Hello everyone,
I am new to linux and am thinking of changing from bash to zsh as my default shell,
I am going to use this command chsh -s /etc/zsh username
are there any tips for caution that I should consider before changing shell ?
This command will not work.
Check the shells available at your system with
chsh -l
Then pick one path and do
chsh -s full-path-to-shell
Run the commands as a normal user, no sudo
. No need to add a username for the current user. The path you posted can’t be a full path to a shell binary. A example would be /usr/bin/zsh
, but check if the path is listed in chsh -l
To see an effect log out and in again.
>>> chsh -l
/bin/sh
/bin/bash
/bin/zsh
/usr/bin/zsh
/usr/bin/git-shell
these are the available options.
Pick the one you like. Since /bin/zsh
is just a link to /usr/bin/zsh
chsh -s /usr/bin/zsh
Don’t forget to logout and in again.
