I just got a noise canceling headphone from Sony. I noticed that the volume on Linux using aux cable is extremely low. And only on linux. It was fine on android with bluetooth, it was also fine on Windows with aux cable.
I almost purchase new usb audio interface without knowing that it’s linux only issue.
On windows on the same machine, volume 10% and 40% on the soundcard gives enough volume. But on Linux I need to crank it up to 100% on the OS and 100% on my sound card to achieve decent volume, and sometimes it’s still not enough.
ANother problem is if I increase my sound card volume, there will be hissing. And enable “Raise max volume” will make the audio to have bad quality when the volume is beyond 100%.
alsamixer
only has one volume setting. config on /etc/asound.conf
doesn’t seem to do anything to my alsamixer as well.
Other than purchasing a hardware that can increase the volume (which I’m not sure what it is or if it will actually fix my problem), I don’t know what else I can do to fix it.
inxi -v7azy ✔
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "id_ID.UTF-8",
LC_IDENTIFICATION = "id_ID.UTF-8",
LC_MEASUREMENT = "id_ID.UTF-8",
LC_MONETARY = "id_ID.UTF-8",
LC_NAME = "id_ID.UTF-8",
LC_NUMERIC = "id_ID.UTF-8",
LC_PAPER = "id_ID.UTF-8",
LC_TELEPHONE = "id_ID.UTF-8",
LC_TIME = "en_SG.UTF-8",
LANG = "en_US.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
Kernel: 6.5.13-7-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.5-x86_64
root=UUID=858ada71-9967-47d5-bb8d-495c18aaf599 rw rootflags=subvol=@
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: frameworks
v: 5.113.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: B450M-HDV R4.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: P4.50
date: 03/12/2021
System RAM: total: 32 GiB available: 31.27 GiB used: 6.55 GiB (20.9%)
Array-1: capacity: 128 GiB slots: 2 modules: 2 EC: None
max-module-size: 64 GiB note: est.
(unregistered) size: 16 GiB speed: 2133 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Geil
part-no: GD2.1829BC.002 serial: <filter>
part-no: GD2.1843BS.00A serial: <filter>
Info: model: AMD Ryzen 5 3500 bits: 64 type: MCP arch: Zen 2 gen: 3 level: v3
note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
desc: 2x8 MiB
Speed (MHz): avg: 2191 high: 2205 min/max: 2200/4120 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200
3: 2199 4: 2197 5: 2205 6: 2148 bogomips: 43217
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: spec_rstack_overflow mitigation: SMT disabled
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU117 [GeForce GTX 1650] driver: nvidia v: 545.29.06
alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current (as of
2024-01; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 09:00.0 chip-ID: 10de:1f82 class-ID: 0300
Display: x11 server: X.Org v: 21.1.10 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x2160 s-dpi: 91 s-size: 535x602mm (21.06x23.70")
s-diag: 805mm (31.71")
Monitor-1: DP-1 pos: primary,top res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
Monitor-2: HDMI-0 pos: bottom res: 1920x1080 hz: 60 dpi: 166
size: 294x166mm (11.57x6.54") diag: 338mm (13.29") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.06
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
memory: 3.91 GiB
API: Vulkan v: 1.3.274 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 driver: nvidia v: 545.29.06
device-ID: 10de:1f82 surfaces: xcb,xlib
Device-1: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 09:00.1 chip-ID: 10de:10fa class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: JMTek LLC. USB PnP Audio Device
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-2:3 chip-ID: 0c76:126e class-ID: 0300
API: ALSA v: k6.5.13-7-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.0.0 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-4: PulseAudio v: 16.1 status: active with: pulseaudio-alsa
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-e24a91d1d5bf state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> virtual: proto kernel_ll scope: link
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: veth47f79df state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-4: vethe8fdf2d state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-5: vethfc1a51f state: up speed: 10000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.96 TiB used: 2.12 TiB (71.6%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 3B2QEXM7 temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000VX008-2E3164
tech: HDD rpm: 5900 serial: <filter> fw-rev: CV12 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: V-Gen model: 01SM21NT256MT
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 5A0 scheme: GPT
ID-1: / raw-size: 97.66 GiB size: 97.66 GiB (100.00%) used: 59.58 GiB (61.0%)
fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: 858ada71-9967-47d5-bb8d-495c18aaf599
ID-2: /boot/efi raw-size: 1000 MiB size: 996 MiB (99.60%)
used: 29.8 MiB (3.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: D4F8-5870
ID-3: /home raw-size: 390.62 GiB size: 383.43 GiB (98.16%)
used: 273.68 GiB (71.4%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
label: home uuid: 3b3e44b5-a833-4e09-b668-250413d14da3
ID-4: /mnt/cross_apps raw-size: 332.88 GiB size: 332.88 GiB (100.00%)
used: 258.53 GiB (77.7%) fs: ntfs dev: /dev/nvme0n1p8 maj-min: 259:8
label: CrossApps uuid: 424EFD4D4EFD3A6D
ID-5: /mnt/warehouse raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 1.54 TiB (84.8%) fs: ntfs dev: /dev/sda2 maj-min: 8:2 label: Warehouse
uuid: 9C5EDB7B5EDB4CA0
ID-6: /var/cache raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
used: 59.58 GiB (61.0%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: 858ada71-9967-47d5-bb8d-495c18aaf599
ID-7: /var/log raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
ID-1: swap-1 type: partition size: 11.72 GiB used: 17 MiB (0.1%)
priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: a744f76f-4318-41b8-8117-a8299568048d
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 97.14 GiB fs: ntfs label: N/A
uuid: E40616080615DC7C
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 516 MiB fs: ntfs label: N/A
uuid: 50642D1A642D03F6
ID-4: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
ID-5: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
ID-6: /dev/sdb2 maj-min: 8:18 size: 238.46 GiB fs: ntfs label: SecondDrive
uuid: B46412A5641269FE
Device-1: 1-6:2 info: Areson Corp 2.4G Receiver type: keyboard,mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 25a7:fa23 class-ID: 0301
Hub-4: 3-1:2 info: Alcor Micro USB Hub ports: 4 rev: 2.0
chip-ID: 058f:6254 class-ID: 0900
Hub-5: 3-1.4:4 info: Alcor Micro USB Hub ports: 4 rev: 2.0
Device-1: 3-1.4.3:5 info: Wacom One Pen Display 13 type: HID
driver: usbhid,wacom interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 chip-ID: 056a:03a6 class-ID: 0300 serial: <filter>
Device-2: 3-1.4.4:6 info: Sejin Electron USB joint Keyboard type: keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 0510:0032 class-ID: 0301
Device-3: 3-2:3 info: JMTek LLC. USB PnP Audio Device type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 56.1 C mobo: N/A gpu: nvidia temp: 51 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Processes: 294 Power: uptime: 13m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 0 hibernate: platform
avail: shutdown,reboot,suspend,test_resume image: 12.5 GiB daemons: upowerd,
org_kde_powerdevil, power-profiles-daemon Init: systemd v: 255
Packages: 1559 pm: pacman pkgs: 1551 libs: 447 tools: pamac pm: flatpak
pkgs: 8 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.21 running-in: konsole inxi: 3.3.32
