Hello everyone,
I needed to install manjaro for school and it seems great so far. I have a little experience with linux, so i am a noob to this, but i can not figure out why my boot is so slow as 15 minutes.
I have a i7 4770k and a SSD hard disk, so it should not take this long. I have seen others on this forum with slow boots (40 seconds), but mostly they get told to buy ssd because it just takes long.
Thank you for your time, i appreciate all help!
systemd-analyze:
Startup finished in 6.932s (firmware) + 5.294s (loader) + 1.841s (kernel) + 3.281s (userspace) = 17.349s
graphical.target reached after 2.092s in userspace
systemd-analyze blaze:
1.174s tlp.service
751ms lvm2-monitor.service
736ms apparmor.service
632ms dev-sda3.device
538ms snapd.service
394ms systemd-random-seed.service
357ms dev-loop1.device
308ms polkit.service
296ms dev-loop4.device
251ms var-lib-snapd-snap-arduino-61.mount
250ms var-lib-snapd-snap-gnome\x2d3\x2d28\x2d1804-161.mount
248ms var-lib-snapd-snap-gtk\x2dcommon\x2dthemes-1515.mount
243ms var-lib-snapd-snap-core18-2074.mount
242ms dev-loop3.device
241ms var-lib-snapd-snap-snapd-12398.mount
221ms dev-loop2.device
215ms avahi-daemon.service
211ms dev-loop0.device
195ms NetworkManager.service
186ms udisks2.service
159ms systemd-logind.service
158ms systemd-udev-trigger.service
133ms systemd-journal-flush.service
126ms user@1000.service
97ms ModemManager.service
89ms systemd-journald.service
86ms snapd.apparmor.service
83ms cups.service
78ms upower.service
78ms systemd-udevd.service
61ms modprobe@drm.service
54ms boot-efi.mount
44ms systemd-tmpfiles-setup-dev.service
40ms systemd-fsck@dev-disk-by\x2duuid-2CF1\x2dC75C.service
39ms systemd-tmpfiles-clean.service
38ms tmp.mount
38ms systemd-modules-load.service
33ms modprobe@fuse.service
28ms linux-module-cleanup.service
25ms systemd-tmpfiles-setup.service
23ms sys-kernel-config.mount
21ms systemd-rfkill.service
18ms systemd-remount-fs.service
18ms systemd-binfmt.service
17ms bluetooth.service
17ms systemd-user-sessions.service
15ms wpa_supplicant.service
15ms dev-hugepages.mount
15ms systemd-update-utmp.service
15ms dev-mqueue.mount
14ms sys-kernel-debug.mount
13ms sys-kernel-tracing.mount
12ms kmod-static-nodes.service
11ms modprobe@configfs.service
10ms systemd-backlight@backlight:intel_backlight.service
9ms proc-sys-fs-binfmt_misc.mount
8ms user-runtime-dir@1000.service
7ms systemd-sysctl.service
5ms rtkit-daemon.service
4ms alsa-restore.service
3ms sys-fs-fuse-connections.mount
892us snapd.socket
vs
doesn’t add up.
The machine is booting fast enough, it certainly doesn’t take 15 minutes.
What do you mean exactly, when you talk about long boot times? Time to login screen?
Please provide output of
$ journalctl -b -p err
Since the it is not problem of the system services (they load in 20sec) I would rather say it is this KDE, which takes so long.
systemd-analyze just counts until it reach the graphical target. At this time SDDM and KDE starts.
I have an hp laptop, so it shows the hp logo first, then when that disappears, 15 minutes later i’m in the login screen.
journalctl -b -p err:
jul 17 17:46:53 renzo-manjaree kernel: platform MSFT0101:00: failed to claim resource 1: [mem 0xfed40000-0xfed40fff]
jul 17 17:46:53 renzo-manjaree kernel: acpi MSFT0101:00: platform device creation failed: -16
jul 17 17:46:54 renzo-manjaree kernel: kfd kfd: TOPAZ not supported in kfd
jul 17 17:46:55 renzo-manjaree kernel: Bluetooth: hci0: BCM: firmware Patch file not found, tried:
jul 17 17:46:55 renzo-manjaree kernel: Bluetooth: hci0: BCM: ‘brcm/BCM43142A0-0a5c-216d.hcd’
jul 17 17:46:55 renzo-manjaree kernel: Bluetooth: hci0: BCM: ‘brcm/BCM-0a5c-216d.hcd’
jul 17 17:46:57 renzo-manjaree kernel: Bluetooth: hci0: command 0x1003 tx timeout
jul 17 17:46:58 renzo-manjaree kernel: Bluetooth: hci0: unexpected event for opcode 0x1003
jul 17 17:57:10 renzo-manjaree kernel: Bluetooth: hci0: command 0x1003 tx timeout
jul 17 17:57:10 renzo-manjaree kernel: Bluetooth: hci0: unexpected event for opcode 0x1003
Thanks! now i have some real errors to work with i’ll look them up online to see if i can find anything interesting
ah, makes sense. Thank you
Do you see the same behaviour when booting a live usb?
Do you see the same behaviour with other kernels?
https://wiki.manjaro.org/index.php/Manjaro_Kernels#Terminal_Commands
I did not have these problems with live usb or other kernals. I have however found out that it is a video problem. if i wait 20 seconds for it to boot, it works. the screen is just black. i can fix it by closing and opening my laptop after those 20 seconds and it works. not the best solution, but it works like a charm and doesn’t seem to really effect performance or cause problems. Thank you everyone that gave advice and helped!
caho
July 17, 2021, 4:35pm
#9
I had the same problem some times ago. The result was, that I had configured random background pictures-show from my nas in the system-settings. There are over 10.000 pictures and kde indicates these pictures every login. During this indication (more than 15 minutes) the computer was unusable.
My solution was to deactivate the picture-show and switch to a single background picture. Since this time the system starts very fast as expected.
Perhaps do you have the same problem …
1.701s systemd-random-seed.service
436ms apparmor.service
399ms tlp.service
364ms lvm2-monitor.service
362ms home-carsten-NAS\x2d2.mount
232ms dev-nvme0n1p2.device
203ms cups.service
180ms boot-efi.mount
172ms snapd.service
164ms user@1027.service
115ms polkit.service
96ms systemd-udev-trigger.service
84ms upower.service
76ms home-carsten-NAS\x2d2\x2dBilder.mount
75ms ModemManager.service
61ms systemd-journald.service
60ms avahi-daemon.service
56ms udisks2.service
55ms NetworkManager.service
52ms systemd-timesyncd.service
52ms systemd-udevd.service
51ms modprobe@drm.service
50ms systemd-journal-flush.service
48ms dev-disk-by\x2duuid-8ad2f757\x2d948e\x2d4040\x2dbe3a\x2d11e385ab1f21.swap
42ms systemd-logind.service
31ms systemd-tmpfiles-clean.service
30ms systemd-fsck-root.service
29ms colord.service
27ms systemd-modules-load.service
27ms snapd.apparmor.service
27ms systemd-fsck@dev-disk-by\x2duuid-A082\x2d2FA5.service
29ms colord.service
24ms NetworkManager-wait-online.service
21ms modprobe@fuse.service
19ms systemd-tmpfiles-setup.service
18ms dev-hugepages.mount
17ms dev-mqueue.mount
17ms sys-kernel-debug.mount
17ms systemd-tmpfiles-setup-dev.service
16ms sys-kernel-tracing.mount
16ms systemd-binfmt.service
15ms kmod-static-nodes.service
14ms systemd-update-utmp.service
14ms bluetooth.service
13ms modprobe@configfs.service
13ms rtkit-daemon.service
12ms wpa_supplicant.service
11ms user-runtime-dir@1027.service
System: Kernel: 5.13.1-3-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.22.3 Distro: Manjaro Linux
Machine: Type: Laptop System: TUXEDO product: TUXEDO Pulse 15 Gen1 v: Standard serial: <filter>
Mobo: TUXEDO s model: PULSE1501 v: Standard serial: <filter> UEFI: American Megatrends v: N.1.07.A02
date: 12/08/2020
Battery: ID-1: BAT0 charge: 81.6 Wh (89.1%) condition: 91.6/91.6 Wh (100.0%)
CPU: Info: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP cache: L2: 4 MiB
Speed: 1397 MHz min/max: 1400/2900 MHz Core speeds (MHz): 1: 1397 2: 1838 3: 1397 4: 1397 5: 1397 6: 1397 7: 1397
8: 1397 9: 1289 10: 1394 11: 1273 12: 1279 13: 1393 14: 1298 15: 1397 16: 1397
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Renoir driver: amdgpu v: kernel
Device-2: Chicony HD Webcam type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.11 driver: loaded: amdgpu,ati unloaded: modesetting resolution: 1920x1080~60Hz
OpenGL: renderer: AMD RENOIR (DRM 3.41.0 5.13.1-3-MANJARO LLVM 12.0.0) v: 4.6 Mesa 21.1.4
Audio: Device-1: Advanced Micro Devices [AMD/ATI] driver: snd_hda_intel
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.13.1-3-MANJARO running: yes
Sound Server-2: PulseAudio v: 14.2 running: yes
Network: Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
address: see --recommends
Drives: Local Storage: total: 232.89 GiB used: 35.33 GiB (15.2%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SA2000M8250G size: 232.89 GiB
Partition: ID-1: / size: 219.86 GiB used: 35.33 GiB (16.1%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 511 MiB used: 304 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
Swap: ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 36.5 C mobo: 35.0 C gpu: amdgpu temp: 35.0 C
Info: Processes: 311 Uptime: 22m Memory: 7.19 GiB used: 1.48 GiB (20.6%) Shell: Bash inxi: 3.3.05
regards
caho
I hadn’t done that yet. I tried it with both amdgpu and radeaon, but it didn’t change anything. I am okay with the way it works now though, i can at least use my laptop again.
I can see that taking a while hahaha. Thanks for the suggestion, but that is not happening in my case. i haven’t connected to the internet and only have the OS images on my laptop
