I would like to do a test, with the aim of testing whether it is possible to turn off interrupts of the Linux kernel.
My test consists of adding nohz_full=‘0-15’ to see if the system works by deactivating the kernel’s multitasking, but I wish to do this non-permanently, and for that I activated the menu and there it asks to press F1 to start (the key does not respond, no matter how many times I press it).
I also tried nohz_full=‘1-15’ to see if it’s an error in my configuration, but it doesn’t respond to the F1 key either.
I could try editing /etc/default/grub and running grub mkconfig as a workaround, but I consider this test as risking needing to configure again with chroot.
To start, it asks you to press F1 and it doesn’t boot when I press it, I’ve tried starting like this even without changing any parameters and it doesn’t work.
What is in your picture looks different from what I see.
For me it is
TAB to get completion recommendations
CTRL-x or F10 to boot
CTRL-C or F2 for a command line
and ESC to abort
