorg.1.log.old:[ 31792.763] Current Operating System: Linux i7 5.15.59-1-MANJARO #1 SMP PREEMPT Wed Aug 3 11:20:04 UTC 2022 x86_64
/var/log/Xorg.1.log.old: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
/var/log/Xorg.1.log.old:[ 31794.058] (II) Initializing extension MIT-SCREEN-SAVER
/var/log/Xorg.1.log.old:[ 31795.210] (EE) event15 - HTX USB HID Device HTX HID Device Touchpad: kernel bug: clickpad advertising right button. See https://wayland.freedesktop.org/libinput/doc/1.21.0/clickpad-with-right-button.html for details
/var/log/Xorg.1.log.old:[ 31795.257] (EE) event15 - HTX USB HID Device HTX HID Device Touchpad: kernel bug: clickpad advertising right button. See https://wayland.freedesktop.org/libinput/doc/1.21.0/clickpad-with-right-button.html for details
cat /var/log/Xorg.0.log
[ 174.312]
X.Org X Server 1.21.1.4
[ 174.315] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=81a981fa-118d-4d84-9d4c-217002acd6f6 rw quiet resume=UUID=609abc4d-60f5-4b57-8c40-d836a364bf44
[ 174.318]
[ 174.319] Current version of pixman: 0.40.0
[ 174.321] Before reporting problems, check http://wiki.x.org
[ 174.321] Markers: (--) probed, (**) from config file, (==) default setting,
[ 174.326] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Aug 15 04:39:43 2022
[ 174.327] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 174.328] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 174.328] (==) ServerLayout "Layout0"
[ 174.328] (**) |-->Screen "Screen0" (0)
[ 174.328] (**) | |-->Monitor "Monitor0"
[ 174.328] (**) | |-->Device "Device0"
[ 174.328] (**) |-->Input Device "Keyboard0"
[ 174.328] (**) |-->Input Device "Mouse0"
[ 174.329] (**) Option "IgnoreABI" "1"
[ 174.329] (**) Ignoring ABI Version
[ 174.329] (==) Automatically adding devices
[ 174.329] (==) Automatically enabling devices
[ 174.329] (==) Automatically adding GPU devices
[ 174.329] (==) Automatically binding GPU devices
[ 174.329] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 174.329] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 174.329] Entry deleted from font path.
[ 174.329] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 174.329] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF,
/usr/share/fonts/100dpi,
/usr/share/fonts/75dpi
[ 174.329] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 174.329] (**) Extension "COMPOSITE" is enabled
[ 174.329] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 174.329] (WW) Disabling Keyboard0
[ 174.329] (WW) Disabling Mouse0
[ 174.329] (II) Module ABI versions:
[ 174.329] X.Org ANSI C Emulation: 0.4
[ 174.329] X.Org Video Driver: 25.2
[ 174.329] X.Org XInput driver : 24.4
[ 174.329] X.Org Server Extension : 10.0
[ 174.329] (++) using VT number 3
[ 174.331] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_321
[ 174.337] (--) PCI:*(1@0:0:0) 10de:0a65:1043:852d rev 162, Mem @ 0xfa000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 174.337] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 174.337] (II) LoadModule: "glx"
[ 174.337] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 174.339] (II) Module glx: vendor="X.Org Foundation"
[ 174.339] compiled for 1.21.1.4, module version = 1.0.0
[ 174.339] ABI class: X.Org Server Extension, version 10.0
[ 174.339] (II) LoadModule: "nvidia"
[ 174.339] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 174.339] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 174.339] compiled for 4.0.2, module version = 1.0.0
[ 174.339] Module class: X.Org Video Driver
[ 174.339] (II) NVIDIA dlloader X Driver 390.154 Wed Jun 22 04:48:53 UTC 2022
[ 174.339] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 174.339] (II) Loading sub module "fb"
[ 174.339] (II) LoadModule: "fb"
[ 174.339] (II) Module "fb" already built-in
[ 174.339] (II) Loading sub module "wfb"
[ 174.339] (II) LoadModule: "wfb"
[ 174.339] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 174.339] (II) Module wfb: vendor="X.Org Foundation"
[ 174.339] ABI class: X.Org ANSI C Emulation, version 0.4
[ 174.339] (II) Loading sub module "ramdac"
[ 174.339] (II) LoadModule: "ramdac"
[ 174.339] (II) Module "ramdac" already built-in
[ 174.339] (WW) NVIDIA(0): The NVIDIA GeForce 210 GPU installed in this system is
[ 174.340] (WW) NVIDIA(0): supported through the NVIDIA 340.xx Legacy drivers. Please
[ 174.340] (WW) NVIDIA(0): visit http://www.nvidia.com/object/unix.html for more
[ 174.340] (WW) NVIDIA(0): information. The 390.154 NVIDIA driver will ignore this
[ 174.340] (WW) NVIDIA(0): GPU. Continuing probe...
[ 174.340] (EE)
Fatal server error:
[ 174.340] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 174.340] (EE)
PPSS
Partially resolved using nouveau
