Has anyone noticed extreme slowdown when disabling a monitor in the display configuration?
I have an XPS 15 that I connect to a Dell D6000 dock with 3 monitors. I have displaylink installed and after some tinkering it works fine. Sometimes the monitors will be disabled and I have to go to display configuration and enable those monitors and arrange them in the correct order.
If I disable an enabled montor myself though, it will work, but the system slows down to the point it’s unusable. I have to do this occasionally because one of my displays will look fuzzy (technical term) and disabling and reenabling it fixes it.
It’s not the end of the world. I would be just fine with it like this, but im curious if anyone has any insight to why this happens or if theres something I can do about it. Or does this only happen to me?
Here’s my system info:
2020 Dell XPS 15
KDE Plasma Version: 5.21.5
KDE Frameworks Version: 5.82.0
Qt Version: 5.15.2
Kernel Version: 5.12.9-1-MANJARO
OS Type: 64-bit
Graphics Platform: X11
Processors: 12 × Intel® Core™ i7-9750H CPU @ 2.60GHz
Memory: 31.0 GiB of RAM
Graphics Processor: Mesa Intel® UHD Graphics 630
I can give logs or whatever other info might be useful.
