Extreme Screen Tearing In Manjaro Xfce
hey guys
I am facing a problem whenever I start my laptop
I get this error for about 2-3 seconds after that everything becomes normal
I have faced this error in past and also got a solution but that solution does not work now
thanks
Here is my system info
[ayushk@ayush-inspiron3541 ~]$ inxi -Fxz
Kernel: 5.10.32-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: Xfce 4.16.0 Distro: Manjaro Linux base: Arch Linux
Type: Portable System: Dell product: Inspiron 3541 v: N/A serial:
Mobo: Dell model: Inspiron 3541 v: A07 serial: BIOS: Dell v: A07
date: 11/27/2015
ID-1: BAT0 charge: 3.4 Wh (60.7%) condition: 5.6/41.4 Wh (13.5%)
volts: 17.1 min: 14.8 model: SMP-SAN2.8 DELL FW1MN41 status: Charging
Info: Quad Core model: AMD A6-6310 APU with AMD Radeon R4 Graphics
bits: 64 type: MCP arch: Puma rev: 1 cache: L2: 2 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 14373
Speed: 998 MHz min/max: 1000/1800 MHz boost: enabled Core speeds (MHz):
1: 998 2: 998 3: 998 4: 997
Device-1: AMD Mullins [Radeon R4/R5 Graphics] vendor: Dell driver: radeon
v: kernel bus-ID: 00:01.0
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 2-1.4:5
Display: x11 server: X.Org 1.20.11 driver: loaded: radeon
resolution: 1366x768~60Hz
OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.10.32-1-MANJARO LLVM 11.1.0)
v: 4.5 Mesa 21.0.3 direct render: Yes
Device-1: AMD Kabini HDMI/DP Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:01.1
Device-2: AMD FCH Azalia vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 00:14.2
Sound Server-1: ALSA v: k5.10.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
IF: enp2s0 state: down mac:
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Dell driver: ath9k v: kernel port: e000 bus-ID: 03:00.0
IF: wlp3s0 state: up mac:
Device-1: Qualcomm Atheros AR9462 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 2-1.2:6
Local Storage: total: 465.76 GiB used: 161.75 GiB (34.7%)
ID-1: /dev/sda vendor: Seagate model: ST500LT012-1DG142 size: 465.76 GiB
ID-1: / size: 450.29 GiB used: 161.75 GiB (35.9%) fs: ext4 dev: /dev/sda1
ID-1: swap-1 type: partition size: 7.2 GiB used: 0 KiB (0.0%)
dev: /dev/sda2
System Temperatures: cpu: 69.0 C mobo: 60.0 C gpu: radeon temp: 68.0 C
Fan Speeds (RPM): cpu: 5194
Processes: 201 Uptime: 18m Memory: 3.28 GiB used: 1.43 GiB (43.7%)
Init: systemd Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1355
Shell: Bash v: 5.1.0 inxi: 3.3.04
